Question about StarTech.com StarView SV211K 2-port KVM Switch
How do I change rf frequency on my super usb box
What is the frequenies for ntl i cant get in to the channel edit or parental control
Posted on May 30, 2010
    Sergeant:
  • 142 Answers
Go to menu then go to user set up and press ok frequencies on there.
Posted on May 16, 2010
Channel change buttons on the TV set will only go to 44 and 50 I need 03 for converter box.
If you cannot change the rf frequency on the tv set to 03 or 04, there is no way you can get the converter box to work with that set..
Sorry.
Apr 18, 2015 | RCA Televison & Video
I have just got a sky+hd 2tb box installed, i have a wireless transmitter and sender that i use to watch sky upstairs in my bedroom, i can get sky upstairs through the wireless scart connector/video sender...
You need to find out if you remote is infrared or radio frequency. If infrared then there are remote extender devices that you can purchase to use your remote. If it is RF, then your search would be the RF remote extender box.
Jul 02, 2014 | Computers & Internet
Hi i have the box super usb , ihavelost more or
yes all the providers have updated there security and there are no longer new codes or fixs yet
May 11, 2010 | StarTech.com StarView SV431USB 4-port KVM...
All we are getting is a pixilated screen and no sound. Dvd's play normally
OK. This should be simple. If you are using a TV with a built in digital tuner like all the HDMI ( High Defintition Media Interface) flatscreens then you probably need to go through your set up menu on your Digital TV and select Initial Setup / Channel Input / Cable / Satellite if coming directly from a dish on 75 Ohm Coax / or Cable if coming directly from the outside 75 Ohm coax with analog signal. ( When I say DIRECTLY, I mean you are not going through any boxes and changing or passing the signal). All satellite direct connects are digital and all satellite converter boxes have multiple out puts these days. There is an HDMI output for high def and low def analogl to digital (A/D) signals coverted within the TV, sometimes there is a DVI or even a USB out put connector...and there is a 75 Ohm coaxial RF cable connection for all the old schoolers who do not have a widescreen digital TV. RF means Radio Frequency and uses Radio Frequency Channels 3 and 4 at the bottom of the RF band around 56 MHz to which any TV with an Analog Tuner can use. In the old days this is what was used for the connection to the TV from the cable boxes because our TVs did not have the capability of decoding analog pay channel signals, hence the little black boxes sold and used ONLY by cable thieves and not any of us here on fixya. For starters, let's make sure you are using your high def, dvi. or some format of digital It sounds like your TV is set up to search and code digital signals but is looking for the wrong carrier frequencies, meaning it is either looking for decoded digital satellite box signals, digital broadcast ( New Digital TV received via an Antenna). Once your TV scans for channels in the cable mode they will be memorized and available on your channel up / down keys and Favorites. (FYI t will scan for both digital and analog channels on antenna mode). Repost if you have troubles or refer to your users manual.
Aug 17, 2009 | Televison & Video
Set top box installation
RF is the normal round coax cable in black.
Further you need to select your video channel on TV to watch the set top box RF signal. Usually you change the RF channel frequency also on these things. If you don't know channel number let TV scan it.
Apr 18, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Working principle of super heterodying receiver
you can find it easy with google, but here is how it works...the incomeing rf signal is mixed with a signal of another frequency from the local oscillator and then passes through a non linear device (semiconductor). after passing through the nonlinear device the output will contain the original frequency,the local oscillator frequency, and frequencies equal to those added together and subtracted from each other,these signals are then passed through filters to obtain only one which will be either the rf frequency plus the local oscillator frequency or the rf frequency minus the local oscillator frequency. This new frequency is then coupled to the intermediate frequency amplifier stages where most of the amplification takes place before the audio is removed and passed to the audio stages.
Jan 13, 2009 | Computers & Internet
Rf modulator for direct tv box
Re: Hiding the direct tv box
Your primary concern with hiding the receiver is how it works with the remote control. By default, Directv remotes use an IR (infared) beam to communicate with the Directv receiver, and this means there must be clear line of sight from the remote to the receiver. However, you can possible use RF (radio frequency) to transmit signals instead. This would allow you to pretty much hide the receiver anywhere you wanted. Currently, standard receivers do not have this capability, but DVRs and HDs do. Contact Directv customer service and ask if you will need to order an RF remote (there may be a charge). https://forums.att.com/t5/DIRECTV-Installation/Hiding-the-direct-tv-box/td-p/4425309
Jan 02, 2018 | Televison & Video
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Jan 30, 2008 | Televison & Video
StarTech.com StarView SV211K 2-port KVM Switch Logo
76 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
