LG f1402 wahing machine - keep getting
Lg f1402 wahing machine - keep getting ''drain hose blocked'' issue though the filter is clear
SOURCE: lg wm2277hw
Followed suggestions for LE message and it solved my problem with the OE message - cleaned the drain filter located on the front of the machine near the floor.
Posted on Sep 03, 2007
  • 1294 Answers
SOURCE: LG front washer WM1814CW error OE
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 16, 2008
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
MNTECH
  • 1543 Answers
SOURCE: lg wm0642hw drain hose in front is pluged with
That's a real pain. Even if you remove the hose, it is hard to clean out. You can get at the pump end of the hose by tilting the machine back and reaching under it. Replace the hose will save a lot of time, or I'd suggest next time you want to clean out your filter do this:
Pull the machine out about 18 inches or so away from the wall and tilt it back until the back rests against the wall. (front feet now up in the air) Now, all the water will be back at the back of the machine and you can remove the filter to clean it out without spilling water.
Posted on Aug 16, 2009
  • 1382 Answers
SOURCE: LG washer with OE error
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Posted on Jul 27, 2010
My lg front load washer posted this ER: check the drain and the hose. we checked all the drain. but the machine stopped when it was on SPINNING. the ER POSTING : CHECK THE DRAIN is back
Water comes out of the drum through a soft corrugated hose, into the filter, out of the filter through another soft corrugated hose into the pump and out of it through the hose that is put to the drain. Have you checked all of these pipes? Sometimes something small can get past the filter and get stuck in the pump. If it is all clear, then perhaps the pump is faulty.
Aug 03, 2015 | LG Washing Machines
Stops in cycle, not sure if its when rinsing? I notice it stops and an error code of OE ?
This error code OE means the tub is not fully drained 10 minutes after the drain pump is turned on.This is possibly due to a clogged/kinked drain hose or the drain filter is blocked. Make sure the drain hose is clear then open the filter door located at the bottom left front of the machine. Drain the remaining water from the tub through the emergency drain hose located in the filter door area. Once completely drained, turn the knob counterclockwise then pull out and clean the filter. Reach in the pump impeller area and turn it with your finger. Replace the drain pump if the filter is clear and the impeller is broken or restricted and cannot be freed.
Jun 18, 2011 | LG WM0642H Front Load
I have a lg front loader mod-wd-1025fb washer, i moved the other day & i have just connected the machine up to wash & it fills up with water but wont spin it out & just stands still has a OE...
The OE code appears because the machine is not fully drained after 10 minutes to start the spin cycle. The machine cannot spin with water still not drained due to clogged/kinked drain hose, blocked pump filter, or pump not working. Remove the drain hose from where it is installed and drain the water from the machine into a basin that is enough to hold the water. The drain hose or the pump filter is indeed clogged/blocked if the water does not drain/flow by gravity into the basin.
Check to make sure that the drain hose is clear and not kinked. Open the pump filter cover then remove and clean the filter. Reach in the pump impeller with your finger and turn it to check whether it is stuck or not.
Make sure the pump wire harness is snugly connected and intact. Replace the pump if no issue is found with the drain hose, pump filter, impeller, and the wire harness or after all issues are addressed and the fault code still appears.
You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Aug 29, 2010 | LG WM-2277HW Front Load Washer
Help!! the washing machine wont spin out it keeps commin up wiv oe?? plz help
OE means that the drain filter or hose is blocked or kinked or clogged.
Clean and straighten the hose and clean filter.
Good luck
Feb 08, 2010 | LG WD-16115FD Front Load Washer
Lg washer not draining
On a front loading LG there is an acess panel on the lower left of the front panel. Open that little door and use the small hose to drain out the water left in the machine. (as long as the hose is not plugged with sand) Now, unscrew the big thing next to the hose, which is a filter. Chances are there is something there blocking the flow of water to the pump. If it is clear and still no pump out, you will have to replace the pump motor. (possible impeller loose on motor shaft)
Nov 11, 2009 | Washing Machines
Getting the OE error message on LG Tromm
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 07, 2009 | LG WM2688HWM TROMM SteamWasher
LG Washer/Dryer won't drain
May 19, 2009 | LG WD-3243RHD Front Load Washer / Dryer
My LG Clothes Washer has stopped mid cycle and is displaying an "OE" error code. How do I get the machine to finish the cycle?
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Apr 29, 2009 | LG WM2688HWM TROMM SteamWasher
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
