I'm trying to find a solution for my aunt's laptop. It is a Toshiba Satellite A205-xxxxx. She's having the exact same problem as a couple of other users that posted to this site. The tag for their post is:laptop lcd color palette inverted constantly....from boot to windows with the exception that I didn't replace the lcd. The display is constantly washing out to the point where it looks like you're looking at a film negative or a monochrome image. From what I read there wasn't really a definitive conclusion to this problem. From what I researched this seem to be a common problem with Toshiba Satellite laptops...including no solution. I have taken this laptop apart to check for the loose connections or anything out of place. There was nothing that stuck out. I was going to get a new inverter since that seemed to be the most common cheapest fix for the Satellite models but thought I saw something here that said that couldn't be the problem since it only powers the backlight. Since this laptop
I had the same problem with a Toshiba A105 laptop and was able to fix it. Up front, I have to say that:
1) You shouldn't try this unless you have some expertise in fixing electronics and are comfortable disassembling laptops. Especially since it involves working with the LCD inverter board which provides high voltage to the fluorescent backlight tube.
2) Though the symptoms may seem similar, your problem may not be what I found. So keep that in mind.
Just before LCD went into negative image mode, I had noticed a few times when the screen would seem to darken intermittently, I thought maybe the power cord was loose and the system was falling into a power save mode but now I think this was the warning sign.
When the failure occurred it was immediate and never recovered. At the time, I thought the backlight had crapped out. But after disassembling the lid and re-powering I could see the backlight shining from the back of the LCD assembly. I then checked for loose wires and cabling connections with no luck. Finally, since the inverter was covered by a thin plastic cover, I started pressing lightly on parts of the inverter board for bad solder joints and cracked traces. Bingo! I was able get the screen back by pressing on an SMT potentiometer with the reference designator VR1. I threw an ohmmeter across the outside leads and found it was 10K but the measurement from one side to the wiper was only about 500 ohms. I tried to de-solder the pot but it cracked and broke during the effort - very fragile. Since I didn't have a matching part, I replaced it temporarily with a 10K 10-turn through-hole part just to find a good setting. I went with about 1200 ohms by turning and eyeballing the contrast of the screen, though it was pretty subtle. I removed the pot and substituted two 0604 chip resistors to match the pot setting. Powered back up and it works like a champ. Though, as I said before, your mileage may differ.
Posted on Oct 02, 2010
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
Cant find CD key for toshiba satellite A130 /A135 . how do i get key?
I think you mean the key to access windows vista home basic. The key should be located on the back of you laptop near some bar codes it should be 25 caracters long like XXXXX-XXXXX-XXXXX-XXXXX-XXXXX.
OR
You can be sneaky:
Download a nifty program called the "ProductKeyFinder" it should be free. Run it on your friend's computer with the EXACT SAME operating system and and copy down his key. If you get in trouble that's too bad.
Aug 14, 2010 | Toshiba Satellite A130 A135 Notebook
Satellite a205 died. will not power up at all. 2
Go to the Toshiba web site. They often extend the warranty on laptops with common problems.
Jan 09, 2010 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Jul 30, 2009 | Toshiba Satellite A205-S4617 Notebook
Have no lan drivers
Hi there!
Drivers for the Toshiba Satellite A205-S4617 are available from Toshiba here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1700051&rpn=PSAF0U&modelFilter=A205-S4617&selCategory=3&selFamily=1073768663&selModel=1700051|PSAF0U#
If this is not your model, then please specify your exact model number and I will try to find you the appropriate drivers.
Feb 17, 2009 | Toshiba Satellite A205-S4617 Notebook
Need The drivers for Toshiba satellite A205-s5804
Try here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1909174&rpn=PSAF3U&modelFilter=A205-S5804&selCategory=3&selFamily=1073768663&selModel=1909174|PSAF3U
Feb 06, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba satellite a205 s5825 memory upgrade
what my audio setting suppose to set to step by step on my Toshiba satellite A205-S5880
Jan 29, 2009 | Toshiba Satellite A205-S4617 Notebook
Spilled milk onto keyboard of toshiba satellite A205-S5800
Well ..Spilling anything on a laptop or any computer component is always a no-no situation. I couldn't tell you what you may have "broke" but I highly doubt that it was just a "fuse"
Nov 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Jul 26, 2008 | Toshiba Satellite A205-S4617 Notebook
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
