Question about Sony VO-5850 VCR
Tape Playback When I insert a tape, it begins to load but the does not quite complete threading and instead of the Play button lighting up,  the F FWD button illuminates.  After a few seconds the process quits.
  • kevinmon Apr 02, 2008
    It was a belt.  But after replacing the belt, and using the unit for
    a few minutes with no problems, after the last tape ejection, all the
    lights went out on the unit like it lost power but there was still power, both AC and DC and no blown fuses that I could find.  I eventually gave up and found a Sony VO 9600 in great shape on Ebay for very little.  You can't give these things away now.
  • 180 Answers
Check the end sensor
Posted on Mar 31, 2008
How to dub tape to tape
Hi Dale,
You're kind of light on details of the equipment you're going to use - so the best I can do is provide generic instructions. You'll need two devices - one must be able to perform playback for source media and the other for recording or copying duties. Inspect the jacks provided on the rear of both units. Most provide standard RCA type "Phono" jacks for left and right audio channels. Connect a stereo patch cable (with plugs that match the jacks of the playback and recording devices) between the left and right OUTPUT (or "PLAY") jacks on the source device and the left and right INPUT (or "RECORD") jacks on the recording device. Insert the source tape, cd, album, etc. in the device that will playback the original and insert a high quality blank media into the device that will provide recording capabilities. Begin playing the source. Set options such as tape bias, Dolby Noise Reduction, etc. on both source and recording devices to match media in each. Advance the playback source to a point that contain the loudest sections. Set recoding levels by monitoring the VU meters on the recoding device and vary the input adjustment levels so that only the loudest prortions of the program just begin to briefly "flirt" with the 0Db or red zone of the meter. Signals that cause the meter to indicate into this area and beyond begin to overload the amount of information that can be recorded on the blank media and often result in muddy audio quality during playback, later. You should also record the same section repeatedly with differnt options (bias, noise reduction, etc.) to actually hear the difference to determine which sounds best to you. Once levels are set, queue the playback device and start recording. In the case of tape, allow enough recording time to let the leader section of the tape to pass beyond the recording heads for several seconds or more. Once the desired amount of silence has elapsed, play the source program. Allow it to run to completion using both sides in the case of tape and then playback the entire new recording to make sure it recorded without any issues.
Apr 09, 2015 | Televison & Video
Tip
How to Safely Clean a Tape Video Head
If you are not getting video from a VCR, 8MM camcorder, or Digital Video recorder camcorder but get audio, do the following: <br /> 1. Use a brand new tape - right out of the package and insert it into the drive. <br /> 2. Perform a record on the tape - set it to do a RECORD (not playback). <br /> 3. Allow it to complete through the entire tape without stopping. <br /> 4. Upon completion - allow it to rewind. <br /> 5. Insert a known good prerecorded tape and play - observe the image. If it's good, then the head was just dirty and is now clean. <br /> You may perform the above as often as necessary without any damage to the device.
on Dec 13, 2010 | Televison & Video
WHEN INSERT THE VHS TAPE TO VCR IT EJECTS BACK... WHAT MAY BE THE PROBLEM?
Hi, depending on the age, chances r that some components r worn out or the eye sensor needs cleaning or sdjusting.....
Jun 21, 2014 | Panasonic Televison & Video
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
  1. Stop the tape.
  3. Play the tape.
  7. Play the tape.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
Tape hanging up and will not record.
There is a threading arm that has gummed up inside the unit. I suspect that the tape is not being loaded correctly. This is a common problem with the Sony units and requires the removal of that loading arm to remove gummed up grease. Once that is completed, the unit will function correctly. Please note that the height of this swing arm is critical to the correct loading of the tape. I would not suggest you attempt this repair because the tape height adjustment needs to be exact. A local shop should be able to resolve this for you with NO parts required.
Dan
Mar 11, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Has power but wont play,rwd, fwd
retime the gears and check power supply
Aug 05, 2008 | RCA VR349 VHS VCR
8mm Tape stops when rewinding
try this:
some cameras have a memory where they begin make sure the memory is off or cleared then try to rewind or try fwd to end clear memory then rewind tape...
now sometime tapes of 120 are really not recommended because of the load of tape amd ost have a tension sensor 60m is usually the best recommended
Jan 04, 2008 | Sony P6-120MP 8mm Tape
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Cassette loading process won't complete
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. If you're NOT still under warrantee you should at least open the VCR and Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY.
Dec 28, 2005 | Panasonic PV-V4021 S-VHS VCR
Televison & Video Logo
129 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
