Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
Red convergence out of alingment
How to adjust the red convergence on a sony kf60xbr800
or how to get to the grid screen when in the srvice mode
  • Sony Master
  • 8,617 Answers
If you cant adjust it with the convergence option on the menu you will need new ICs. They are inexpensive. I can post a link where you can get replacement ICs and free step by step instructions on how to do the repair yoursel. The Conversion ICs will have STK numbers such as STK392-110 or simallar There are two of them identical attached to a large heat sink.
Posted on Mar 30, 2008
SOURCE:
Red picture tube out of alingment how do you make major adjustment
Its done with the original remote--convergence in the customer menu should be looked at first---call up the crosses or the grid of lines, it has one or the other.
You first want to look to see if red out and then if it will move both up/down and left right where off.
If it will not move in some direction anywhere on the screen the convergence output chips the set uses are bad.
The set will or should have two hidden menus, one will bring up the advanced grid for convergence---input for that with the remote is Mute, 181 or 183----if you call up the wrong one shut set off and try the other number.
It is possible to converge the whole screen there, if memory serves me 7,8,9 change the color being adjusted DO NOT ADJUST GREEN FOR ANY REASON.
two buttons (different on different remotes will move the cursor around the grid (and the remote must have a button somewhere on it with "data" to save the adjustments.
Check in customer menu the convergence first---got movement?
Dec 08, 2012 | Samsung HLP5685W 56" Rear Projection...
Sony kf60xbr800 red ghost
See if you can download the manual from here:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KF60XBR800
Also, if you haven't been here already:
http://esupport.sony.com/US/perl/model-home.pl?mdl=KF60XBR800&LOC=3
Hope that helps!
Feb 05, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
How i adjust horizontal size and vertical size
To answer your concern, all you have to do is to change the setting of your aspect ratio on your TV.
Here is my suggested way to procede:
1. Apply 1080i signal, which should produce an oversized HD image on ColorStream1or 2.
2. Select an HD channel that is broadcasting standard 4:3 image, not wide screen.
3. Switch to the Service Mode ( Please refer to the above links). In the Service mode, press channel up/down to find the Adjustment parameters needed for the following steps.
4. Adjust HIT with volume up/down control for the image height to 22.5 inches.
6. Adjust WID for image width of 30 inches, (22.5*4/3)
7. Adjust HPOS to center the image.
8. Adjust PARA and TRAP to minimize geometric distortion.
9. Switch into Convergence mode and Adjust VLIN to get equally spaced horizontal grid lines.
10. Measure the length of the central grid lines and note the number of horizontal and vertical grid lines. This information is used to create an overlay grid.
11. Create the overlay grid on 40x25 x0.003 inch clear Acetate sheet, which you can get at the Art Supply store for under $2. Draw the grid with a fine line erasable pen. Draw vertical and horizontal lines through the center of the sheet so that the lengths are the same as the central grid lines. Now draw the grid so that it has the same number of lines as the convergence grid but are equally spaced, with the outer ones at the ends of the central lines.
12. Cut off about 1/4 inch from the right side of the sheet so that the sheet can lay flat against the screen, which is slightly less than 40 inches.
13. Put a reference mark on the TV frame 2.5 inches down from the upper left side of the screen.
14. Place the overlay on the screen so that the upper edge lines up with the reference mark. The overlay sticks by electrostatic attraction.
15. Use convergence controls to remove grid distortion and converge grid colors. Refer to the Anamorphic link for details.
16. Enjoy 1080i.
Other Comments:
I didn't realize I could create the overlay grid before placing the Acetate sheet on the TV screen, until I finished drawing the grid with the sheet placed on the screen. I added grid lines as called for in the procedure. I'm sure this method took much longer no only to draw the lines but some of them were difficult to see.
Part way through the convergence procedure, I became concerned that the image width was off since I did my screen adjustment with wide screen image. Thus, I decided to repeat that step with a 4:3 screen.
I confirmed the need to press 7 often to save results since after I adjusted one grid color without it, I accidentally hit a key that switched me out of convergence mode and when I switched back, all settings were gone.
Another mistake I made was not realizing that the cursor color determines which grid gets moved.
May 13, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
Convergence
Have you tried to adjust the convergence in service mode yet?
If not here are the steps.
1) Turn the TV off with the System off (under flap of remote)
2) Press: Display, 5, Volume+, then Power. If successful, service text will appear on the screen.
3) Use 2 & 5 - to select the PJE category. Be careful, like your computer, you don't want to be adjusting the wrong screen.
4) Press 9 - to get to the convergence adjusting.
5) Press 6 several times to get the convergence screen of choice. (I like the grid)
6) Use the remotes arrow keys (joystick), move the brackets around until you have found the area to adjust. Press the center of the joystick to change the bracket from white to a color. Use the joystick to adjust the color(Push it sideways or up and down and hold). Press 3 to change color to adjust(red, green or blue). When done, press center of joystick again, this will turn it back to white.
Note: Try to keep the grid even and square.
7) Repeat step 6 for all parts of the screen that need it.
8) Once done, you need to save your settings. Press: Mute,Enter. Then on the T.V. press "Flash Focus" (it will set it self)
9) Turn off Power.
Jan 10, 2010 | Sony KP-51WS510 51" Rear Projection...
How to get in convergence set up mode sony tv kp51ws500
OTHER THAN TRYING IT IN THE CUSTOMER MENU there is the tech menu.
With the set off on the original Sony remote control press:
Display, 5, Vol up and power.
The set should come on with a lot of words and numbers on screen.
With 1 OR 4 you navigate until you see PJE on the screen.
9, and then 6 on the remote will bring up the convergence grid. You will see a grid with a blinking colored cursor--if it is green do nothing--3 will allow you to change to red or blue or green. IT IS A GOOD IDEA TO CHANGE THE SET TO A UNUSED VIDEO INPUT TO MAKE IT EASY TO SEE WHAT YOU ARE DOING.
Select red with the three button and navigate with the 1 or 4 buttons--enter button will allow you to adjust. enter again will allow you to navigate with the 1 or 4 buttons-- you want to get to the middle of the screen and then with 1 or 4 buttons navigate from the center around the screen.
You will find 1 moves adjustment in one direction and 4 in another. Go all around and adjust red first. Then repeat with blue.
YOU ACTUALLY ADJUST USING THE CURSOR BUTTONS--WHEEL NEAR THE MIDDLE OF THE REMOTE--YOU WILL SEE THE CHANGES AS YOU DO THIS.
When you are done hit Muting and then enter to save adjustments.
NOTE: some of these sets require the convergence be adjusted in the 4X3 which will also adjust in the FULL--if the set has the ZOOM AND WIDE zoom you will have to repeat the adjustment again in one of those modes to adjust Zoom and Wide Zoom.
Also if you have HD connection you may have to adjust it there also--many of these sets require it to be adjusted 3 times in the three modes.
IF convergence will not adjust in any one of the picture modes you have a convergence circuit problem and need to replace the convergence chips etc.
When you are done be sure to hit Muting and then Enter to save adjustments you have made. The word Write will appear on screen in green when you press muting and then in green when you press enter--it means you have saved the adjustments.
NEVER TRY TO ADJUST GREEN!
If you have questions or need help let me know.
IF this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 06, 2009 | Sony KP-51WS500 51" Rear Projection...
I have 46ux13k hitachi tv and i need to know if there is atrick to adjusting the convergence.
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACHI REMOTE. NONE ELSE WILL DO
1. Receive an NTSC signal.
2. Press Magic Focus to begin magic focus
3. Press magic focus again during the magic focus process to get the “stop” screen.
4. While stop screen is up, press STATUS or INFO on the remote control (R/C) to bring you to DCAM mode and the service grid (64 point grid).
5. When you first get in here? I believe red is the selected color by default (it is flashing).
6. To choose other colors to converge, use the following buttons on the R/C:
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
ONE COLOR WILL NOT MOVE. YOU WILL NEED TO MOVE OTHER COLORS TO ALIGN TO IT.
7. Start from the center of the screen and work your way out on one color at a time. I adjusted red across the whole screen to match green. Then I switched to blue, and adjusted that to green as well. After you adjust blue, you
may want to go back and adjust some red again? etc. until the convergence looks good.
· Use 4, 6, 2, and 5 on the R/C to move the cursor position (dotted lines).
· Use thumb stick to move the convergence point color.
Then going along the lines and adjusting, you may run into the problem of getting an ‘S’ curve on the line. You’ll know if you get there. Basically, no matter what you do to adjust the line to be converged, the middle of the line between the points will not straighten out (it bends between the points). To fix this, the manual recommends going to the (7x5) mode which gives you less points to adjust. I had this problem, and the solution worked. There is also another mode (3x3) which gives you even less points. Basically, if the set looks good, you only fine tune it in (13x9) mode (64 point). If you have serious problems, the grids work as:
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
10) To get to each of these patterns use the following on the R/C: (only if you need to)
1. (3x3) Press “STATUS” 5 times (only works when DCU is in uncorrected state)
2. (7x5) Press “0” 5 times
3. (13x9) Press “ANT” 5 times
11) If you adjust the 3x3, then you should go to the 7x5, and then the 13x9. You get the point… depending on where you start, work your way up, and always finish on the 13x9
12) When finishing up the 13x9 mode, to get additional ‘grids’ on the edges of the screen, press the PIP CH button on the remote control while in the digital convergence adjustment mode (DCAM). Fine tune the edge convergence as necessary. To exit, press PIP CH again.
13) When convergence is acceptable, press PIP MODE to write data to ROM memory. ROM WRITE? is displayed to alarm system that ROM will be overwritten with new data. Press the PIP MODE button again to write displayed data to ROM.
14) DATA WRITE TO ROM will take approximately 4 seconds and no picture will be displayed.
15) Green dots will be displayed when operation is completed.
16) Press MUTE to return to convergence pattern, then confirm again convergence is acceptable.
17) Turn power OFF.
18) Wait a few seconds. Turn the TV on, and you should have your normal signal. Press Magic Focus button just to make sure the magic focus still works (and that you did the last few steps properly)
Mar 21, 2009 | Hitachi 43FDX01B TV
Convergence problem with TV Pojection Sony KDP65WS550
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Oct 08, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Pioneer sd-643hd5 rear projection 64" tv has green geometry grid problems
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Hitachi 43FDXO1B Convergence?
Manual Convergence for the Hitachi. YOU WILL NEED ORIGINAL HITACH REMOTE CONTROL. NONE ELSE WILL DO.
· “STATUS” - Green
· “0” - Red
· “ANT” – Blue
3x3 – ‘coarse’
7x5 – ‘medium’
13x9 – ‘fine’
17) Turn power OFF.
Jan 13, 2008 | Hitachi 43FDX01B TV
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
79 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
