Question about GE DBXR453EV Dryer
DBXR453 GE Electric Dryer - Noisy
As the dryer heats up it has a loud, rythmic, metalic squeal. It is not the tension pully or the belt (both tested and good). The sound is coming from the middle of the back of the dryer. It is LOUD. I am thinking that as the metal heats up it expands and somehting is rubbing that should not.
  • dtaul Apr 18, 2009
    I have the same dryer and same problem except mine is really squeaky right from the start and then sometimes quiets down as it runs.
I have the same dryer, with the dryer empty open the door and try to push the basket up, if it has lots of play in it then you should check the "bearing drum" which is attached to the front panel. this machine doesnt have bearing on the back of the drum. it rides on plastic sleaves called slide drum. they are on the inside of the front dryer panel. only 4 screws to remove and check
Posted on Jan 20, 2009
    Novelist:
  • 163 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
LG dle3777w emitting a high-pitched squeal
Hello there and thank you for choosing fixya
If your dryer is making a squealing sound or a high pitch noise please look at the following
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
May 17, 2011 | LG DLE3777 Electric Dryer
My electric dryer makes a loud squeal while drying? what is wrong
Hello
Sounds like the belt is slipping from wear.Remove rear panel of dryer and replace the belt.
Its not very hard to do.
Belt wraps wround the drum and a pully on the motor,there may be an idler pully also.
Check these pullys and motor for free turning while the belt is off.
Mar 20, 2011 | Frigidaire Dryers
My GE dryer is making a real loud noice while drying model #DBXR463ED2WW
hELLO THERE
If your dryer is noisy, check these: Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Dec 04, 2010 | GE Dryers
Squeling on dryer model #dpsr475ewoww
replace the belt and tensioner pully to eliminate the squealing
Sears sell these parts in sets
Jun 07, 2010 | GE DPSR483EA Electric Dryer
Squealing dryer
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts. Also Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
Apr 06, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag MDE5500AYW 220V Electric Dryer. Makes a
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
Mar 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is making a loud noise when running. Sounds like it is coming from belt pully area.
your idler pulley near the motor area is bad,it keeps tension on the belt,usually either a spring steel rod or a bracket with a nylon pulley attached on the end
Mar 02, 2010 | GE DBSR453EBWW Electric Dryer
Dryer squeal @ start up; access
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
It sounds as if you have a dry rear drum roller. Check the above link first for parts and teardown.
You can also obtain more appliance information at my website, www.homemanagement.services.officelive.com
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Aug 27, 2009 | Maytag Dryers
Noisy dryer......when engaged...making squeaking/squealing noise.
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 09, 2009 | GE Spacemaker Washer and Dryer Electric...
When our dryer is turned on it has a very high pitched noise as if some metal is rubbing on the drum. It is model number DBXR453GVOWW.
It's noisy If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Mar 07, 2009 | GE Dryers
Dryers Logo
921 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
