Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Refrigerator defrosted and will not come back model gss22QGPE cc
  • Anonymous Dec 19, 2008
    G.E. model GSS22JFPA CC Refrigerator does not get cold. Freezer
    does freeze.
  • robert samples May 11, 2010
    whats the brand and is the compressor running and is the light in the fridge working
My freezer keeps freezing until it gets stocked then It shots down and will not regulate. I have to unplug it for a few hours and replug it... what to do?
Posted on Nov 28, 2008
  • 109 Answers
Check defrost timer is not stuck in defrost position
Posted on Mar 30, 2008
GE GSS20IEP CC is freezing up after we replaced the defrost heater and the thermostat. what else could it be?
you have a bad computer board located on the back outside wall,part number wr55x10942.everything runs through the board,sometimes you'll notice that the fans aren't running correctly too.unplug the machine,remove the cover,you'll need a pair of needlenose plyers,there are 4 white plastic pins that hold the board in place,pich in the tab on the pin and pull on the corner of the board,pull off the wire harnesses and plug them back in the same connectors then ground it with one of the screws.go here 801 is your part and this is your problem
Sep 02, 2012 | GE GSS20IEP Side by Side Refrigerator
Model # GSH22VGPC CC water leak
Evaporator condensate should go to pan for evaporation. If the amount exceeds pan capacity during defrost cycle it could overflow to the floor.
Sep 03, 2017 | GE Refrigerators
My refer/freezer model ET14CC upright top freezer14.3 cu.ft. cycle defrost model no longer defrosts. I need a manual, parts list, part number, diagram, something to get started troubleshooting it.
ok if you have a multimeter you would set the multimeter to measure continuity you would then remove the rear panel in the freezer defrost any ice build up with a hair dryer and then you would look at the defrost thermostat the deforst heater and the defrost timer most of the time this is due to the defrost thermostat going bad you can also see how your defrost cycle works in your unit by clicking here and as far as looking up the parts this model number you gave is not complete so you would get the complete number and click on this site which would bring up the entire schematic for your machine i left the look up on the page where you would pick which model is yours according to your exact model number if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
p.s all the defrost pieces should have a continuity test done to them and which ever fails is the one that you would replace
Apr 21, 2011 | Refrigerators
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 26, 2010 | Refrigerators
My g e frig is not defrosting mod gss22wgmc cc i check out relay heater replace board still ice up
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Aug 24, 2010 | GE Refrigerators
I have a side-by-side refrigerator model #
This is an auotmatic defrost system. If you have severe frost build up on the back of the freezer wall you have a defrost problem. Either defrost timer, Defrost terminator (t-sat) or defrost heater.
Jan 27, 2010 | Refrigerators
Freezer stays cold, but the fridge side does not
A small amount of frost on the back usually means lots more behind it on the evaporator coil indicating a defrost problem. check defrost heater, defrost thermostat.
If the heater and thermostat are ok it’ll be the motherboard.
How to check everything
Part 801 on this diagram is your motherboard.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling, frosting up
You might try GE customer service and ask where to locate the defrost timer,since that sounds like your problem.
Nov 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
A common problem with these refrigerators is a faulty defrost heater. When the defrost heater fails ice will accumulate on the condenser coils located inside the freezer compartment of the refrigerator. Typical symptoms are frost appearing on the back wall of the freezer compartment, little or no ice being made by the ice maker, and above normal temperatures in the freezer compartment. The defrost heater should be replaced by a qualified repair person. The part itself is not particularly expensive.
Aug 04, 2007 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
