Question about VeriFone PINPad 1000SE Network Terminal
Getting error No d key
Lately I've been always getting the following error "10086 - Error Invalid Number......."
your number input is wrong or maybe you have a key pad error.CONTACT SAMSUNG TECHNICAL
Sep 14, 2015 | Samsung Glaxy SII i777
Error e001
E001 error is the generic Wrong Mode error message on the Casio tills.
It simply means that a transaction was started in one mode without being finished before the key was turned to a different.
Return the key to the mode you were in before, complete the transaction then try turning the key.
If you keep getting the error turn the X and press SBTL.
Thanks,
Shopstuff
May 19, 2014 | Casio Parts Cash Register PC Desktop
Geller sx-580 key op error
WHEN Z READING KEY OP EROR COME UP
Aug 06, 2012 | Computers & Internet
I am getting an error mesage on my hp c7250 oxc05d1381
Press and hold the '*' key on the key pad, then press the '#' key and release them both. Then enter '123' to enter maintenance mode. Press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then press OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
I hope this will help
Jan 26, 2012 | HP Photosmart C7250 All-In-One Thermal...
I am getting an error " Default key corrupt or
you go in system setting and go for network setting option and make the setting key off. this message will go off.
Jul 18, 2011 | Canon ImageRunner C-3170I Copier
Getting error E000001-0010 on canon IR5055 network printer. How can resolve this issue ?
This is a fixing error - Temperature is not getting to the correct temp soon enough. Most likely a simple reset of the copier will work. You have to get into service mode first. Press the additional function key, then press the 2 & 8 keys at the same time, then the additional function key again. Then copier, function, clear, err, then OK. This clears the error code from the copier. Then power cycle the copier and the copier should be operational. If this doesn't work then you will have to have a technician fix it. Good luck.
Dec 08, 2010 | Canon imageRUNNER 5570 Copier
Getting H3 error message Sharp AL 1631 copier
H3 is a heater/fuser problem. Try to reset it by SIM 14. Press Clear , auto exposure, Clear and auto exposure and press copy key. check if H3 has been reset and LED is back to "00".
Oct 29, 2009 | Sharp AL 1631 Copier
Check Printer and Press resume key message along with Alarm light
Too many things can cause that, paper jams, carriage errors, printhead problems, purge assembly errors, feed roller errors, need more info to be of any help.
Aug 12, 2009 | Canon MultiPASS F80 All-In-One InkJet...
I keep getting error messages when entering my product key number.
Please mention about the message you are getting. And what product key you are typing ? The product key that you are entering may be wrong or its outdated. If yo can tell that product name then i would give you the exact product key. Thank you....
Sep 12, 2008 | Gateway Computers & Internet
VeriFone PINPad 1000SE Network Terminal Logo
286 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
