Question about Disney Mix Max Digital Media Player
Mix max When we plug the headphones into the jack it is so loose that they do not stay in. Could there be a piece missing? Can this be fixed?
  • gms123 Apr 18, 2008
    Our Mix Max is having the same problem. Can the port for the headphones be replaced by someone?
    Scholar:
  • 93 Answers
It shouldn't be doing that at all.
I would suggest you take it back to the store for a replacement of contact the manufacturer for a warranty replacement if the store won't take it back.
Posted on Apr 01, 2008
SOURCE:
Loose audio plug
thing is headphone jack seems gone unable to fix that try to buy new headphone or else try to use the port at the backside of cpu.
Feb 16, 2014 | HP Pavilion Computers & Internet
No sound thru headphone jack
Please confirm that the sound from the main output is working. if it is functioning then check if there is not a seperate Headphone volume or mix control adjustment.
Jan 31, 2014 | Pioneer Audio Players & Recorders
Headphone jack has a piece of connector stuck in it and it is making my speakers not work how can i fix this problem?
You will need to remove the broken piece. Power down the computer and unplug it. The only suggestion I would have is see if you get get to the jack from inside the computer and push out the broken piece with a paper clip.
Jun 11, 2012 | Dell Dimension E510 Dual Core 2.8 Ghz...
Yamaha CP 300 broken headphone jack
Some keyboards use the amp output sockets for headphone use.
You might need some adapters for your headphones.
If it fell in, you would see an empty hole. This would be unlikely because it is held on by two screws. If all fails, buy an amp with a headphone jack input. Plug the keyboard into the amp and use the amps jack.
Dec 15, 2011 | Yamaha CP300 Stage Digital Piano...
HEAD PHONE WAS USE FOR LISTENING, WHEN REMOVE NO SOUND COMES SPEAKERS
a good guess is either part of the headphone plug stayed in the jack holding out the speakers (looking carefully at the plug for a missing tip), If thats the case should be able to see it inside the jack, so a deck screw will probably thread into the broken piece and pull it out (unplug the unit first please) or, the jack itself is faulty and holding the speakers out. Those two would be the cheap things to look at first. If neither of those end up as the culprit then either repost naming your product or seek professional servicing, as there would be a fault in the circuitry.
Feb 23, 2010 | Sony DAV-S400 System
Only one earphone works, weird problem
there is a broken solder joint where it is on the pc board.it is not the earbud itself,because when you pull it out,both sides work.the jack has 3 sections,the tip which is one side,the next piece,which is the other side,and the shank piece which is the ground.the ground connects to the outside ring of the headphone jack.there are 2 contact points inside for the two channels.what happens is the copper foil of the pc board fractures where the pins are soldered.scrape away some of the foil so that copper is exposed for the pins,and resolder it and it will work if you wiggle the jack,you will see the whole piece of circuit board move where it is cracked.after fixing it,put epoxy over the area to make it stronger.
Jul 19, 2009 | Audio Players & Recorders
Cant hear out of right ear piece
The usual cause for that is that the headphone jack is loose or the connectors are loose inside the unit and therefore not keeping complete contact with the headphone piece. It can be repaired but would probably be cheaper to get a new MP3 if that is the sansa one.
Feb 03, 2009 | Insignia Sport MP3 Player
No sound
I had this problem as well. I would get sound from headphones but unplugging them I had no sound from the builtin speaker.
When you plug in your headphones it moves a thin piece of metal in the jack which interrupts a connection (this is a good thing) so it can know when to disable the internal speaker. When you unplug your headphones the piece of metal moves back and it enables the internal speaker again.
I was able to fix this by taking apart my x51v and bending the piece of metal a little while the headphones are plugged in so that it will contact better when the headphones are unplugged,
To take your axim apart there are 4 screws on the back underneath the rubber grips that you need to take out. Then you can just slide a finger nail up and down each side to remove the front and back of the casing. The back you will need to swing out from the bottom since it hooks over the headphone jack. I unplugged the small wire that connects the front half of the case to the guts using a tiny flat screwdriver.
Inside on the back, there is a black plastic plate that is held on by 4 more screws. Take that off.
Now you can see the headphone jack. I plugged in my headphones and used a small flat screwdriver to push against the headphone jack on the bottom piece of metal on the right side with the axim face down. You can observe the piece I mean by looking at the side of the headphone jack when you plug and unplug headphones. It moves perhaps 1/32 of an inch.
Your goal is to bend the piece of metal closer to where it is when no headphones are plugged in. The only way to bend it properly is to do it when the headphones are in.
Sorry if this isn't clear enough. I'm not sure if this is a permanent fix or not but it's worked for me.
Jan 04, 2009 | Dell Axim X51v Pocket PC
Loose headphone jack
if there isn't screws to take the MP3 player apart then their are clips on the inside
Unscrew the screws (or if you have clips from the on/off switch use a screw driver to open it. this isn't the most safest way to open it i could break so this is a last opption.)
ussing a sodering iron resoder the conection between the loose headphone jack and the curcit board.
(you can pick up a sodering iron at Radio shack for as low as 10$)
Oct 19, 2008 | Samsung Yepp YP-P2 Digital Media Player
The earphone port has lost whatever holds the earphone in the mix max, can it be repaired?
yes it can be repaired your looking at $20 for new headphone jack installed should not cost anymore than that any electric repair place should install one for you even radio shack
Jul 17, 2008 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
26 people viewed this question
Top Disney Audio Players & Recorders Experts
Ekse
Trevor Turner
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
