Question about Keurig Platinum B70 Coffee Maker
It won't brew when i put a kcup in but as soon as i take the kcup out i have no problem with the water going through
    Champion:
  • 213 Answers
Sometimes if the coffee is packed in to tightly or if your using a finer ground coffee it makes it harder to pump water through.
Hope that helps its just my experience. Mine does this too. I like my coffee strong so I understand
Posted on May 14, 2010
Keurig 2.0 coffee grounds are everywhere
Ensure the kcups are being pierced by both the bottom and top needles. Be sure to check each kcup is thoroughly sealed before placing it in the brewer. Crushed or dented kcups may not brew properly.
Feb 18, 2015 | Keurig K350 2.0 Brewer
It goes through all the cycles but no hot water comes out. Unit is two months old.
Have you tried brewing with no k-cup in the unit? If water comes out then the needle that punctures the bottom of the kcup needs to be cleared out. I use a paper clip and put it into the kcup holder where the puncture needle is. I move it up and down the hole until cleared out.
Jul 19, 2014 | Keurig Elite B40 Coffee Maker
Helpline
Sounds like a cleaning problem. Mix 1/2 vinegar and 1/2 water pout into machine and brew,WITHOUT K CUP! Do 5-6 x's and then brew plain water to rinse vinegar out. Do this several times. Should be ready to go.
Mar 31, 2014 | Keurig Coffee Makers & Espresso Machines
At the end of brewing it explodes water and grounds
Clean the Tubes that penetrate the Kcups. Use a needle or paperclip.
Oct 01, 2012 | Keurig B30 Mini Coffee Maker
My k cup reusable coffee filter for the b60 keurig coffee maker is leaking water when i'm brewing coffee with it. What should I do to fix this?
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
Dec 29, 2010 | Keurig B60 Coffee Maker
Be sure to clean the nozzle in the bottom of the cup holder and retest, but if this machine is more than 3 years old, the pump is probably bad. I have had several of these fail. Keurig says this is not repairable - just buy a new one (get someone on the phone.) They have always offered me a fair trade-in value against a new one. For me, 2 or 3 years from one of these machines is acceptable given the convenience and quality of coffee every day.
Mar 20, 2010 | Keurig Platinum B70 Coffee Maker
MY b60 all of a sudden won't fill a full cup when it brews. I descaled it and it works just fine and fills the cup with water and no kcup in place. When I brew with the kcup it only half fills.what can I...
When I descaled my b60 I also used a paper clip to clean out a possibe clog in the little bottom drainage tube. The help I received suggested I also use the paper clip to check the top tube which I didn't know about. I did this and now it works fine...thanks for your help.
Dec 30, 2009 | Keurig B60 Coffee Maker
My Keurig is leaving a lot of coffee grounds in the cup
I found that the kcups were under pressure. When I insert the kcup, I press down on the cup to puncture the bottom of the cup then close it. Works fine now.
May 16, 2009 | Keurig Special Edition B60 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
169 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
