Question about Gateway GTW-P42M303 42 in. Plasma Television
Gateway GWT-P42M303 screen problem
Ok I have a Gateway GWT-P42M303 plasma that I just received from a relative who told me I could have it if I could fix it. Originally he thought that the PSU was fried but when we opened it and looked everything seemed to be intact. He said when the picture went he heard a pop then it went blank (after flickering). The TV powers on and you can hear it trying to work and the LED lights on the front and back turn on but the screen does not seem to be powering on. We purchased a tester and tested the connections last night and discovered that the upper fuse on the ZSUS board was blown (the other one was fine). We replaced it with another fuse and it blew as soon as we turned the TV back on. We then bypassed all of the fuses and when we turned the TV back on it turned off after ten seconds or less. After a few attempts at this we unplugged the PSU cable from the ZSUS board to cut off the power supply and turned the TV back on and it turned on and stayed on (no picture still, just blank). This leads me to believe that the ZSUS is bad. I went online and found the part (well I think) for $100 but I am not confident enough in my assumption to just purchase it. Also the P/N on the board from the TV is LGE 6871QZH030A which when looked up says it’s a Zenith P/N but Gateway is telling me the P/N is 6870QZE009E. Should I just go with the number on the board or Gateway’s word who doesn’t even make their own plasmas? Please can someone help to figure out if I am right about the ZSUS board or could it be something else?
  • 2 more comments
  • Anonymous Jan 12, 2009
    On my board the item "D1" was soldered out by itself. The item has the printed code 61FC4. Could someone tell me a store to buy this Diode?
  • nsdn Feb 12, 2009
    I have exactly the same problem with a TEAC but the board is the LG one and D1 has desoldered itself and self destructed in a big way FS1 is also blown. Did replacing the diode and the fuse fix the problem?....I notice the other diodes, D2-D4 are actually in parallel with D1, I wonder why D1 died the same death in both our cases.
  • Anonymous Mar 06, 2009
    lg lcd tv the f1 on on the zsus blown plus all the diode was shorted replace the board and the same happen. can someone help.
  • Anonymous Apr 01, 2014
    I have a LG 50px4dr. The screen was extremely dim. I was instructed to replace the zsus. I installed the replacement. Now the screen doesn't turn on, relay clicks, standby blinks yellowamber 15 times. I reinstalled the original zsus, which maintained it's original dim symptoms. The new zsus board is bad, right?
    New Friend:
I have a LG 50PB2DR and I initially THOUGHT that my 61fc4 diodes (two of them) went short circuit. It turned out that when I removed those diodes, a continuity test across the board terminals (with diodes removed) still registered as short circuit! The diodes turned out to be NOT faulty. Instead, my 61fc4's were probably in parallel with an inductor coil or something, which initially gave the impression that the diodes were bad. My TV went bad because two FQB46N15 Mosfets developed short circuits across drain and source. After replacing those failed Mosfets, the TV was fully functional again. The 61fc4 diodes are just fine. They just 'appeared' to be faulty - most likely because they really might be connected across coils or something. I haven't got a circuit diagram of my board. But it became apparent to me that 'short circuit' readings don't always necessarily mean failed component. I learned this just today from this particular experience.
Posted on May 03, 2017
Has anyone found a place to buy the 61FC4 Diodes ?
Posted on Mar 10, 2010
The 15v is shorted to the ysus board and probably one of the two big heat sinks with the number 4921QP1002B is the cause. If you don't repair it can I have it for parts?
Posted on Apr 17, 2008
I have gateway plasma tv srs bbc 50 " get verry hot in the exauste and in the sreen is it normal? think's
Yes,it's normal, a plasma uses a lot of power (over 300W) so it generates a lot of heat - especially the screen.Remember, plasma is an overheated gas so a large screen contains a very large amount of a very hot gas.
Jun 23, 2010 | Gateway GTW-P42M303 42 in. Plasma...
Gateway 42" plasma has sound only, no picture. 6 years old
Gateway 50" plasma tv #7005406 runs only in black and white after power outage. Menu screen still in color.
Mar 01, 2010 | Gateway GTW-P42M303 42 in. Plasma...
I have a Gateway gtw-p42m303 powers up to the warm up screen then light switches from green to standby orange. smells hot could be a power supply or capacitor?
Most likely a Y sustain module failure. Gateway does not make a set, so I would need a part number off of the board in order to give you an exact price of the part. Usually they're around $300.00
Nov 13, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Gateway 42 plasma p42m303 parts
There is an image board on sale on ebay you may want to check this out.
Sep 04, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Gateway TV
I have had the same problem on my gateway plasma for a year now. My 2nd TV just started to show similar defects on the screen. I can never get a straight answer as to what causes this problem yet it is a very common defect on these tv models (gateway) most accurate answer I got from gateway was that it is better to buy a new one.
Jan 04, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Gateway QTW-P42M303 vertical black bar on screen after 5 minutes. 2 1/2 years old
its a bit complicated but you trace the circuts and voltages across schematic,, with the if you can find gateway service manual for your specific tv besides this these things are very touchy they have built in circut protection and its just a matter of finding the fualty circut or ps led flash codes.. hope this helps..
Sep 06, 2006 | Gateway GTW-P42M303 42 in. Plasma...
Gateway GTW-P42M303 42 in. Plasma Television Logo
977 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
