Question about Hampton Bay 52 In. Brushed Nickel Romano with Integrated Pan Style Light Kit Fan
Hampton Bay Mondel EF200-36
Fan came with the house. Did not have a pull chain for the fan. Opened it up; the chain was pulled out of the switch. Bought a new switch, but did not make note of which wires go where on the switch. Have black, white, blue and yellow. I know black is the hot. From touching them together I know that white has to be on for any speed to work, but I have never gotten low speed, only medium and high. Which wires go in L-1-2-3? Thanks.
SOURCE:
salt56
  • 373 Answers
SOURCE: Hampton bay Fan 54 in
I think one of the brushes in the motor may be at fault: not connected properly. Would require taking motor apart and checking
Posted on Dec 30, 2007
  • 141 Answers
SOURCE: Hampton Bay San Marino 36" Ceiling Fan
18 gauge is a little light... should use 14. Are you sure it is a hum, or is it possibly the fan resonating due to imbalance of the blades. Watch to see if the fan is oscillating when it runs. Also, does changing the speed affect the frequency of the hum. If this is the case, you have to balance the blades using metal shims.
Posted on Sep 20, 2008
  • 25 Answers
SOURCE: New Hampton Bay Ceiling fan - runs only in clockwise direction
By using the "switch" to change direction I assume you mean the small slide switch on the side of the fan housing. What you have done is correct and would not affect this switch. The switch is probably bad and you need to return the fan. Suggestion: if the switch is on the housing of the light kit and the light kit connects to the fan with a plug, you are in luck. Go get another fan, swap the light kits and return the fan. Saves you a lot of work. Good luck!
Posted on Jan 18, 2009
woobie dog
  • 1273 Answers
SOURCE: where can i buy a replacement light socket in
Lowe's or Home Depot come to mind. If you are the DIY type, find a thrift store. Spare parts abound....and they're cheeeeeep!
Regards!
--W/D--
Posted on Jul 14, 2009
Treefrog15
  • 130 Answers
SOURCE: Hampton Bay Windward II Purchased 2002
Most fans have a small rectangular multi-tap capacitor connected to the speed control in the fan. It is likely that this has gone partially bad. The capacitance values are printed on it. Lighting stores and big box hardware stores generally carry replacements.
Posted on Feb 25, 2010
The pull chain for our Hampton Bay Sibley 52" Ceiling fan quit working so we think we need a new light kit???
You just need the switch by the sounds of it.
Hampton Bay Customer Support -Troubleshooting & FAQ ' The Home ...
www.homedepot.com/c/SPC_BRD_HamptonBay_Help
  1. Cached
  2. Similar
Find Hampton Bay customer support, replacement parts, warranty information, troubleshooting and ... Ceiling Fans Patio Furniture Lighting Bath Fans Fireplace
Hampton Bay - Ceiling Fan Parts - Ceiling Fans & Accessories - The ...
www.homedepot.com > ... > Ceiling Fans & Accessories > Ceiling Fan Parts
  1. Cached
Shop our selection of Hampton Bay, Ceiling Fan Parts in the Lighting & Ceiling ... Hampton Bay 3-Light Universal Ceiling Fan Light Kit with Shatter Resistant Bowl .... Fan Light is an ideal choice for replacing worn or outdated fan light fixtures.
Hampton Bay Lighting Parts and Accessories ' eBay
www.ebay.com > ... > Hampton Bay Lighting Parts and Accessories
  1. Cached
  2. Similar
Replaces Hampton Bay and many other similar ceiling fan remote controls. Common replacement for model number UC7078T or FAN-HD with a reverse button.
Hampton Bay Replacement Parts
hamptonlightingadvice.com/hampton-bay-replacement-parts/
  1. Cached
If you have a Hampton Bay product such as a lighting fixture or patio furniture or maybe even some solar lights or ceiling fans then you may need to find a ...
Hampton bay fan and lighting company website store
hamptonbayfanandlighting.net/
  1. Cached
Hampton bay fan and lighting online store. Menu. Skip to content. Hampton bay moved to new ... Hampton bay moved to new website >>>> hampton bay ...
Hampton Bay Ceiling Fan Parts
www.ceilingfansbay.com/hampton-bay-ceiling-fan-parts/
  1. Cached
Do you need help to find a Hampton Bay Ceiling Fan Part? ... known and reputable manufacturer of ceiling fans, bath fans, light fixtures, patio furniture, chandeliers and more. ... Easy Way to Finding the correct Hampton Bay replacement part:.
Hampton Bay Ceiling Fans & Lighting
  1. Cached
If you need a Hampton Bay replacement part, we can help you with that. Here are the most common Hampton Bay replacement parts that people search for, and ...
Lighting Replacement Parts For Your Ceiling Fan
www.ceilingfanreplacementparts.com/hampton_bay_lighting_replacement_parts.html
  1. Cached
  2. Similar
Hampton Bay lighting replacement parts are readily available to let you maintain for many years the beauty and function of your ceiling fans, lamps, chandeliers, ...
Hampton Bay Google Search
Nov 21, 2016 | Hampton Bay Dryers
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Fan chain came out of Hampton bay fan
i would check the manual it will show you how to fix it. if you dont have a manual get one here
Hampton Bay Ceiling Fan Manuals
Dec 20, 2012 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
I have a hampton bay ceiling fan and the fan pullchain came out. can this be fixed?
If it pulled entirely out of the switch, the switch will have to be replaced
Sep 17, 2012 | Hampton Bay 24750 Huntington III Ceiling...
How to replace fan 3 speed switch in hampton bay ceiling light
Remove the switch housing from the fan with a Phillips screwdriver. Depending on the model, there are either two attaching screws on the base of the switch housing, or three screws around the upper rim of the housing. Once the screws have been removed, unscrew the brass finial surrounding the chain on the outside of the switch housing and pull the chain through to detach the housing from the fan.
Insert a thin flat headed screwdriver into the slot next to each wire; twist the screwdriver and pull the soldered ends of the wires out. If the wires are connected to the terminals with screws, undo the screw a few turns and pull the terminals out from under the screw heads. Undo the two screws holding the switch to the fan and remove it.
  • Take the old switch to the nearest electrical or home improvement outlet and buy an identical replacement part. If there are two similar switches and you're not sure which is the right one, describe the fan to a sales assistant and tell him how many operating speeds it's equipped with.
  • ceiling light
  • May 27, 2012 | Hampton Bay 52 In.Carriage House II in...
    Chain switch broke
    The light fixture then the fans lower housing needs to be removed to gain access to the pull chain switch
    May 03, 2010 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
    Zing ear switch from a hampton bay ceiling
    Did you try Home Depot, Lowes, or any lighting supply store. It's a pretty common item, so they should all stock it
    Dec 12, 2009 | Hampton Bay 52 In.Carriage House II in...
    My Hampton Bay Windward II
    I need a fan chain pull switch for my Hampton Bay 5 Blade Model 552 od--
    SKU # 409-952----
    MFG # 5A00007
    SER # 720275940415653B
    The switch controls High,Medium,Low Speed and Off.
    4 Wires--Black,Brown Purple and Gray are connected to awitch, they come from a Block Capacitor (4.5mf,6mf and 5mf)
    This fan was purchased around 1995 and is in good condition but needs this replacement switch---
    Where can I get the replacement for this model?
    Apr 19, 2009 | Hampton Bay 24002 Ceiling Fan
    Fan switch broken, wires out when opened
    I googled Hampton Bay Manufacturing and this is what I found:
    Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
    Maybe they can supply you with a wiring diagram.
    Jun 08, 2008 | Dryers
    Hampton Bay 52 In. Brushed Nickel Romano with Integrated Pan Style Light Kit Fan Logo
    114 people viewed this question
    Top Hampton Bay Dryers Experts
    Steve Allison
    Steve Allison
    Ronald Buckner
    Level 1 Expert
    Donald Klecher
    Donald Klecher
    Level 1 Expert
    Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
