Question about Sansui VRDVD5000 DVD Recorder/VCR
Sansui San0218-250GB. Hello I hope you can help! this recorder has a red lit up area around the DVD button and it wont go away and the DVD will not respond to anything. I cant turn on off - only from power switch in wall. So it is non respondent to anything. and only has the circular red light on. Please help Kind regards Pamela
  • 1 more comment
  • roxiehart May 26, 2008
    I have a similar problem. The red recording light is on, and won't turn off. It won't respond to anything but turning it off at the wall. Then when I turn it back on it says 'HDD title damaged. recover it?' I can either recover or delete it. Either way though, the recording resumes and I can't turn it off again. When I go to the HDD menu, it looks as if it is recording, but the time elapsed is 00.00 and I cannot stop it from the menu either.
    Hope someone can help, this is driving me crazy!!
    thanks
  • jekabs Oct 24, 2008
    Jekabs. I have the same problem.The red light is on and the unit is nat responding. The unit is not respopnding to pressing the stand-by button for 100 seconds continuously. Error message says the DVD disc is at fault. To remove the disc is recommended, but the disc door is not opening. Ies there a mechanical interlock on thed isc drawer?
  • donkey_26 Dec 19, 2008
    can some one help me i got a sansui dvd recorder and i need a remote for it the model number is san0218-80gb
    Habit-Forming:
  • 31 Answers
I also experienced this problem as well as other intermittent error messages about hdd titles damaged etc.
Rather than send machine back for repair I opened it up and found a loose cable to the hard drive.(Must have come loose during transportation even though they appear to be glued in?)
I assume that because the machine can't fully "boot up" (like with a computer) it just stalls with the red light around the DVD button.
So if you are not confident in opening the machine up (unplugged from the wall of course) I would suggest taking it to a repair shop (if it is not still under warranty)..chances are it is the hard drive.
Hope this helps a few people.
Posted on Jun 22, 2009
  • 3 Answers
I had the same problem with my sansui san0218-160 dvd recorder. i found the power supply board inside the case had failed, so i replaced two faulty capacitors on the power supply board and reassembled the recorder, it`s working like new again. hope this may be of some help.
Posted on Mar 07, 2009
I've got the same model but what you are talking about is not a fault. It is a safeguard so you don't interrupt the recording accidentally. From memory, if you want to stop it recording, press and HOLD the stop button on the device (not the remote) until it responds. It takes a few seconds so be patient.
Good luck
Drew
Posted on Apr 26, 2008
I have a sansui tv and need the code can u help me
Hello
Three digit universal remote codes for Sansui are:-
135/ 136
Four digit universal remote code for Sansui are:-
0135 0310
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Feb 10, 2011 | Televison & Video
Code for universal sony remote sony-v201
Hello
Sorry to say that Sansui is not listed to Sony V201 remote control. Anyway I'll give you some three digit and four diit conds for Sansui. I'm not sure will it work, but try these, sometimes you may get.
135/ 136
Four digit universal remote code for Sansui TV/VCR combo is
0310
Four digit universal remote code for Sansui TV are:
0135 0310
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your combo with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
Hopes you will be helped.
OK.
Jan 27, 2011 | Sansui COM312AD 13" TV/VCR Combo
How do i use the code search on the ucr universal remote
Hello
Four digit universal remote code for Sansui TV/VCR/DVD combo are:-
0394 0967
Direct Code Entry
Ok
Jan 07, 2011 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
Nov 25, 2010 | Sansui Televison & Video
Wont work
hello,
the problem of this is from the power supply board of DVD player, try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 31, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Need users manual for Sansui VCR/ DVD Recorder Model VRDVD5000A
Hello there... I don't know if you have found already the one that's free but looks like you really need to buy its manual: Here. Hope this helps... :D
Oct 06, 2009 | Sansui Televison & Video
Dvd player/recorder wont work
I had the same problem with my sansui san0218-160 dvd recorder, i found a capacitor had failed on the power supply board, i replaced the capacitor and it now works perfectly.
Feb 20, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
SAN0901 Manual
again hope this helps!
i'll check back to see if you need more help
electech
Oct 22, 2008 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD-4000
this unit does not record dvds.
Feb 24, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Vcr to dvd recording
As i recall, +r's will only format in dvd vr, the unit does not like high speed recording disks. switch to dvd drive - insert blank disk - if no format screen - goto (on remote) setup - onscreen menu - system setup - disc setup - new disk format - hit center button in ring on remote to change to vr or move up to reformat as vr. once disk is formatted, use record speed button on remote to set record speed 1,2,4,6 hr then switch to tape deck with tape in and stopped at begining, on remote hit dubbing, it will ask you confirm dubbing vhs-dvd .... toggle over to yes & hit center button... away you should go... c245 is a copyguarded tape.
Oct 09, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD5000 DVD Recorder/VCR Logo
440 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
