Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
The paper i covered with ink totally black have tried two different toners
    President:
  • 3,085 Answers
The toner cartridge is the only possible failure. Try another one
Posted on May 14, 2010
I HAVE A EPSON TX110 MODEL PRINTER BUT I WANT TO CHANGE INK CARTIGE TO TONER INK. IT IS POSSIBLE OR NOT.
No. Inkjets printers use liquid ink that is sprayed onto the paper through nozzles. Toner-based equipment uses powered ink that is electrostatically attracted to a metal drum then transferred to the paper and heat fused to it. The processes are completely different and require totally different internal hardware to achieve.
Sep 01, 2016 | Epson Workforce 1100 InkJet Plotter...
I have a hl2040 laser printer and i have black verticle lines on the paper. i have cleened the corona wire by sliding the tab back and forth on trum cartridge. the toner cartridge is new. the printer was...
Remove the drum and toner from printer, turn printer off and find the glass scanner bar on the top of the inside of printer. Clean that with a paper towel and window cleaner. Wipe dry. DO NOT SPRAY INSIDE THE PRINTER. Only spray window cleaner on towel.
May 26, 2017 | Brother HL-2040 Laser Printer
My document wont print because the cyan is empty, I only need black ink, can I over ride this?
I have not see a printer that will you do that. you always need to have all colours with ink available.
Thanks
May 05, 2011 | Canon Office Equipment & Supplies
What type of glossy paper should be used for Samsung CL315W Color Laser Printer?
Really there are no 'photo papers' for color laser. As the toner 'sits' on the surface of the page it makes little difference what paper type you use. Ink on the other hand is absorbed into photo paper and the gloss finish gives it a nice look and feel.
You may get a perceived effect with different brightness of paper. I have found the the high bright copy paper is best.
The inkjet papers will not work as it has a coating for inks not toners. From experience and trying various glossy laser papers, I have found that different ones work differently with each laser and its only trial and error. When you print try and scratch the surface as we have found that on alot of the papers the toners scratch off pretty easily.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 10, 2011 | Samsung CLP-315W Laser Color Printer
Black ink streak on left side of paper on hp 1012, just put in new toner
Run a half test.
Put paper in the manual feed tray(tray 1).
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
Oct 21, 2010 | HP LaserJet 1012 Printer
Smudges on paper and then when it does copy, ink is light.
hi,check copy cartridge or clean corotron wire.try to increase toner.send me result.
thank you.
May 25, 2009 | Sharp AR-5320 Black and White Copier
Canon Pixma 470/ cyan and yellow won't print
it may be many things, here some thing to try:
the ink or toner is contrammed with foreign liqued like oils, water, bad ink, bad toner cartridge,
oil, water, ink toner inside the ink itself
oil from a human skin my have came in contact with refill of ink or toner cartridge, cleaning solvent to clean the cartridge, needles for hte ink or toner cartridge, water in the ink or toner cartridge, steam or vapors of some kind, compress air can or air compressor will spread water solution, the freon is used in compressed air can thats way they get so cold when you spray the can.
paper may also be wet some how try new and different brand of paper.
rod the candymangandy
Feb 04, 2009 | Enlight Intel Xeon 470 WATT EN-470 MP...
How can I make my laserjet prints look as dark as my designjet pr
It si not possible because the %darkness of the black ink and the black toner. The first is near 93% black and the toner even at ***** eye looks dark gray less than 90% black.
Jan 12, 2009 | HP DesignJet 4000 InkJet Printer
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
24 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
