Question about Mitsubishi VS-60607 TV
Channel button When I push the channel up or down button, on the TV itself, the channel still does change. Can someone tell me why
    President:
  • 4,402 Answers
Well i would guess loose connect or plug cam off or missing voltage to the buttons.
Posted on May 28, 2008
Tv changing channels on its own
What tv ? You tryed factory reset ??
Jan 03, 2014 | Sansui Televison & Video
The Channels won't stop Changing
if someone has spilled water or pop around the buttons on the tv itself then the buttons may be sticking if it was just water then it should go back to normal after the water dries out.But if it is soda then you have to manually take it apart and wipe the motherboard where the tv buttons connect to it with rubbing alcohol. have you tried pushing the channel up and down buttons numerous times and sometimes pushing them pretty hard will unstick it. If not the i say it would have to be clean.I would also use the remote and fool around with menu buttons to see if there is a way to correct it that way.But if all else fails then the motherboard tv buttons have to be cleaned .Hope this little bit of knowledge helps at all.GOOD LUCK to you and good fortune be with you.
Jan 02, 2011 | Apex Digital PF3220 32" TV
Channel buttons change input
Auto channel search is your friend. Once the tv has been through it and finds active channels, your channel button should work the way you envision.
Jul 06, 2017 | Toshiba 15LV505 LCD TV
The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
Nov 25, 2009 | Televison & Video
Cant get the tv to change from aux to reg channels
depending on the tv, some tv's you can change the input by channeling up and down. others you have to push an "input, tv/video, source or a/v" button. some tv's have this button on the tv itself (try that) or try the button on the remote. make sure you are using the remote that came w/ the tv. (because if you have a satellite remote, some satellite remotes the input button has to be programmed seperately) the problem is not exactly clear if you could be more specific steps that you are taking to try to change the input to the regular channels. i may be able to help better
Apr 10, 2009 | Televison & Video
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
TV turns on and changes channels on its own
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
Oct 17, 2007 | GE 31GT740 31" TV
Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Aug 29, 2007 | GE 32GT740 32" TV
TV changes channels itself
Have you checked to see if any of the front panel buttons are depressed and stuck??? this is a big problem these days?? I have also found the infared remote sensor to be bad on some sets that do crazy things all by them selfs.. A funny storry once i had was a customer called me after her mother called some goast finders as her maggy projection set would go on all by itself andf the channels would change and the volume would go up and down all by its self. funny thing I had a set just like thast in the shop at the time with the same problem and I scoped out the output pulse from the infared reciver on the set and that was putting out noise on the data line and caused the set to eratacly do all sorts of weird stuff. get the point?? its a stck button or the remote sensor is bad.
Apr 01, 2006 | Bush WS6671 28" TV
Mitsubishi VS-60607 TV Logo
27 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
