Question about Refrigerators
Replacing a fridge thermostat of a Smeg FC40RX fridge freezer
Hi y'all is it possible to buy and replace a thermostat for the fridge part of the FC40RX? Smeg Fridge Freezer myself? In the recent weeks I have noticed that although the freezer part works perfect and the light of the fridge still works I cannot alter the fridge temperature using the 7 settings. The temperature is warmish and food is not keeping as well as it used to plus a smell is developing. ( I put a plate of bicarbonate of soda in it) Because of where the fridge freezer unit is standing it happened that the surrounding temperatures were colder than the fridge itself I wondered whether that has confused the 'thermostat' or broke it? Could that be the problem? I love the fridge freezer and had it for 14 years and look well after it. I would like to repair it if possible. I don't know where the thermostat is please let me know and if I can replace it. Are there schematic/technical drawings available online? Please advise I'd be most grateful. Best regards Sabine Kazich
DO NOT ATTEMPT THIS METHOD UNLESS YOU UNDERSTAND ELECTRICAL SAFETY. The thermostat is behind the cooling element at the back of the fridge compartment and it connected to the dial at the top front of the compartment that controls its temperature setting. Remove the front plate to access the switch and you will see the wiring that goes to the thermostat. Connect the two wires to the thermostat and if the fridge does not start the thermostat is faulty. Replacements are available, but you may need to do some hunting on line. With the power off this time, securely tie a few feet of string around the thermostat wiring at the switch. carefully loosen the cooling element to free the thermostat and pull it free. Now tie the string to your new thermostat and pull the string back through so the wiring is pulled into place. Put everything back the way you found it and, after a short while, enjoy a nice cold drink.
Posted on May 23, 2011
Smeg FAB28QRI thermostat not restarting fridge unless I hit side of fridge! Do I need a new thermostat?
It could be a loose wire on the terminal of the compressor. Also check for loose wires on the thermostat. If that is ok, the thermostat could be bad because it is a temperature controlled switch that turns the compressor on or off.
Jun 14, 2014 | Smeg FAB28QR1 Retro Fridge with Freezer...
I have a tall smeg fridge freezer. Freezer compartment working perfectly. Fridge not cooling despite all lights being on. I've switched it off then on, turned the thermostat down, then up again...
Hi Evelyn,
Has the freezer been defrosted lately? Perhaps a buildup of ice will not let the refrigerator cool sufficiently. Try this and let me know how it works out for you. If it does not have a self defrosting cycle on it, it may take some time, just do not use a sharp object in the freezer as this could puncture the freon lines and that would render the unit useless.
Joe
Sep 21, 2011 | Smeg Refrigerators
Hi, we just defrost our Smeg Freezer FAB30 and followed the instructions on the website. It seems now that the fridge doesn't restart !!! Help ! What do we do ?
some of these new fridges have a delay timer and can take up to 10 minutes to reset. check to see you have power at the plug.. use a hair drier low heat .. make sure the stat is set.. duh .. hey it happens to the best of us .. jay
Jul 23, 2011 | Smeg FC40RX Bottom Freezer Refrigerator
Freezer works fine, fridge compartment cools but has stopped cooling as good and has recently stopped cooling. did a manuel defrost on fridge and freezer worked fine afterwards, now doing the same thing...
Oncce the fridge was shut off and left for a while the cooling had come back . If frost is seen it is a good indication as the compressor is working with sufficient gas within.
If after about 6 hours you observe cooling it is possible that the defrost timer is faulty.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
replace the defrost timer, heater or thermostat one you have confirmed to eliminate one by one.
Mar 11, 2011 | Hotpoint  14.9 Cu. Ft. Top-Freezer...
Freezer is very frosted up. Do we have to switch off fridge and defrost all?
Yes, that is the best way to do it...
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 07, 2010 | Smeg FC40RX Bottom Freezer Refrigerator
Smeg integrated kitchen fridge and freezer unit - freezer stopped
beneath the freezer usualy installed timer and a fan look for a hidden screw on the sides...check the fan bushing f its lose or has a clearance change it f not check for the timer if its busted...replace.. becareful...electric shock can kill
Jul 11, 2009 | Smeg FC40RX Bottom Freezer Refrigerator
I need a manual for a Smeg FC40RX fridge/frezer. Can you help?
I would suggest contacting the company thru web online request at
http://www.smeg.it/international/WebForm.aspx
Every time you click on manuals on the web there is an error.
So fill out the form and request manual.
Mar 12, 2008 | Refrigerators
Fridge not cold enough and build up of ice at back of fridge
May be your damper switch not closing your damper when it reaches tempature setting.
Dec 13, 2007 | Smeg FA311X Top Freezer Refrigerator
Smeg Fab 32 door problem
Remove the lower hinge on the fridge door and pack out using a piece of cardboard resrcew the hinge onto the door, this will resolve the problem Regards Advisor Smeg Agent
Jun 08, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerators Logo
1,310 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
