I sent a fax message a few days past (manually) and do not know what happened. Firstly, I had installed the FAX system as an option when purchased. What I do know is everytime I turn on the machine - I thought as a re-boot of sort, it is trying to fax a document - like redial. What I really REALLY want is to permanently disable this feature. I want to send a fax, and if does not go thru, then I, and I alone will re-fax. No redial. First, please tell me how to turn off the [blanking] fax machine from trying to send this document and then how to permanently disable this annoying (to me anyway) feature. Many thanks in advance.
Open the left fax display cover. Find and hold down the "Alternate Display" key. While holding it down, press the "Stop/Clear" key. The transmission will be cancelled.
Automatic re-dialing is preformed by this machine unless you are in the direct transmission mode.
To set the default to direct transmission:
Press the "System/Menu" key,arrow down to "Fax Default".
Press the "Enter" key. Arrow down to "TX/Default".
Press the "Enter" key. Arrow down to "Direct Feed Transmission" and press the "Enter" key.
When you are finished, press "Reset".
Was this helpful?
Yes
No
Popular Solutions for Kyocera Mita KM-2050 Printer
instead of just hanging up the engage tone drags on for about 4 minutes before it hangs up, how do I...
(More)
instead of just hanging up the engage tone drags on for about 4 minutes before it hangs up, how do I reduce this
Ofter long delay only blank paper printing with code @ PJL SET TIMEOUT = 300, need your urgent...
(More)
Ofter long delay only blank paper printing with code @ PJL SET TIMEOUT = 300, need your urgent help!!
