Question about Zenith Z32H41D TV
No picture, Horizontal line center of screen
I have a Zenith Z32H41D 32" T.V. that has a White horizontal line that is centered in the screen. The audio seems to be okay. The line is a bright white color. I removed the back cover and see no signs of a fryed board nor any burnt chips. I adjusted the manual horizontal and vertical controls with no change. Any help is greatly appreciated. Greg
  • yasky1 Mar 30, 2008
    I re-soldered the 4 pin yoke connector to the main board; no fix. I re-soldered the transistor labeled H.O.T. which is located behind the yoke connector and behind the Deflection Transformer. No fix. Could you explain the measuring steps for the transistor? I've worked with low DC voltage transistors, and want to make sure of the correct procedure. Thanks, Greg
  • yasky1 Apr 01, 2008
    I removed and tested the transistor. Readings are Base to emitter = 45 Ohms. Reverse leads same reading. Collector to base = Open, reverse leads = 1.4M Ohms. Collector to emitter = Open, reverse leads = 1.4M Ohms. Replaced transistor, new transistor readings are the same except the 1.4M Ohms readings are 2.2M Ohms. Installed new transistor, No change. Is the Vertical driver the next best area for testing? Thanks, Greg
  • Zenith Master
  • 8,617 Answers
You either have a bad solder joint at the yoke plug. Thats the large group of wires coming off the yoke on the picture tube neck, Resolder where that plugs enters the chassis the pins may have a crack in the solder, The other item to check is the solder around the horizontal output which is mounted on the heat sink near the flyback transformer. That Transistor could be open as well and if so it will need replacing. Try the solder first however as that seems most likely.
Posted on Mar 30, 2008
  • Sonny Berry
    Sonny Berry Mar 30, 2008
    okay, first you have to remove the transistor from circuit then check for resistance pins much like checking a diode any 2 pins should have resistance in one direction but very little when the meter leads are reversed on the same two pins you check emitter to base and collector to base then emitter to collector if you get high continuity on any given 2 pins no matter how you reverse the meter leads the trans is shorted. If you get no continuity no matter how you reverse the meter leads the transistor is open. Either way the trans will need to be replaced. Let me know if you have any questions or need more assistance.
  • Sonny Berry
    Sonny Berry Apr 01, 2008
    yes it has to be one of the components in the vertical circuit that is causing the loss of vertical deflection also check the diodes and resistors in the vertical section.
  • Zenith Master
  • 19,396 Answers
Can be a case of vertical collapse. If this is the case, then the vertical oscillator and/or the vertical driver circuit are faulty. .
You can take you problem directly to zenith. They have a customer service post available here
SOURCE:
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Zenith b25a24z has a line in center of screen and i replace the verticle output ic and the problem remains can somebody help me?
was the line vertical or horizontal? if vertical check on the horizantal sync side if horizontal check vertical side also check for dry solder joint on the circuite.
Apr 07, 2010 | Zenith C27A24T 27" TV
White, horizontal line in center with vertical striations.
55hdm71 plasma hitachi vertical lins 3 red on right side what do i do?
Oct 04, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
RCA tv model F32649 white horizontal lines
the problem of your tv is in vertical section, to be sure change all the capacitor in vertical section.
Sep 27, 2008 | RCA F32649 32" TV
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
White Horizontal line across screen
It is most likely the vertical deflection IC has overheated and lost its soldering. If you open your TV up, it is a 10-15 pin in a row IC sticking out of the motherboard attached to a heatsink. It should be labeled "IC451." Give it a wiggle, see if it affects the picture, You may have to resolder them in place.
The IC may be hard to find, look for a peice of metal that is sticking out of the motherboard, attached to a small chip. I fixed a samsung tv that had it in the middle area.
Mar 27, 2008 | Zenith Z32H41D TV
Televison & Video Logo
147 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
