Question about Plumbing
We have a single lever mono bath shower mixer PN321 (hudson reed). It is leaking around the ball joint where the tap lever is. When the lever is pulled out for put the tap on some water drips out from the joint. Can this be resolved? Janet
Our bath taps which are a mixer with shower attachment stay really hot if you put the hot on first or really cold if you put the cold on first any idea how to adjust so we can have warm water when turning...
you make no sense. From the picture the water "mixer" is the center lever or is it a diverter valve for the shower and water nozzle below???
The knobs are for hot and cold water??
Jun 08, 2014 | Plumbing
Can't regulate a delta shower.
If you have the type that you turn the handle like a clock, you have to find that perfect spot. It can be 3/4 of the way around. If you have the ball type, single lever, the rubber seats and springs under the ball should be replaced. Cost...less than $10 for the kit to do yourself.
Dec 04, 2012 | Delta & Single Handle Shower Faucet
I have a hudson reed Twin Concealed Thermostatic Shower Valve. It was working fine for a couple of years. My brother used the shower and adjusted the water temperature valve but since then the water has...
Sounds to me the diffusor is stuck or broken in the position to allow only hot water through it.Looks to me tou have a mixer valve on it. Might have to replace it.
May 31, 2011 | Hudson Reed Home
PLUMBING>FITTING FLEXI TAP CONNECTORS TO BATH
NO PROBLEM USING FLEXIBLE HOSES. JUST ENSURE THEY ARE NOT KINKED WHEN INSTALLING
Oct 13, 2009 | Home
My Hudson Reed lift and turn mono block tap leak
There should be a retaining ring right under the handle when removed. The stem of the ball runs up through the middle. Tighten this retaining ring and it should stop the leak.
Mar 21, 2009 | Hudson Reed Traditional 6 piece bathroom...
Plumbing Logo
81 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
