Question about LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television
Rear projection TV (LG 44SZ51): Horizontal dark band on upper screen field
I have this TV for 3 years. 3 months ago, a horizontal dark band (not black, i can see the picture there but it is considerably darker than the rest of the screen) of about 10-15cm width (not perfectly straight border line) appeared. Initialy i thought it was humidity on the mirror. I opened the case but there was nothing on the rear mirror. I didn't want to mess around with other parts of the device and the dark band is still there...
Is it possible that the lamp comes to the end of it's life and needs replacement? No indicator of such problem on the TV though. What could cause this? I don't know if i can find a technician for such a TV in my town...
Any ideas are welcome. Thank you in advance
  • 1 more comment
  • Anonymous Mar 30, 2008
    I made a mistake. The TV is the LG 44SZ21 (if i recall correctly because right now I am not home and i can't check it) but i think the problem is not so much model specific anyway...
  • Pausdale Jun 15, 2008
    Have almost the same problem. From the left about half way across it is dark but can still see picture sort-of, then 1/4 is a little liter and about 4" from the right it is normal. What is causing this problem?
  • elchat Nov 20, 2008
    I have the same problem but on another model. ru-44sz61d. Any solutions?
  • 21 Answers
The LG 44SZ21RB Have a problem with their light tunnel collasping due to the heat from the lamp. They are available as a spare part @ LG and would also require some silicon adhesive to bond it into the assembly. Very tedious job for any technican (2-3 hrs). Lg will not release parts to the general public only to an authorised LG agent.
Posted on Apr 23, 2008
SOURCE:
Dark horizontal band at top of Sony KDF - 46E 2000 TV
rca ps2720lv blue is very dim any suggestions
Nov 14, 2009 | Sony Televison & Video
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
I have had a Sony KF-WS60S1 rear projection TV for some 3 years and recently had to replace the globe. I completed this as per the book, double checking all screws were tight and the globe inserted...
You will need to pull out the engine and check for any smudge on the lens. then proceed with the polarizers 3 of them they are sitting in front of the DLP chips, this is a delicates operation. the blue polarizer is the one which usually suffers burn-in (dark spots on the glass). if everything looks ok, then it means that the dlp chips are faulty, at that stage it will be uneconomical to be fixed.
Hope this helps!
please rate me!
Mar 19, 2009 | Sony Televison & Video
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
Green bowed bands
replace convergence ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 27, 2007 | Toshiba 57H82 57" Rear Projection...
Red lines, green lines, now static!
Uneven colors with multicolored lines in the center of the picture and/or flashing, C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002)
Nov 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Horizontal lines
If this model has a "lint screen" or air filter, I would check to make sure the set is getting proper ventilation. Otherwise, you probably have a bad solder connection or capicators going bad, causing your symptoms. Hopefully you won't have to get a replacement Printed circuit board as they are quite expensive.
Jan 02, 2007 | Toshiba TheaterWide 62HM84 62" Rear...
Open Questions:
LG RU-44SZ51D 44" Rear Projection HDTV-Ready Television Logo
362 people viewed this question
Ekse
