Question about Nvidia 32MB GeForce MX200 AGP Video Card Graphic Card
AGP SIGMA MX200 32M ,WINDOWS XP, OK BUT USB HAVE
Agp sigma MX200 32M windows xp ok but usb have problem --> read thum drive ok. But tell insert disk in drive. Why? thank you.
SOURCE: sigma mx400 64
thanks a lot. will try your suggestions.
Posted on Jan 17, 2008
ghost_cyrix
  • 33 Answers
SOURCE: I have Vga Card nvidia 64MB AGP Geforce2-MX400, I need driver it
http://www.nodevice.com/driver/GeForce2_MX_400/get37172.html
best luck
Posted on Dec 02, 2008
  • 254 Answers
SOURCE: GeForce 6600 AGP 8x 256 MB in Asrock 7s41gx
get another hard disk and do a fresh install of xp then the drivers and the game see if its all ok
if it is then its your drivers get them out and replace them
with the latest from nvidia. or format and go again
hope this helps
Posted on Dec 31, 2008
technical114
  • 1851 Answers
SOURCE: i need driver for windows xp sp2 nvidia 64mb
There you are
http://download.cnet.com/NVIDIA-GeForce2-MX-400/3000-2108_4-84310.html
Stelios.
Posted on Feb 20, 2010
  • 518 Answers
SOURCE: is Sigma mx200 32m is part of NVIDIA?
nvidia web site has all the drivers
Posted on Jul 05, 2010
PNY VCG84512SPEB GeForce 8400GS (ASUS K8U-X)
I have no idea why you would go from an agp to a pci. Agp has like 8x the banwidth of pci.I'll assume the agp slot went bad. If you can get into bios before you lose the display,change the display from agp to "init pci first",save & re-boot. See if that works,then when in windows install the drivers right away. If that doesn't work, during boot at the splash screen, press f8 & select "safe mode" with networking. This should let you get into windows so you can remove the old agp drivers,then re-boot into safe mode again & install the new drivers. Then re-boot normal & you should be ok. If not,that board has a big problem.
May 14, 2010 | ASUS K8U-X Motherboard
Tip
Acer One's and More "Making working Windows copy to USB Stick"
Directions for Making Usb OS for windows 98,me,xp,2000,2003
You will need to saerch for a little program called Komku-SP-usb so get going and also a working computer with an actual cd/dvd rom drive.So if you need go use your buddys computer.
After you found the program as stated abovce download it and follow the rest of these directions I have left. Curtosy of someone else of course.
1.Open and install Komku-SP-usb on a working computer other than your Acer One.
Make sure that the Usb Stick you may be using has at least 2GB.
2.Locate folder C:\Komku\PeToUSB\ and double click PeToUSB.exe
3.Select USB Removable,make sure enable disk format and enable disk format are all checked.
If you feel the need you may put something to name your usb in the drive label area.And uncheck
enable file copy if it is checked.
4.Click Start
5.Click Yes
6.Click Yes Again
7.After Operation complete you can exit out of that program.
8.Next open Ms Dos command promt.Click Start > Run > type cmd > click OK
9.On Command Prompt window, go to directory C:\Komku\bootsect\
how to do this?
first type this cd\ and press Enter
10.then type cd komku\bootsect and press Enter
11.on command prompt window, type bootsect /nt52 and whatever your drive letter is {Mine was H:}
12.press enter
13.now type this cd.. and press Enter
14.then type cd usb_prep8 and press Enter
15.type usb_prep8 again... and pres Enter
16.Press any key to continue and the usb_prep8 welcome screen will appear
17.now, insert your original Windows XP CD, or Windows XP with sata ahci driver to your CD/DVD ROM
and back to Command Prompt window
18.type 1 then press Enter and "Browse For Folder" window will appear, select your CD/DVD drive and click OK
19.the result... "XP Setup Source Path" changed to G:\ (yours may be different)
20.now for point 2, if letter T is currently assigned to a drive in your computer,
you must change it.... if not, leave it as it is
To change it type 2 and press Enter...
21.Enter Available Virtual DriveLetter"
for example you doesn't have drive S
so you type S and press Enter
back to usb_prep8 welcome screen...
now type 3 and press Enter...
22.Please give Target USB-Drive Letter e.g type U" Enter Target USB-Drive Letter:
because my Flash drive letter is H
23.so, type H and press Enter...
after back to usb_prep8 welcome screen...
now type 4 and press Enter to make new temporary image with XP LocalSource and copy it to USB Flash Drive
please wait a few seconds..
24.WARNING, ALL DATA ON NON-REMOVABLE DISK DRIVE T: WILL BE LOST! Proceed with Format (Y/N)?"
type Y and press Enter
please wait....
when format virtual disk complete, press any key to continue...
25.when you see "Making of LocalSource folder $WIN_NT$.~LS Ready"
26."Copy TempDrive Files to USB-Drive in about 15 minutes = Yes OR STOP = End Program = No"
Click Yes, and wait...
27.Would you like USB-stick to be preferred Boot Drive U: bla... bla..."
Click Yes
28."Would you like to unmount the Virtual Drive ?"
Click Yes, wait a few seconds, and press any key....
press any key again to close usb_prep8...
29.Now, insert your USB Flash Drive/Flash Disk/Thumb Drive to your notebook (e.g Acer Aspire One)
go to BIOS and make USB HDD (or USB ZIP in some other machine) as primary boot device....
30.then boot form your USB Flash Drive....
and select "TXT Mode Setup Windows XP, Never unplug USB-Drive Until After Logon"
31.After Hard Disk detected, delete all partition, create single partition...
and install Windows XP on that partition...
and wait...
32.once text mode setup is complete, computer will restart....
this time select "GUI Mode setup Windows XP, Continue Setup + Start XP"
33.Continue Windows XP setup.... and Done!
Windows XP Installed....
34.Remember, you can use this tutorial to install Windows XP on all other computers..
not just Aspire One and Asus EEE-PC....
on Jun 21, 2009 | Acer Aspire One AOA150-1570 Notebook PC
DRIVER
go to
http://www.nvidia.com/Download/index5.aspx?lang=en-us
In Product Type choose Legacy
In Product Series choose Vanta series
In Operating System choose the OS you're using.
Click Search and download the driver!
For Windows XP, you can use the following direct link:
Driver
Mar 05, 2010 | Nvidia TNT2 Vanta, (16 MB) AGP Graphic...
Sigma card reader/writer doesn't recognize my new SD card
What I suspect here is that, the USB port that you are using is a USB 1.0 port, which has a lower voltage not enough to power on your Storage drive.
In this case, there are two things you can do,
1. Change the USB port you are using for the storage drive to a USB 2.0 one (Just keep Checking all the ports one by one in case you dont know which one it is).
2. If your Storage drive has external power facility, just plug it in an external power first, before connecting it to the system.
If there are no USB 2.0 Ports on your system at all,
then just go to any electronic store and tell them you want to buy a USB 2.0 Expansion card.
and if it is a laptop, A USB 2.0 PCMCIA card.
Install it on your system, and connect your external drive through it.
Hope this helps you out.
Goodluck
Nov 19, 2009 | Electronics - Others
Hello! I installed windows Xp-pro on pentuim of
first install correct usb drivers, for your moterboard
them your camera is recognize
Oct 30, 2009 | Intel Refurbished SLOT1 ATX SYSTEM BOARD 2...
I need driver help, yes i am a idiot
No your not.Go to microsoft web site or use the built in Windows Update on your computer.If you haven't downloaded the update tool it will ask you to install it.After it installs the update tool, run it.Pick the updates you need lnstall them some will require you to restart.Later check the automatic update feature to check for updates.Other updates will be from the manufacturer or your PC,check for their updates.Software from their sites.This is not hard.If I were you I would buy a general book on XP you can learn easy steps to keep your PC up to date and won't have to ask anyone (except FixYa.com) good luck
Sep 05, 2009 | Computers & Internet
PNY Attache USB (4GB pen drive) not recognized by WinXP SP3
Your USB memory should be damaged. i have a Centon DataStickPro 4GB that was OK but now i have the same problem. If you know HOW you can try re-format on DOS, but be careful with your harddrive.
By the way, 3885 MB are 3.7GB or so.....
You can try buying another one, SAME MODEL, then the same/next day return the BAD ONE to the store and get your money back.
May 16, 2009 | PNY Technologies GeForce 6200 128MB AGP...
Cant log on xp.
hi..if u want to run as good that VGA u need to set in the Bios as init fist display as AGP then find what AGP size appear on bios..if this all OK try to booting the system..thanks and Good Luck..^_^
May 11, 2009 | NVIDIA GeForce 5500 / 128MB DDR / AGP 8x /...
Dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
Nov 10, 2008 | Dell Latitude L400 (220-3575) PC Notebook
Sigma mx400 64
it most probably supports OpenGL; will run on the P3 comp. and to be able to use the card properly u will need it;s drivers. U;ll have to look for them on the manufacture\s site or on other sits (www.driverguide.com for example ....) If u don;t find it's driver, it might work with other drivers made for the same video card chipset ....
Jan 16, 2008 | Sigma ZDS VGA Video Controller 030249...
Computers & Internet Logo
179 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
