Question about Minolta EP4000/5000 CS/PRO Copier
Minolta cspro 2010 error code c05 - Minolta EP4000/5000 CS/PRO Copier
  • Minolta Master
  • 1,297 Answers
PLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
Posted on May 22, 2010
C0d50 what ia the solution ? thnk for you
Posted on Feb 13, 2012
Have a Minolta CSPro 3050 with error code C004A. What does it mean
There is a fan located under the big glass section remove the glass an check the fan clean it or replace it.
Feb 01, 2012 | Minolta Office Equipment & Supplies
This is a public library in northeastern Montana with no Minolta repair help. Our CSPRO Minolta copier was donated without an instruction manual. The copier turns on but is inoperable.The letters COS...
What model? The C0S is most likely a C05 which is a fusing unit temperature failure. Meaning the fusing unit, the part that gets hot and fixes the toner onto the paper, is not heating properly. Most likely you are going to have to have someone fix that problem before the copier is going to function. I am in Kansas not Montana so I can't help you but hopefully you can find an independant guy locally that might be able to help you.
wheatlandsvc
Aug 04, 2010 | Minolta Office Equipment & Supplies
My copier minolta cs/pro ep 2010 does not function. when you switch it on it displays a spaner symbol and error code 05
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
Mar 20, 2010 | Minolta EP4000/5000 CS/PRO Copier
the error in the fixing unit
try to clean the upper roll thermostat
MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Oct 10, 2009 | Office Equipment & Supplies
Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Feb 06, 2009 | Minolta Di3010 Copier
Problem in minolta cspro 2050
What code are you looking for??? I'll tell you what it means for FREE.....
Aug 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
Ep2080 minolta cspro
Ep2080 minolta cspro error code comes up with c0500
Dec 06, 2007 | Minolta EP4000/5000 CS/PRO Copier
Konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
656 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
