Receiver shuts off when I turn up spund past 66db (max)
When I turn my my receiver past 66db, it turns off. This happen when watching TV, or on DVD, even the radio. thought maybe it was to hot, so I placed a fan by fan by it, but no go. When I was calabrating the speakers, it would go from L, C, R, RS, then when it would go to the rear speakers, it would cut off on me. SO I tried removing the rear speakers, and I programed it to tell the receiver that there was no rear speakers, but still that did no good. I even tried puting it on pure stereo (just the L + R speakers) and it still shuts off when you turn the sound up past 66db max.
  • 31 Answers
What receiver do you have? Some receivers do this as a protection mechanism if something is shorting. does it turn off if you disconnect all of the speakers and turn it up? If not, then you most likely have some wires touching each other or something else, or you may have a speaker that is blown or shorted. If it still shuts off them most likely there is something wrong internally, and if thats the case your best bet would be to return it or take it into a professional. Hope this helps.
Posted on Mar 30, 2008
SOURCE:
Tv screen turns black and red when playing through pioneer receiver
Usually when I hear of solid colors that display on a TV, my first solution would be to change the cable. We know your DVD player is working as you connected it straight to your TV and you report no problems. I assume you are using a composite cable (red, white, and yellow) Red and White being the Audio and Yellow your video.
But since your player works...and your tv works under the same input, then the only other issue would be the output cable from the receiver or the actual composite input or output connector is faulty.
try a video game system in place of the dvd player through your receiver..if it happens again, then change the receiver's output cable...if it still persists then your reciever's output connector is faulty.
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/anthony_db0df2be5e6f8c0c
Aug 09, 2012 | Audio Players & Recorders
Dish menu but no picture or sound
Try holding the power button in on the receiver until the picture goes away then turn it aloose it will reboot and your sound will usually come back. If you had rather and can get to it unplugging it from the electric outlet, the receiver, does the same thing.
Oct 21, 2009 | Televison & Video
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
Receiver shuts off when trying to play a dvd in the dvd player.
Just a hunch - what's drawing power from the two convenience outlets on the back of the receiver. They're only rated for 120watts, that is, nothing like a TV.
I doubt this has anything to do with the source you're playing (unless you have it cranked to "11"). If I understand you correctly you said turning the TV on and off causes the problem. There's a clue.
Apr 07, 2009 | Denon AVR-1803 Receiver
Harmony 880 remote will not turn on my dish 622 satellite receiv
Have you tried contacting your dish people, maybe they can reset.
Mar 07, 2009 | Logitech Harmony 880 LCD Remote Control
Have to turn the volume near max on my Onkyo receiver to hear TV
it sounds like a source level adjustment refer to your users manual and see if there is a way to turn the SLA up and if not then a small amp can be bought or purchased to boost the sound from the tv. check out the Fiio E5 for examples it might just do the trick
Feb 18, 2009 | Onkyo TX-SR500 Receiver
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
No Picture
check the power cord
Dec 17, 2007 | Sony KV-32S42 32" TV
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Powers off when watching dvds
Hard to say if this indicates a more serious problem that should be looked into. If under warranty take the receiver back to the shop and let them worry about it. If warranty no longer valid, you should let a professional Yamaha service person look into it. But first lets see if we can't work around this problem. Is the DVD connected to its own power supply, or connected to the AC outlets in the back of the receiver? in case DVD player's power cord is connected to the back of the receiver, I suggest you connect it independently to another electricity socket, and see if this has any effect on the problem. Another thing to try is to connect the DVD audio cables to the receiver, and the video cables directly into the TV. Even if this helps you solve the problem, you're better off having someone look into it. especially if under warranty, don?t think twice. good luck
Jan 16, 2006 | Yamaha HTR-5635 5.1 Channels Receiver
97 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
