Question about Linksys Wireless-G WRT54G Router
I CAN CONNECT WITH NO TROUBLE TO THE INTERNET THROUGH MY ROOTER HOWEVER WHEN I TRY TO CONNECT THROUGH MY WIRELESS WRT54GS I CANNOT I GET A MESSAGE SAYING THAT IT CAN NOT FIND THE SERVER OR INTERNET CONNECTION AGAIN THIS ONLY HAPPENS WHEN I TRY TO CONNECT THE WIRERLESS SYSTEM
  • 32 Answers
What exactly are you trying to connect to the router? They usually have default passwords, such as 'admin'.
If not go to 192.168.1.1 on your computer when connected to the router, and leave the username blank and the password as 'admin'.
Then go to the top tab and change or remove the wireless password. If you mess anything up, just click the reset button on the outside of the box for 20 secs.
Posted on Mar 31, 2008
The password comes back as invalid when I just used the same password to connect my Windows based laptop and my iphone to the Wifi......
Report Trouble with Linksys router WRT54GS [Solved/Closed] johnkwit 2Posts June 16, 2008Registration date - Jun 17, 2008 11:17pm BST - Last answer on Jul 27, 2010 5:27am BST hello Hello,
I have a new Linksys router WRT54gs and a new Dell laptop.
The router works well with the cable attached but when I go to wireless
I get a strong signal but unable to get on the internet with WEP security.
With security disabled the wireless works fine. But will not connect to the
internet with WEP security on. I tried to use the CD install disk that comes
with the router but ir does not help.
Any help would be apreciated
Jan 05, 2011 | Computers & Internet
I"m tryingo to connect my
I suspect that you have setup your router to expect a password of sorts and your lap top is not sensing the auto find feature. Check:  http://www.retrevo.com/support/Linksys-WRT54GS-Wireless-Routers-manual/id/421ci076/t/2/  for a primer on how to setup the WRT54G router.
Nov 27, 2010 | Linksys Wireless-G Broadband Router
I cannot connect to the internet. I am using a netgear rooter. Although I am connected to the router I cant get through to the internet
moz-screenshot.png1) Go to Start and click on Control Panel.
2) Control Panel window will appear. Double click on Network Connections.
3) Network Connections window will appear. Right click correct Local Area Connection by identifying correct network card and click Properties.
4) Select Internet Protocol (TCP/IP). Click on Properties.
5) Then try assigning the following values (default) and Select OK.
Nov 18, 2010 | Acer (D10709-002) (D10709002) 802.11g/b...
I have an Linksys Wireless G WRT54GS router. I
This is strange... Never heard of it in all my years. Call Linksys www.linksys.com and then ask them becuase this is rare. If they can't find a solution just steal the internet :)
Oct 13, 2009 | Linksys Wireless-G WRT54GS Router...
Links up as a rooter but it will not connect to internet the modem is a talktalk smartAX mt882 adsl modem and the rooter is a linksys wrt54gs-uk im in the uk i can see and link up to the network
Howdy,
Try this: 1- Logon to the router @ 192.168.1.1. Default username = blank (none). Default password = "admin" (no quotes). Then: 2- On the main opening page, reset the IP address from 192.168.1.1 to 192.168.2.1. Check (adjust) your timezone - etc. Then: 3- Click save at the bottom. At this point it will tell you settings successfully changed and it may try to return you to the page. But it won't be able to because you changed the IP address. Please close the browser and reopen and repeat logon as above using 192.168.2.1. If you can log in you have sucessfully changed the routers IP address. Certain modems will not function with the default IP address that comes with the router and must be changed. My setup is like this and I must do what is described above for my wrt54gs to function properly. Please use Internet Explorer browser if other browses do not work. Good luck.
J
Jun 01, 2009 | Linksys Wireless-G WRT54G Router
The linksys wrt54gs-uk
With a DSL modem in the US, you need to confiugre the router for PPPOE with the username/password that was provided to you by your ISP. If you can't remember the name or password, contact your ISP
May 31, 2009 | Linksys Wireless-G Broadband Router
Can not connect without resetting router each time from base
try and update the wireless G's firmware....
it should solve your problem....
Jan 28, 2009 | Linksys Wireless-G WRT54GS Router...
The port of Linksys Wireless-G WRT54GS Router Linksys Wireless-G WRT54GS Router
What do you want to know about the ports? The one separated from the other ports is the Internet port. that is where you're going to connect the cable from your modem. The other four are the ethernet port where you will connect the computers.
Jan 22, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys wrt54gs router and Xbox live
make sure that internet connection working fine first..if it is connect you xbox via wired or wireless(if wireless, make sure that you connect to your own wireless network and enter the wireless security if there is)...check if you can get an ip address, better set to obtain the ip address and dns of your xbox, if all set and still unable to access internet, access the linksys router setup page by typing 192.168.1.1 on the address bar of your internet explorer, when pop-up for username and password type admin under password, leave it empty for the username. Click administration tab and disabled UPnP. Check if your X-BOX working fine. Hope this help you.
Sep 29, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54G Router Logo
32 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
