Question about Philips HR1363 Mixer
Some one had presented a philips mixer grinder to me. whn opened the box, some covers etc were missing in it. how to get these parts ??? Model No. HL 1618
I bought a deni meat grinder but there was no cutting blade enclosed. The store is going out of business so I cannot exchange it. Now what?
Call the customer service number listed in the literature that came with your product. Even though the company is going out of business they should be able to ship you any missing parts.
Apr 16, 2014 | Deni Classic Meat Grinder 3301
Front attachment won't turn
It sounds like one of the gears inside the head has failed. You will need to remove the head and take it apart to work out which one. It should be relatively easy to get hold of the part you need once you have identified it. Please post your model number for us to point you to the right parts list.
Jan 13, 2010 | KitchenAid K45SS Classic Stand Mixer
We just bought a Kitchenaid Pro 500. It was not
Hi JBKRIEGER, Happy New Year! Yes you can download both your Owners Instruction Manual and Parts List Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number and then select the appropriate files under Owners Manual for your Instruction and Recipe manual and the file under Parts List for your parts list manual.
The Parts List manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part names and numbers. (Definitely check to see it this matches your mixer). You may not need it now, but if your mixer is out of warranty and you want to attempt to troubleshoot and fix your mixer yourself if something goes wrong with your mixer, you’ll definitely need that parts list manual.
Good luck with your KA mixer, Howard, Burke, VA.
If this solution was helpful though, please rate it. hslincoln
Jan 10, 2010 | Food Mixers
I recently acquired a KitchenAid/Hobart Model 4C stand mixer for free. It seems to work okay but I?m in need of a flat beater, dough hook and wire whip as it came with only the juicer attachment. Do you...
A number of attachments were available for the 4C, such as a juicer, a meat grinder, etc., all of which ran off the PTO on the front of the housing.  The only beater, however, was the wire one.  No dough hook was ever made.  I have been told that the motor didn't have the necessary power to run a dough hook.
Jul 25, 2009 | KitchenAid Food Mixers
My Super Grinder needs repairs
the blade of the jar got jamed, you have to remove the jar shaft and lubricat with any oil and refix it back
Feb 02, 2009 | Food Mixers
Need bowl and mixer attachments for Kitchen Aid Artisan Mixer
We've found most all accessories at any place that sells the mixer. Bowls, beaters, meat grinders, pasta makers, etc.
Jan 24, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Put kitcheraid meat grinder back together
Proper assembly of the Food Grinder Attachment is covered in the attachment's Use and Care Guide.
Jan 11, 2009 | KitchenAid Food Mixers
Oster regency parts
There are all kinds of Oster Kitchen Center parts and attachments for sale on Ebay. Here is another site that sells Regency parts: http://www.Goodman's.net
Can you help me with my Regency problem? I bought a used one with the hopes of using a lot of the attachments including a meat grinder (did not come with), but now after receiving the OKC there is no hole in the side of the mixer arm to attach the grinder - there is a metal circle. Do I need to punch out this circle - like an electrician does with an electrical box? HELP
Ladydirector@verizon.net
Dec 28, 2008 | Food Mixers
Grinder attachment
Cindy,if it has a screw take it out,grab a flathead screwdriver and work your way around the cap.Some mixers have been painted or just the gunk over the years make the cap hard to pull off.The push button i have never seen on a hobart mixer near the hub.Give me the serial and spec number.
Nov 12, 2008 | Hobart A200 Stand Mixer
MX-AC300 Mixer Grinder Got from India 2 months back Not working.Tried Reset Button too.
There is a great guy on Gerrard street in Toronto, who can fix mixer grinders and has parts also like breaker/reset switch etc.
The store is called Appliances 220, Ph # 416-778-9908.
Hope this helps.
Sep 24, 2008 | Food Mixers
Philips HR1363 Mixer Logo
117 people viewed this question
Top Philips Food Mixers Experts
eyecam
Are you a Philips Food Mixer Expert? Answer questions, earn points and help others
