Question about Alera Technologies Cruiser (270118) DVD±RW Dual Layer Burner
Land Cruiser mantenance
Changed the timing belt but need the procedure to turn of the timing belt warning light
  • 2 more comments
  • mikira Mar 30, 2008
    Have had no response from any expert!
  • mikira Apr 03, 2008
    Is this web site a scam?
    I paid my fee for mechanical expert assistance/advice but have had zero response on a probable solution.
    However I have recieved several invitations to spend more fees to get added expeert advice!!
    Whats going on??
  • mikira Apr 07, 2008
    Thanks for the tip!
    Cheers
    Thanks to those that reponded. Will continue to use the service!
  • 3,037 Answers
Here you go
When the warning light comes on replace the timing belt then reset the light. To reset the light, according to my repair manual:
Remove the grommet from the speedometer and turn off the lamp by pushing the warning light reset switch, then replace the grommet. Make sure you replace the belt first and don't just reset the light. If the belt breaks it can do major engine damage.
Let me know if you need any more help or have further questions
Good luck fixing this and have a good day
Posted on Apr 07, 2008
  • 69 Answers
It sounds to like you need to get a hold of a diagnostic tester so you can reset the light. I don't know of any other way to turn off the light. Hope this helps
  • Jason Breth
    Jason Breth Apr 07, 2008
    One other thing you can try, disconnect the battery for approx. 2 to 3 minutes this should reset the computer. If not you need a diagnostic tester to reset it.
  • 13,433 Answers
The site is legit, no one seems to exactly know what your talking about, is this a DVD RW DRIVE or a CAR??
what is it exactly.
Land cruiser 2010 timing belt warning light ON, how can reset?
not sure if thes will work for you but try it you wont lose any thing :
turn the key on hold the odometer button in and turn the key but don't start the engine and keep holding the button for 10 ten seconds then lift your finger off the button and the number 1 should come up now this number represents 10,000 K's so what you do is keep pushing the button until you reach the desired K's you want you can go up to 20 = 200,000 K's and then you hold the button in for another 10 seconds then let go and turn the key off and turn it back on and it should be gone i know this works because I've just done it today
Mar 26, 2013 | 2010 Toyota Land Cruiser
Timing chain replacement 1994 land cruiser 4.5 eng
Best not be an azzclown and get your T Belt changed and it may be less than 1500 dollars but good luck with that,ya get what you pay for!
Feb 07, 2012 | 1994 Toyota Land Cruiser
How to tun off timing light after changing the belt
with ignition turned on, using the trip switch , change the display to ODO, and then turn the ignition OFF
While pressing the trip switch,turn the ignition switch ON and hold for five seconds
Release the trip switch,then press the switch again within five seconds.The digital display should change to T- BELT MODE. Each press of the switch then should change the reset time by 10,000km increments. After setting the klms hold the trip switch ON for more than five seconds then release the switch. Check that the display has now changed back to ODO and that now the warning has gone off when the engine is started .
Dec 28, 2010 | 2006 Toyota Land Cruiser
How do i turn of the timing belt light on my 04 landcruiser 3 litre
Ive never heard of a timing belt light, but there is a maintenance light that can be reset. Here the procedure:
To reset the maintenance reminder light: Turn the ignition switch to the "ON" position. Set the odometer/trip display to the odometer (ODO) mode. Turn the ignition switch off. Depress and hold the trip meter reset button while turning the ignition switch to the on position. The maintenance reminder light will, illuminate for 3 seconds, blink for 2 seconds, illuminate solid for 1 second and then turn off. Release the trip meter reset button. Turn the ignition switch to the off position. Turn the ignition switch to the on position. Confirm that the maintenance light goes out.
Let me know if this helped you out!
Mar 29, 2010 | 2004 Toyota Land Cruiser
How do I reset the timing belt warning light in a 2004 toyota prado 120 diesel
how to reset timing belt warning light in a toyota hilux model LN 145
Aug 29, 2009 | 2004 Toyota Land Cruiser
I want to know how to turn off T-beltlight
I understand that this warning light comes on whenever the odometer reaches 100,000 and multiples thereof, as a reminder to change the timing belt. Once the t-belt has been changed, the light should be off. How? I don't know - the local Toyota service center made the change for me. good luck. Rolf H.
Apr 13, 2009 | 1999 Toyota Land Cruiser
Timing belt light of Toyota LandCruiser 2006
the reset procedure of the timing belt light is all done by pressing the trip meter button and holding it in whilst the ignition is turned to on then select from the trip button then continue pressing until you come to 15 on trip metre, turn off and then restart. The light should then go off.
Dec 27, 2008 | 2006 Toyota Land Cruiser
How to reset timing belt warning light of UZJ100 LANDCRUSER
what year what type ??? whats a holden ,i think its an opel now ,best advice remove the bulb
Nov 21, 2008 | 2006 Toyota Land Cruiser
T-BELT light in dash of 78/79 cruiser ute
You need to remove the dash and swop this screw into the other hole. tbelt1.jpg
Also the light should come on at 100,000km, this could indicate that your speedo has been clocked.
Sep 16, 2008 | 2000 Toyota Land Cruiser
Toyota Land Cruiser check timimg Belt
I am assuming that you have a series 80 diesel engine and that it has run for about 100,000 kms hence the warning light and the changing of the timing belt. Based on the instructions of its repair manual you need to "remove the grommet off from the speedometer and turn off the lamp by pushing the warning light reset switch, then replace the grommet." Alternately, you can try to reset the entire computer of the vehicle by removing the battery cables for a couple of minutes. Pls note that some car radios/head units would revert to security default (ask for a code) when power is completely removed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 24, 2008 | 1997 Toyota Land Cruiser
Alera Technologies Cruiser (270118) DVD±RW Dual Layer Burner Logo
307 people viewed this question
Top Alera Technologies Computers & Internet Experts
solver2010
Tom Chichester
Bill Boyd
Are you an Alera Technologies Computer and Internet Expert? Answer questions, earn points and help others
