Question about Boating
Compression of 92 Yamaha 250 OX66, 250 hrs after rebuild.
I have the opportunity to purchase one of 2 1992 250 OX66 saltwater series engines. They were rebuilt 250 hrs ago and has 105 psi compression. It is the starboard or right hand motor on a 31' Fountain. The port motor already sold and had 113 psi. Is it possible that this starboard engine was propped wrong and was carring the bulk of the load? Assuming that and that I will only lightly use how say 75 hours per year how many years can I go till another rebuild?
  • Boating Master
  • 3,498 Answers
Hey Anon,
The biggie is the compression difference between ALL the cylinders,,, there should not be a 5-10% max. difference between the lowest and highest readings.. if more.. I would question the rebuild quality,,(My V6 is all within 5 psi after 13 years - (I rebuilt it!!) The longevity is based on how hard you run it, the quality of the oil and fuel you run and how clean you keep inside the cowl....
The engine could last for a long time.. or break tomorrow...no way to know??
Posted on Jun 21, 2017
2 Suggested Answers
  • 51186 Answers
SOURCE: Compression of 92 Yamaha 250 OX66, 250 hrs after rebuild.
you could get 20 + years out of it with proper service
Posted on Apr 25, 2010
02 yz 250 not reving up
Check the compression. It should have at least 100 psi,..if not,then its time to rebuild the top end..IE piston,rings,bore cylinder. If compression checks out,i would start with the power valve. Two stroke dirtbikes power valves are notorius for gumming up and sticking,causing them to not rev correctly.
Aug 31, 2012 | 2003 Yamaha YZ 250
Water in oil in transmisson on Yamaha yz 250 2003
you got a blown head gasket or warped head
Apr 22, 2012 | 2003 Yamaha YZ 250
So i was just wondering what the compression should be at cause i ran a compression test and on three of the cyliders the had a little over 100 PSI and the other was 70. and if the 70 is bad what do i do?
A car that old is not worth rebuilding the engine. For the price of an engine rebuild you can buy a 99 Saturn with half the miles. Or you can call a junkyard and see if they can locate you a SOHC saturn engine to fit a 92, probably any Saturn SOHC up to 95 will do. Used motor will cost 300-400 dollars plus removal/install while a rebuild will cost you 1500 at least plus a removal/install.
Oct 14, 2010 | 1992 Saturn SL1
Wont start low compression
well its 20+ years old!!! the engine will need a rebuild by now
the full works too,,,
Jul 01, 2010 | 1987 Yamaha FZR 250
Mar 20, 2010 | Boating
92 festiva and i have oil in my air filter
rebuild engine!!but do compresion test first check dealer for compression spec if good look at pcv problems
Dec 22, 2009 | 1992 Ford Festiva
My 1992 yamaha timberwolf 250 2wd, wont start. engine overheated due to low oil. engine is not seized, still turns over with good compression. it has spark and in all essence should start
i wonderin if u cooked a valve or not-sed u had compression-did u test it with a gauge-any engine is really sensitive to low oil n heat-physical parts can warp n electrical stuf can fry-tho it dozint appear
Aug 13, 2009 | 1992 Yamaha FZR 250 R
My Yamaha FZR 250 ran out of oil and coolant and overheated. Now I can't get it started. Is the engine ceased?
Very likely yes. If it won't turn over at all you will probably need a complete rebuild. If it turns over but won't run I would check the compression before I rebuilt it.
Jun 26, 2009 | 1988 Yamaha FZR 250
FZR 250 power promblems and no top end power battery keeps draining
need to have the valves adjusted and the compression checked
Jun 01, 2009 | 1988 Yamaha FZR 250
Boating Logo
956 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
