How to thread the bobbin on an Elna 3005. I have lost the instruction book. (Your category does not include sewing machines)
    President:
  • 2,651 Answers
Http://www.2instructions.com/search.php?cmarque=ELNA&modele=3005
heres a that looks like theyt will get a manual for you
Posted on Mar 30, 2008
  • 19,396 Answers
This are the instructions from Wiki for Elna 1500, which is a similar model:
" First, raise the presser foot lever and turn the flywheel towards you to raise the thread take-up lever to its highest point.
Next,, place your spool of thread on the horizontal post and hold in place with the spool cap. You know that little nick in the spool where you tuck your thread so the spool won't unravel? Make sure that nick is pointing to the right.
Now draw your thread to the left and "click" it into the little silver loop. A 1" oval thread guide sits to the left of that silver loop; draw your thread around the left of the thread guide.
Now you're going to loop your thread through the tension discs. You'll see two "cracks" in your machine. First run your thread DOWN through the RIGHT crack, then immediately UP through the LEFT crack.
At the top of the LEFT crack is your silver thread take-up lever. This is probably the trickiest part of threading your machine because the lever is always kind of inside the machine. But you can do it! Pass your thread from RIGHT to LEFT through the back of the loop at the top of the silver lever.
Whew! We're almost there.
Now draw your thread right back down the same crack you pulled it up before. You now have two stationary guides above your needle. Pass it through the thick silver guide and then through the thin silver guide. Both of these moves are kind of a left-to-right motion.
Now thread your needle from FRONT to BACK.
You're done -- well, except for the bobbin.
Hold your bobbin spool above the bobbin case so that it looks like a letter "P" Draw the bobblin thread from RIGHT to LEFT through the small crack in the silver part of the bobbin case, then pull the thread straight toward the back of the machine.
Now turn your flywheel one revolution toward you so that your upper thread picks up the bobbin thread. Now close your bobbin cover, and SEW!
Congratulations! You did it!
  • Ginko
    Ginko Mar 30, 2008
    I did not find Elna 3005 in the model list , are you sure of the model?
SOURCE:
How do i thread Elna 1200 also bobbin placement.
You should probably find an owners manual. Search for:
Make Model manual
(however, Elna manuals are seldom free)
IMPORTANT TIPS:
ALWAYS RAISE the presser foot when threading the top thread! Install a brand new needle at least every 8 hrs of sewing or whenever it strikes something. AVOID old and bargain bin threads.
How To Thread An Old Elna Sewing Machine
Elna Threading Instructions
Nov 17, 2017 | Elna Sewing Machines
How do you adjust the tension control on an Elna lotus SP
The tension dial is on the front of the machine right above the needle. The higher the number, the tighter the tension is applied to the top thread. HINT: When threading the top thread, ALWAYS RAISE the presser foot throughout the entire threading process. This allows the thread to seat completely in the tension disk. Tension is correct when the top and bobbin threads meet in the middle of the fabric.
Elna Lotus Instruction Booklet
Elna Lotus SP bobbin case repair Removing cotton jam from Elna Sewing...
Elna SP ST SU sewing machine repair tips (I use liquid Tri-Flow Synthetic Lube or silicone spray to loosen parts seized from old oil. Do NOT use WD-40, cooking oil, motor oil...)
Apr 29, 2017 | Elna Sewing Machines
What bobbin for elna 3005?
check with sewingpartsonline.com for the bobbins
Jan 20, 2012 | Elna Sewing Machines
I have mislaid the instructions for my Elnita 140. In particular, I need to find the instructions for threading, including the little bobbin that goes underneath!
This is a machine made under licence for Elna back in the 80's I believe. So should be a bobbin inside a bobbin case mounted vertically. Try this link for threading up, it should be very similar.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Elna_Sewing_machine_threading/Elna_225_threading_diagram.htm
Many machines have this bobbin case design and they all work much the same way, you need to place the bobbin into the bobbin case with it turning the right direction, click the thread into the tension spring on the outside of the bobbin case then latch it into the rotary hook of the machine, usually there is a little latch on the bobbin case that holds it in.
Top thread is usually fairly obvious, from the spool through an eyelet, through the take up lever, through a tension device, then down to the needle.
Always thread up with the pressure foot raised as this opens up the tension device and allows the thread to seat in correctly.
You can probably buy a manual for your machine from either sewusa.com or www.sewingpartsonline.com or "sewing machine relics" websites. Or just search ebay, there are several vendors who sell pdf copies of different manuals there.
I hope this helps you get sewing with your Elnita, four thumbs up if so.
Aug 21, 2011 | Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Having thread breakage probelm and also can't track down the correct bobbin to use on the Elna 2005
have you got the manual for this machine? You can download one from here: http://www.ps2netdrivers.net/manual/elna.2005/
It is a front loading bobbin and removabel bobbin case so I think the bobbin is a plastic "Class 15" - like this http://www.sewingpartsonline.com/bobbins-class-15-plastic-10-pack.aspx
Thread breaking could be caused several factors such as the thread actually being old and brittle, the needle or needle plate having burrs and catching the thread, incorrect threading, bobbin in bobbin case the wrong way, or top tension discs playing up/too tight or thread catching somewhere in the threading path.
I'd suggest that you trouble shoot this and refer to the manual for cleaning instructions. If you can access them clean between the tension discs (turn tension down to zero and "floss" between the by running the selvage edge of a piece of clean cotton scrap through the discs to remove any lint/dye buildup). Wind a fresh bobbin and rethread referring to the manual to ensure the bobbin is turning the right way. New needle and rethread top thread refering to threading diagram. Tension on 5 and test sew again.
If you are still having problems, then the machine may benefit from a service by your local Elna dealer, a good service and clean at least every 2 years is recommended.
May 06, 2011 | Elna 2005 Mechanical Sewing Machine
Elna 3005, threaded correctly, won't sell,whats a coupling knob
it could be that the foot control has failed on it .
Feb 02, 2018 | Elna Sewing Machines
Open Questions:
AOL +MAil +TelePHoNe +{1-855*536*5666}#[email protected] NuMbER CONNECTICUT This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 19, 2019 | AOL Computers & Internet
Fujifilm Printer customer care number%%[+l^26O{0O64}}%%:~NumbER USA Wngots Fujifilm Printer WngLogin customer care Number +[185526O{0O64}]WngLogin Fujifilm Printer tech support number USA Repair service center to resolve all Fujifilm Printer tEcH SupPoRt pHoNe nUmBeR products. Fujifilm Printer is an American multinational company which was founded by Michael Fujifilm Printer using its company headquarters in Round Rock, United States of America. Contact Fujifilm Printer for Setup & Installation Fujifilm Printer Setup Free & Installation Fujifilm Printer TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Fujifilm Printer Connect, Fujifilm Printer TECH Free Phone Number you'll be searching out Fujifilm Printer Connect setup as well. So, here we're with all cthe setup process and for your to Fujifilm Printer Connect. Get Fujifilm Printer Setup Instant Free Fujifilm Printer TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Fujifilm Printer Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 19, 2019 | Carrier Computers & Internet
AOL MAil SuPPoRt+-***-+ {1-855*536*5666}#[email protected] +-*/*--+*--+*/*-IOWA This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Computers & Internet Logo
228 people viewed this question
Ekse
Alun Cox
