I have loss connection to my laptop I had it then the power went out and now I can not remember how to connect it again-thanks
    Guru:
  • 523 Answers
Hi Friend,
Please follow the below steps,
1.Please turn on the Wireless switch in the Laptop
2.Try to search for Wireless network in the range
3.Connect to your network,if you have any Security key,it will prompt you to type.
4.After giving it,click on connect.
5.After connecting,please check your internet connection
Regards,
Aysaam
Posted on May 14, 2010
My X box 360 4 GB slim console from USA when connected to 230 V through 220-110 power converter,ELCB got tripped and was showing red light in power supply unit and finally light went off. After that when...
dude i think your power supply burnt out... yes its better if you buy new power supply but remember to check the wattage of your power supply... you must buy the same wattage because if you buy below the wattage there will be a tendency that the power supply will be burnt again... tnx dude please rate me if you think it help thanks...
Jun 04, 2011 | Microsoft Xbox 360 Console
My HP laptop lost power (not because of its fault) and now I can not aquire an IP address via either of my wireless cards or the RJ45. Comand prompt inquiry shows 0.0.0... and ipconfig/renew gives an error...
Try theses options: ( turn off and on the power of your router / restart your laptop ) - to refresh all. See also if other computer and laptop can connect to the internet thru the same router just to isolate.
1. use your wired connection first ( rj45 ). Unplug and replug both ends of the cable from the router and from your laptop. Restart your computer. Then check if its ok.
2. Try to do a loop back test to check if your network card and the tcp/ip is working properly. To do a loop back test, go to command prompt and just type " ping 127.0.0.1 " and press enter. It should reply and should tell you 0% loss. If there's an error then disable and enable your LAN ( Local Area Connection ).
3. Do " flush dns". Go to command prompt again, then type " ipconfig /flushdns" then press enter.
Nov 13, 2010 | Computers & Internet
My Toshiba Tecra M4 losses power and switchs off.
first to do is check the HDD RAM,or the wireless card,,
Jun 25, 2010 | Toshiba Satellite M35X-S149 Notebook
Acer laptop will not turn on.
You must now assemble it again by taking out components carefully and fix it properly it is due to lose connection in your laptop
thanks
May 15, 2010 | Computers & Internet
try reseating everything from the memory, hdd to the cables of all the devices connected to the mobo. it should work since you alredy have a new mobo. also try to hook an external monitor it may be an lcd issue.
Mar 30, 2010 | Computers & Internet
Loss of connection. Recently wireless connection has repeadedly failed between the master PC and laptops. The red internet light on the 2 wire router comes on a few minutes later connection restores Lap...
I went into Tool in internet explorer and made sure that the SSL and TSL buttons were all ticked. I also checked my firewall to make sure that the firewall recognised and accepted the entire network.
It also seems that when the laptops went online to Spotify the firewall prevented a connection.
Not quite got that bit sorted but all seems ok now so long as no one tries to connect to Spotify
Jan 04, 2010 | 2wire Computers & Internet
My HP Pavillion dv9000z eon't boot after the screen went blank.
Ttry disconnecting the power. Remove the battery for a couple of minutes and then try again.
Jul 20, 2009 | HP Pavilion dv9700t Notebook PC
Toshiba Satellite M105-S1021 not getting AC power to it.
My toshiba had a bad internal power socket and I went through the same steps that you did. I also replaced the battery. So now I have two batteries and two power supplies and had to pay to have the computer shop put in the internal socket that the power supply plugs into. Hope this helps
May 25, 2009 | Toshiba Satellite M105-S1021 Notebook
Compaq n800c pp2130
When you connect the power adaptor to the mains and to the laptop and when you turn on the main s the power light should normally glow or else the adaptor id faulty. Try removing the laptop battery and plug it again as sometimes due to jerks there is a loose connection .
Sep 24, 2007 | Compaq Evo N800c Notebook
Computers & Internet Logo
David Payne
David Payne
