Question about E-Machines emachines (emachinees) CD-ROM Drive
Cd brokes in cd rom
Cd rom doesnt open properly
This problem creat by your drive machanism, reassamble your drive.
Posted on May 15, 2010
I have an Acer Aspire 5332 and the CD-Rom/DVD Drive (Optiarc DVD RW AD-7580S ATA Device) is not working properly...every time I put a disk of any kind (i.e CD/DVD/Game) it doesnt recognize it and load
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Mar 22, 2012 | Acer Computers & Internet
DVD/CD will not open on my HP Pavllion s7000 what may cause this?
go to computer and try to right click on CD/DVD Rom and then select Eject there.. if this doesnt helps u then u would have to manually release the CD/DVD rom.. just below the tray there is a Small Hole .. use a Needle or any other device that may go in that hole.. try to press on eject button there.. and try to press using needle.. try doing so 3 - 4 times.. there is a latch that needs to be released to open the Tray..
this normally happens if the eject functionality of the tray is not functioning properly.. if ur computer is under warranty .. get the CD/DVD rom replaced.. let me know if this resolved ur issue regards, guru
Apr 20, 2010 | HP Computers & Internet
Cd brokes in cd rom
IS IT ON?...DOES CDROM HAVE POWER GETTING TO IT FROM PC? Next to open/close switch there is a small pin-hole. Push a paperclip into this hole and gently pull out tray...try gently pushing tray back in and watch for a blinking green light;if none either the cdrom is not getting power, or it has quit working
Mar 20, 2010 | E-Machines emachines (emachinees) CD-ROM...
I want my desktop to boot from cd. But in the boot priorities there is no option for CD-ROM. How can I make CD-ROM first boot priority?
If there is no cd rom, you need to check for it your bios detects your cd rom drive, and make sure you connect it properly.
If you are using IDE CD-ROM,make sure it doesnt conflict on your Master-Slave configuration. if you are using SATA CD-ROM make sure it connects properly to your SATA Ports, and also check if you have properly connect the power cable to your CD Drive.
Jan 05, 2010 | Computers & Internet
Internal samsung cd-rom sn-124 doesnt recognize cd's/wont work
replace it. samsung cd rom even its dvd writer have lots of problems. sometime they dont want to open unless you leave a cd in it. sometime it doesnt read cd. better change it. get a Sony, LG, Pioneer DVD writer.
Aug 20, 2009 | Computers & Internet
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
Cd rom doesnt work at all
hi if ur system is provided with two drives then u can use the second drive.. if not then u have to go for a change of new rom..since u said that ur light wont even flash it means that ir drive doesnt detect that particular rom and it has got damaged....
thank u rate me
Feb 09, 2009 | Sony VAIO PCV-RX462DS PC Desktop
A cd broke in my cd rom
I've seen and come across cd-roms where cd's have broken (or in most cases exploded/shattered). In one case the drive flew open and bits of cd flew across a classroom, in most cases the drive remains shut (even the tray can get jammed).
This problem is usually caused by a flaw on the cd itself, a scratch or mark on the cd causes it to 'wobble' and due to the speeds cd-roms spin cd's they come off the 'spindle' inside (all that holds it on is a magnet).
I have taken cd-roms apart and removed all the cd parts and the drive has worked perfectly afterwards. Other times the drive has needed to be replaced, so i would say its purely luck if your drive isn't damaged in some way.
Although the problem could have been your drive. Without being able to get the drive ejecting and spinning cd's again you'll never know... just make sure you don't use an important cd to test it with!
Dec 27, 2008 | E-Machines emachines (emachinees) CD-ROM...
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
restart the computer
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
Computers & Internet Logo
42 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
