Question about Sharp MD-MT20 Personal MiniDisc Player
Utoc error or toc error
When playing a disc it reads utoc error or toc erro. Also record doesn't work.
2 Suggested Answers
SOURCE: toc error problem
HEY,
t is not the topic, but I'm for al long time searching for the sharp md-mt20h and I see that you buy a new md player? Were can I buy him?? thanx
Posted on Feb 26, 2008
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
SONY MDS JE 530. (C14) Toc error.
Your owners manual (you DID read your owners manual, right?) says the machine cannot read the TOC on the disc.
It might be a disc problem and it might be a deck problem?
Have you tried a different minidisc?
Have you changed any of the SET-UP settings? Take a look at them, too.
Apr 01, 2013 | Audio Players & Recorders
How i can fix TOC ERRORa
Table of Contents errors usually happen if you lose power before the disc is 'finalized' when recording. You cannot unplug the unit before it is done with a disc, or remove it until it is done finalizing. You will see "TOC" flash when you are done recording. When it stops, then you are all set. Try a fresh disc and see if that works.
Mar 26, 2012 | Audio Players & Recorders
My MD-MS702 gave me very good service. Unfortunately it was not used for five to six years and now when i switch it on after full battery charging I get TOC error on all of my recorded discs. SOS, as I am...
According to you You don't have use your disk play for a huge time, so that it may damaged or lens became dirty.
You can clear the lens with lens cleaner (clear the optical head).
check the battery was properly charged or working.
Check the disk moved properly.
To prevent the disk erase or damage slide the accidental erase prevention tab.
You can show it to the Technician.
Jan 06, 2011 | Audio Players & Recorders
When I input a disc and hit play I receive an error which says "TOC ERRORa".
Possible that the disc is not reading and so the the TOC- table of content error must be referred.
It can be due to a poor head tracking or the failure of the data being read or processed.
Clean the head and use a good disc to be checked once again. If so the optical head can be faulty as it might be getting weaker.
Nov 06, 2010 | Sharp MD-MS702 Personal MiniDisc Player
Kenwood MD plays ok but recordings fail to play; U TOC error?
Without a decent Table Of Contents, your MiniDisc will NOT work, as you've found out. Does it matter what brand of MD you use? I would record it at "1X" and NOT 4x speed too. Try erasing a blank minidisc first and then shut off the unit and then turn it back on and see if the TOC works. Try adding a title, then turn it off and back on. Then try the CD to MD.
Jan 16, 2010 | Audio Players & Recorders
Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Oct 09, 2009 | Philips CDR770 CD Recorder
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
Aug 19, 2009 | Sharp MD-MS702 Personal MiniDisc Player
What does toc err mean?
TOC is table of contents. Typically if its on a recorded cd try burning a cd from antoher computer and try it, if it works its most likely that your burner or software or ccd's your using are bad. Also is it a MP3 disc your trying to play? If so then you MUST burn it as a MP3 cd. You cant just burn MP3's to a CD and it read them. If this is the case thats why you are getting the TOC error because its not writing to the CD whats on the CD on the TOC area of the disc.
Sep 14, 2007 | Kenwood KDC-MP228 CD Player
Sharp MD-MT20 Personal MiniDisc Player Logo
225 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
