Question about Kodak EasyShare Z740 Digital Camera
Z740 camera repeatedly formating memory card
Z740 camera repeatedly says memory card needs to be formated even after formated. I've even tryed buying a new memory card and it still says it needs to be formated. I have used the internal memory just fine.
    Genius:
  • 1,234 Answers
Hello Dear
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    An unused memory card inserted into the kodak z740 says memory card needs formatted
    May be you inserted a memory card formatted with your PC or has some errors.
    In any case, use the 'Format' function in the camera menu. (I guess you will be able to find it if you browse thru the menus). This will enable the memory card to be used with the camera.
    Sep 19, 2011 | Kodak EasyShare Z740 Digital Camera
    My Z740 won't format my 8G memory card. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message. Rich
    The Z740 works with MMC and SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
    Feb 14, 2011 | Kodak EasyShare Z740 Digital Camera
    When i put a new memory card in, the camera reads "memory card needs formatting", but when i click format, it does nothing
    While some Easyshare cameras will use SDHC cards, the documentation for the Z740 states that it uses MMC and SD cards.
    Try using an SD card. If that works, then stay with SD cards. If that doesn't, then there's something else wrong.
    Sep 04, 2010 | Kodak EasyShare Z740 Digital Camera
    I purchased a new memory card (sandisk sdhc ) it will not format?
    Get a new camera :-)
    Seriously, the Z740 is designed to work with SD cards, not SDHC cards. While SDHC cards will fit into the camera, they will not work. You need to buy SD cards 2GB and smaller.
    Jul 26, 2010 | Kodak EasyShare Z740 Digital Camera
    Kodak Easy Share z740 won't format Kodak Memory
    1. Insert the memory card into the camera. Make sure the card is firmly seated (push in the card until it clicks into place).
    2. Turn on the camera.
    3. Press the Menu button, then go to the Setup Menu.
    4. Scroll up or down to the Format option, then press the OK button.
    5. Follow the prompts to format the memory card.
    Retrieved from www.kodak.com.
    Mar 29, 2010 | Cameras
    Hi there , after formate if you face the same problem then, its look like the memory card life is end. He complete his total image serial number. For example:
    Life time card capacity is DSC 00000 to DSC49999.
    If he reach on end then he does not have any serioul no for further photos. In that case you need to replace the card. Thanks.
    Mar 20, 2010 | Kodak EasyShare Z740 Digital Camera
    I have a 512 memory card and it states needs formating but wont actually format. Its just repeating itself saying needs formatting. Its saying it when i put the SD card into my camera and my pc. Can i fix...
    # Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
    # 2 Open up 'My Computer'. You should see it under the list of available drives.
    # 3 Check its contents first to make sure that you have the right drive.
    # 4 In 'My Computer', right-click on the drive and choose 'Format'.
    # 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
    # 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
    Sep 18, 2009 | Kodak EasyShare Z740 Digital Camera
    My Z740 won't format my memory card. When I turn
    My Z740 won't format my memory card. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message.
    Aug 15, 2009 | Kodak EasyShare Z740 Digital Camera
    Format card error
    Some of those cameras and cards are extremely sensitive. I would try to find another memory card and try that. You can also try to format in another camera or a computer.
    May 05, 2009 | Kodak EasyShare Z740 Digital Camera
    Memory Card Formatting for Z740 - max memory?
    Take the card back bad card. You can use a 512 card or better.
    Dec 21, 2008 | Kodak EasyShare Z740 Digital Camera
    Kodak EasyShare Z740 Digital Camera Logo
    119 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Greg Cann
    Greg Cann
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
