Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Toshiba lcd tv just stopped working
And now the power won't even come on.
2 Suggested Answers
SOURCE: my toshiba 40e210u lcd tv won't show full image on screen
The Aspect ratio of the TV could be on the wrong setting for the image you are trying to view. Widescreen's standard ratio is 16:9 ensure the TV is not set to zoom, 4:3, or pan & scan in the picture menu of your TV.
If the picture looks normal except it's just missing the edges or looks squashed or looks like it is zoomed in from the normal image then aspect ratio is probably the cause.
Posted on Aug 03, 2012
Tv stops responding to remote after 10 minutes
I have same issue and not just remote even controls on tv do not work. Eventually hitting power button will turn it off then I can turn on and have functions for 3-10 minutes. Wish someone had a solution
Nov 23, 2012 | Toshiba 46SL417U LCD TV
Toshiba 20vl14 power loss
problem with power supply ask technician check it...
May 04, 2008 | Toshiba 20VL14 20 in. EDTV-Ready LCD...
Blank screen when powing on, won't start.
Toshiba laptop LCD screen. It is to provide you with high quality laptop inverter replacement. The design of the Toshiba laptop LCD screen is 100% compatible with the Toshiba digital or model manufacturers.
Product Features:
1. Model: Toshiba laptop LCD screen
2. Each test notebook computer LCD screen before shipment, 100% of the working conditions:
3.100% new high quality replacement Toshiba laptop LCD screen
4. Toshiba inverter can be used for the other models and Inverter part No
5. Toshiba the notebook LCD InverterDefective backlight inverter can have the following symptoms:
Screen image, but the power light stays in
Dark display, but still readable
Flashing on and off of the screen between 1/2 to several seconds
The power indicator stays on, but no display and sound
Screen images, but LCD TV still has sound
Picture cycle on and off, as well as high-power LED lights
In good working condition. The best match for your device. High-quality, durable, easy to install. http://www.lcdinverters.net/Laptop-Inverter/Toshiba/Toshiba.html
Nov 01, 2012 | Toshiba Computers & Internet
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
Toshiba 32AV502R won't turn on even though green light goes on
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Toshiba 32AV502R LCD TV
Apart from the on-off button none of the panel or remote controls are working on my Toshiba 20wl56b t.v
I think problem is from the control board. The board works with the TV buttons and that's where the remote sensor is. If the board is defective or dead, the buttons won't work and the remote won't work as well.
I hope the above is clear.
Good luck.
Jan 05, 2012 | Toshiba 37WLC48 LCD Television
I have a Toshiba 26AV502R tv, was working yesterday and now it won't turn on? It's about a year old. What do I do to fix this?
the only thing you can try to do: unplug TV, let it "reset" for a minute or so, then plug it back in. If that won't help, means: surrender to repair service. for 1 year, even with 24/7 usage, there is a slim chance for "bloated" capacitors inside of TV's power supply, but quite a good chance of your main board failure. Now a days they quite compact, packed with high temperature producing IC chips, led-free solder, which has drawback of "fatigue" failure. Or, there might be power surge involved. In any case, except "lock up", appeal to TV repair service.
good luck,
Alex's Television,
215-806-5980.
Jul 16, 2011 | Toshiba 26AV502R 26 in. LCD HDTV
Toshiba regza 46rv530u will not turn on
Check the ac fuse. In a couple of cases because of a power surge the fuse opens up.
After replacing, the sets have worked normally.
Jun 17, 2009 | Toshiba REGZA 46RV530U LCD TV
I have Zenith projection TV 60" model# 1QB60M90W-1, Serial#071-25350934, when pluged up all TV does is roll from one station to another no sound only thing that works is the on and off switch. When...
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Abctay com China Wholesale Wholesale Electronics Gadgets tv parts power...
Oct 16, 2017 | Televison & Video
42hl67
I had lcd 42" over a year it is working find before , but now it has very dark picture
can y help me to find out what is a problem and how much to fix?
May 01, 2008 | Toshiba 42HL67 42 in. LCD Television
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
