Question about NEC ND 1100 (50022667) DVD+RW Burner
Need the switch setting for connection as slave
Need the switch setting for connection of a nec ND-1100A as slave
    Problem Solver:
  • 6 Answers
On the back of the drive is a set of six pins.
There will be writing above or below these pins it will be (cs),(sl)(ma).
There should be a cap on two of these pins make sure you put them on the two pins marked (sl) slave. If you are connecting this along with another
drive make sure the other drive is set to (ma) master.
Posted on May 16, 2010
Jumper setting in cpu
Not sure what the CPU has to do with anything! The following might help with CD/DVD drive jumper settings:
http://www.computershopper.com/storage/howto/installing-a-new-dvd-burner4
Jan 03, 2014 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Will not read any dvd
make sure the CD or DVD media you isnert is compatible for read/write opeartions
this DVD/RW is 12x40 trasnfer (rate read) and 4x16 write +RW
what format or speed CD media are you inserting ? go to this link to give you a better look at the specs of this NEC product you have
http://support.necam.com/optical/specs/nd-1100a.pdf
if this helped you , please rate me
Nov 03, 2010 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
The first selection is for "master" the second will be for slave, and the third is an automatic selection done by the motherboard.
Mar 20, 2010 | NEC ND 1100 (50022667) DVD+RW Burner
What is the jumper setting as slave?
All drives are different, you have to look on your drive for the pin config
Nov 07, 2009 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
XP can't find ND-1100A drive
Thanks for coming to FixYa, The problem you have is either a well documented software problem or a failing drive.
Click the below link, then scroll down and click the "Fix It" button. Follow the onscreen instructions, restart when it's done and see if your drive re-appears. If it does, you're done, if it doesn't work then your drive is most likely failed and you should replace it.
www.microsoft.com/kb/341060/
Hope this helps FixYa,
Chris
Jul 11, 2009 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Drive will not stay closed
mechanical problem, switches. hard to repair and you dont get the parts for that
May 03, 2008 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
NEC DVD+RW ND-1100A
This is a single layer drive only. Usually dual layer drives have DL in the form factor so possibly a
NEC DVD+RW DL?
http://www.adamant.com/itemInfo.asp?GotoID=ITEM&PrdAbr=CDVN-3540A&menu=PARTS
Oct 24, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Nec dvd + rw nd-1100a
first try a audio CD see if ti reads that fine. then inset a data CD and see if you can see all the files on it. Try a few data and audio CD's. If it has trouble with any of these your drive has gone to the great garbage dump in the sky.
Jun 28, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
NEC ND 1100 (50022667) DVD+RW Burner Logo
71 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
