Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My Mitsu 52525 lamp indicator went solid red. I
My Mitsu 52525 lamp indicator went solid red. I followed instructions and purchased a new lamp. When new lamp was installed I still got the solid lamp indicator and screen would not light up. When pushing the power button I looked through the vent above the left air filter and saw that the bulb does light up for approx 8 seconds and then goes dark again. What is causing this and is there a easy fix? Thanks.
  • Mitsubishi Master
  • 8,617 Answers
Sounds like the caps on the power board have failed. You can get the V26 DM/Power repair kit from www.tvrepairworld.com which also contains the instructions.
Posted on May 14, 2010
The red light was on solid, and the manual said to replace the lamp. I bought a new lamp and put it in, but still no picture. The fan comes on, it tries to power up and then in about 20 seconds the red...
these TV's have lots of problems. Don't waste your money on repair. But towards new one or you will be constantly replacing parts.
But anyway sounds like a power supply or light eng problem. If all measurements are good then the chassis needs to be sent to Mitsu for repair (approximately 140 updates to it).
Feb 26, 2011 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi digital WD-52525, and the "lamp" indicator is illuminated in red. Can I buy a new lamp and replace it myself?
If you have a red led solid. check the fans and make sure they work. Sceond push both input and menu and see what the blink code is?
Jul 08, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Thats usually caused by failed capacitors on the power board. The V26 power repair kit from www.tvrepairworld.com should repair that issue. The kit comes with the instructions on Cd.
Mar 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Hello, I have a 52525 and the lamp indicator went
push the menu and device buttons on the front of the set both in together and hold for 6 seconds and see what two digit error codes blinks. It will most likely blink a 3 pause then 4 and then repeat the sequence indicating a 34 error for lamp abnormality which is almost always caused by faile capacitors on the Power pwb.
Jan 22, 2010 | Mitsubishi WD-52525 52" Rear Projection...
No picture on my WD-52525 projection television.
Chances are youre getting a 34 errod which is cxaused by failed capacitors on the power board. You can get the V26 DLP Power board repair kit at the following link which contains the capacitors and the CD with detailed instructions.
http://www.tvrepairworld.com/
Jul 25, 2009 | Televison & Video
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Had blue screen, now no picture and red light
Press the menu and the device/input buttond on the det both in together and hold in for 5 seconds to see if the led will blink a two digit code such as 3 blinks slight pause then 4 blinks. I would almost bet that you have a 34 code come up. But respond to this same post and let me know which two digit blink code came up, and I will assist you with whats wrong with your DLP.
Aug 08, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525-Code 34-Sound OK-No picture!
I had another problem kinda the same and emailed ctechnicians.com and they gave the fix.
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
278 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
