Question about Sony MDS-JE480 Mini Disc Player
Mini dics play okay but cannot seem to adjust recording level isn't picking up anything from source ie-cd's or vinyl. Can you help?
    Problem Solver:
  • 4 Answers
Obviously you first need to check that your connections are 'out' of the source and 'in' to your MD recorder. On most Sony's you press the menu button until 'REC LEVEL' appears in the display. Simply adjust with the AMS wheel to desired level. Note that when recording 'digitally' the record level is automatically set. Good luck.
Posted on Jun 17, 2010
Vinyl recording turntable
The Denon will act just like a standard tape recorder. It should have an audio in, for recording. If that socket is connected to the audio out of a tape socket on your receiver, the Denon will pick up the signals that are sent to your receiver from whatever source. All you have to do is follow the instructions for recording on the Denon then. If you have lost the user manual for it, it's free on-line.
Jun 22, 2017 | Denon CDR-W1500 2-Disc CD Recorder
Not recording anymore
After you press the 'record' button the Minidisc unit is still in "pause mode" - you can hear the music and see the meters move, but notice that the time isn't moving until you press "Play" - then it will start recording. Is the time changing when you go to play it back? You might have left the MD in 'pause' perhaps?
Jan 30, 2014 | Sony Minidisc Mini Disc Remote Control...
I can not get my Crosley CR248 Songwriter to Finalize when I try to transfer from cassette to cd. It keeps showing me FAIL....
I don't know this particular machine but here are some general comments.
Most CD recorders need you to press (and sometimes hold) the record button followed by the play button before tehy actually record anything (if you don't press the play button you will still hear sound via headphones etc. but no recording file will be created)
Does it record from vinyl records okay or is it just cassettes?
Are you using the correct sort of CD?
We use a Denon CD recorder and it only works with AUDIO CDs - computer data CDs or CDRWs will not work in it. Even if the Crossley will accept computer CDs it may require a particular format either +ve or -ve (labelled CDR+ or CDR-) to be compatible. Once you have tried finalising a disk and it has failed you cannot use the same disk again.
Jan 29, 2011 | Crosley CR248 Turntable
Converting vinyl lp's to cd's with same quality sound. When we use our turntable played through the stereo connected to our iMac and use Audacity, the resulted cd sounds tinny compared to the vinyl...
Hi, use acoustica spin it again. You can adjust the input levels and it will convert the records analogue signal to wave format. Cheers styluscity@gmail.com
Aug 21, 2010 | Audio Players & Recorders
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Jensen JTA 450 turntable skips?
Try moving the arm up to the end of the vinyl, if it does go till the end of the vinyl then try adjusting your counter weights, a penny will do, if it doesn't go till the end of your vinyl then there's a mechanical problem check any obstruction at the botton of your arm.
Jun 09, 2010 | Audiovox Jensen JTA450 Turntable
Mini dics play okay but cannot seem to adjust recording level, isn't picking up anything from source ie-cd's or vinyl. Can you help?
You have to set the INPUT to what you're using. Line level or Tape Level signal to IN jack on MD. Also makre sure switch is set to "Analog" input; crank LEVEL all the way clockwise, and it should take off.
Mar 20, 2010 | Sony MDS-JE480 Mini Disc Player
How can I connect my CD-RW880 recorder to the
Make sure the phonograph is connected to the Phono Connectors. Hook up your CD recorder to the tape. The play connectors on the CD recorders can connect to the tape play connectors on your stereo. The record connectors on your CD recorder connect to the record outputs on the tape connectors on your stereo. You can also connect you CD recorder to the VCR connectors if you are using an audio tape as your source. All of the outputs and inputs are the same level except the phono.
Jun 12, 2009 | Teac CD-RW880 CD Player / Recorder
Recording
It will record any line level source (CD, MD, tape, tuner). You can only record vinyl records if you have a phono pre-amp.
The best way to use a CD recorder is to use the "tape loop" on your amp/receiver. Does your amp/receiver have a "tape in" and a "tape out"? If it does you should connect your CD recorder to these in/outputs. That way, whatever your amp or receiver is set to listen to, is what you'll be recording.
Shout if you need more help!
Sep 13, 2007 | Koss CDR200 2-Disc CD Recorder
Sony MDS-JE480 Mini Disc Player Logo
67 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
