I have a credaplan Ecowash series washer dryer. The drawer does not empty it's contents of washing detergent during the wash. Everthing else is ok but washing comes out washed with water!
  • 1294 Answers
SOURCE: Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Posted on Oct 08, 2007
SOURCE: my washing machine is leaking water everywhere when rinsing
you are over filling it!!!!!!!!!!!!!!!!!!!! when you use the rinse cycle it just fills the washer up to get all the soap out of the clothes. try just rinsing less clothes then usual. if that is not the problem then on the bottom of your washer is either rusted out or there is a rubber seal that could be over used!
let me know if that helped at all
zac
Posted on Oct 31, 2008
  • 33 Answers
SOURCE: kenmore series 70 washer
Dear Customer,
please rate this solution if it meets ur needs, else choose fixya..
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Drum does not spin
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
No water is entering the wash tub
or no hot water
or no cold water
Washer does not work but it does make noise
please rate this solution if it meets ur need, else choose fixya.Thank you..
Posted on Dec 17, 2008
SOURCE: detergent drawer does not empty detergent
hi! remove your powder draw, it should just pull out with a wiggle,give it a good clean in hot water, before you put it back give the draw hola a god clean with a bottle brush and hot water! good luck
Posted on Dec 20, 2008
barkencoa
  • 3463 Answers
SOURCE: Bosch axxis washing machine detergent symbols
There are usually 3 compartments in the drawer, the smallest is for using fabric conditioner, the largest is where you put the powder or detergent in, the middle size one you do not put anything in, as it is where the cold water comes in for rinsing.
Plz rate my solution.
Thanks.
Posted on Jan 26, 2009
Water in the Softerner compartment
The softener drawer cover is designed to siphon out most of the water that runs into the drawer so, when the wash is over, the drawer should always be nearly empty. Unclip and take out the detergent drawer, unclip the softener cover and fill the softener tray with water. Clip the softener cover back on and the water should run out immediately. If it doesn't then a small blockage in any of the 3 pipes in the cover can completely stop the siphon action. Cleaning them out is generally all that's needed.
Apr 06, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
Where would I find a replacement detergent drawer for a Zanussi 1055W washer/dryer?
http://www.ebay.co.uk/itm/Zanussi-Washing-Machine-Washer-Dryer-WDA1055W-Soap-Tablet-Detergent-Drawer/162547763876?hash=item25d89a0aa4:g:fsAAAOSwuxFYzP3t
Nov 06, 2017 | Zanussi WDA1055W Front Load Washer / Dryer
The soap tray fills with water at the back conditioner section on every run (no matter which programme) and does not drain, so I have to manually remove it and empty it after every load. I also think this...
Remove the detergent drawer by pulling it out and then pressing down the yellow part on the back of the drawer. Clean the drawer fully by hand in a washing up bowl using a mild detergent. Detach the yellow part from the grey part by turning it upside down and push in the clips gently. Clean the yellow part thoroughly. Put the yellow part back on - it just clicks back in place, and push your detergent drawer back in. Do an empty cotton wash at 85C (with no washing powder) to sanitise your machine.
Apr 13, 2011 | Dyson Memory CRO1 Front Load Washer
Need a manual for CredaPlan Cabaret oven
This is not exactly your model, but should be close: http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Creda/Cooking/HB48283.pdf
Sep 09, 2010 | Ovens
He3t washer frabic softner compartment isn't draining completly
Remove the drawer detergent dispenser. Then feel around in the front of the empty drawer tray for any missing detergent caps or chunks of anything. This can cause your issue - and can be an easy fix.
Aug 08, 2010 | Kenmore HE3T Washer
My he3t machine frabic softner compartment is not draing completly
remove the drawer detergent dispenser. Then feel around in the front of the empty drawer tray for any missing detergent caps or chunks of anything.
Have a Miele W320, during the rinse part of wash cycle, water pours from underneath the detergent drawer. What can I do to stop this happening?
Is the drawer gunged up? Are you using too much detergent?
Remove the drawer, and clean it with hot water and a brush.
Look into the empty drawer slot for any blockages and remove.
Replace drawer, try pouring hot water into the open drawer to try to dissolve and clear any blockages.
Consider using a dosing ball and adding detergent to the drum.
Feb 18, 2010 | Miele W320 Front Load Washer
Thanks.
Jan 26, 2009 | Bosch Logixx WFT 2806 Front Load...
Detergent drawer does not empty detergent
Dec 20, 2008 | AEG Lavamat W1050 Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
