Question about Philips Magnavox Learning Universal Remote
MAGNAVOX UNIVERSAL REMOTE
I have a Magnavox TV/VCR/DVD. I lost the remote and purchased a magnox universal remote. I also have cable TV. I thought the code for this universal remote had the numbers 2, 0, and 5. I've tried every combination of these numbers. HELP PLEASE! Thanks.
  • 4 more comments
  • soonerbabe Mar 30, 2008
    I don't see a model indicator on the remote. I bought it at a discount store(like Walmart) and as I recall, cost between $10 - $20 - not the high dollar one. My cable is purchased through Cox Cable in Tulsa, OK. I have tried several codes, but did not see one for the TV/VCR/DVD combo on the internet sites that I have tried.
    thank you, but neither code works. I am pushing down the code search button until it stays on, then pushing the cable button. Neither code works. Help?
    We're getting close. 0247 works for the TV, but not the cable. In other words, the remote will now change the tv channels, but with cable, I need to change the cable channels. Changing the tv channel from "3" only gives me snowy channels. My cable box says DCT700/US, and appears to be made by macrovision. Thanks.
  • soonerbabe Mar 31, 2008
    Did my ;ast post made sense? I think I just need a code for the CABLE. The last code tyou gave me works for the TV, but not for the cable. Please help! Thank you.
  • soonerbabe Apr 01, 2008
    Do you all have the information is posted last weekend, or should I repost that information? I need my magnavox universal remote to change the channels on my CABLE tv/dvd/vcr. the code I got on my original post was 0247 or 247. That works great for changing my TV stations, but the TV needs to remain on channel 3. I need the cable channels to change. I know this is possible because it used to work, then a battery dropped out of the remote and the code became invalid. HELP PLEASE. THANK YOU.
    Sorry, it didn't work. Do you have the code I need?
    Genius:
  • 1,011 Answers
Hello sir,
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote! Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Try this link for more information...............
http://www.universal-remote.net/rca.html
Thanks
Done forget to rate the solution
Posted on Apr 01, 2008
    Genius:
  • 1,027 Answers
For the TV/VCR/DVD combo the code is 0456 4digit or 456 3digit
Posted on Mar 30, 2008
  • 236 Answers
Hi Soonerbabe, if your are trying to program the universtal remote to the units, here are the codes:
Magnavox tv numbers are:
002,009,109,118,209,309,402,408,502,508,510,807,914,917
VCR are:
130,226,330,534,536,635,734
DVD are:
441,442
One of those should work, just got to try them all...
If those all fail, let me know what your model numbers are for the tv/vcr/dvd and the model of the remote.
  • 5 more comments
  • Dave MacPhee
    Dave MacPhee Mar 30, 2008
    Sorry, didn't notice it was a combo set..
    Try this one
    0247
    if you can't enter 4 digits, just try 247
  • Dave MacPhee
    Can you take a picture of the remote and post it?
  • Dave MacPhee
    Code search instructions:
    Manually turn on the device (TV, VCR, etc.) to be
    controlled.
    2. Press and hold the CODE SEARCH button until the
    red indicator stays on, then release the CODE
    SEARCH
    button.
    3. Press and quickly release the desired mode button
    (TV, VCR, etc.). The red indicator blinks off once.
    4. Press the CHANNEL UP button repeatedly (up to
    300 times) until the device to be controlled changes
    channel. The red indicator blinks off with each
    button press. If you accidentally overshoot the
    code required, press the CHANNEL DOWN button
    to backtrack through the library until the device
    changes channel. Pressing CHANNEL UP changes
    direction to forward again.
    5. Press and release MUTE to install the code.
  • Dave MacPhee
    One of these should work for the cable:
    0552, 0148, 0952, 0453, 0654, 0754, 0048, 0752, 0254, 0947
    (could be without the 0)
  • Dave MacPhee
    Or try these 2
    0466, 0463
  • Dave MacPhee
    Dave MacPhee Mar 31, 2008
    did you look at the bottom of my post, the last 2 posts I made are for cable
  • Dave MacPhee
    Dave MacPhee Apr 01, 2008
    OK another shot...
    Try this one (is for comcast)
    0752 (or without 0)
  • 4,102 Answers
Hi have you tried scanning all codes with the remote untill it picks up the correct signal if you have the manual it will tell you how to do this if its possible it will work after searching the codes.
Also what model remote and what make cable box
  • 5 more comments
  • paul proctor Mar 30, 2008
    To program, press the set button until the light stays on. Then press
    the appropriate device button. Then press the Channel up button until
    the channel changes. Then hit the enter button.
    Try that and it will find your cable box code for you thats if its possible to control it with this control
    let me know how you get on ok
    Try my last post then get back to me
    But you can be pressing the channel up button for 15 min or more but it should operate it in the end just keep going untill the channel changes then dont forget to lock this into the remote my previous post tells you how to do this.
    If it dont work then its not possible to operate your box with this remote.
  • paul proctor Apr 01, 2008
    Hi if after you have used the controls function to scan every frequency then if it still dont work then their is no code going to work either.
    Have you tried pressing cable on remote the scanning untill it changes the cable its what psionics is telling you to do if it still dont work after this then the chances are that remote will not operate your unit. try following these instructions carefully ok
    if its the cable box your trying to get the remote to work then make sure the cable channel is on on the telly so you can see a channel from the cable box on the telly ok so put a channel on that you know is coming from the cable and you can watch it on tv screen ok then do as folows
    1 Switch the device on you want the remote to work on like cable box on with you seeing the channel on telly as if you was watching something ok
    2 press and hold "code search untill red light stays on then release light should still be on ok
    3 press and release cable only press once and release ok(red light will blink off then back on once ok
    4 now then keep pressing channel up button whilst pointing control at cable box ok not to fast or you could go past the frequencey ok keep pressing chan up button could take a while but keep pressing whilst pointing at cable ok.
    Now when the channel changes on the cable box you will see it change channel on your telly as you would if you was changing channel with the real cable box remote ok.
    So when you see the channel change stop and now press MUTE this will store that code for you and then you can use the remote to change the cable box.
    Im just checking you have followed the info correctly that another expert told you in previous post.
    ok so your not trying to enter a code your just pressing the channel up button untill the channel on the cable box changed ok let me know if you have done this you could press the channel up button for 15 min or more before it changes the channel. Dont hold channel up button down keep pressing it not to fast ok but keep pressing it for about 15 min or more so keep pressing it like you would if you was flicking through the channels ok.
    Then let me know the outcome of this
  • paul proctor Apr 02, 2008
    HI if scanning manually didnt find the code for you then the chances are that the remote wont work with that unit.
    Also what make is your cable box not who the provide is look on the back or bottom of cable box and it will give you make and model number also what make and model number is the tv,vcr,dvd let me know these and ill double check everything for you.
    If this remote worked before then their is no reason why it wont work now so please give me this info and ill hunt the codes down for you
    Sorry just seen you give make of coble but what make and model is the conbi
    also if you look on back of control or under the battery see if their is model number forthe control also
    1. press the device button (VCR, TV, ETC.)
    2. press the set button till it blinks
    3. enter the code
    Forget above 1 2 3 for now but does your remote take 4 digit codes or 3 digit codes as that make does to different types of remote for your make let me know ok
    hi please can you take the batterys out of your remote and give me the model number please its located under the battery
SOURCE:
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
I need code for philip s remote for a sayno ty
Philips rca universal remote codes sayno vcr dvd combo ...
www.fixya.com > ... > Remote Controls
Universal Philips Magnavox remote for a Sanyodvd vcr combo ? I have a cableremote and need to program my Magnavox vcr/dvd combo into it i have 2 dvds ...
How to Reprogram a Philips Universal Remote Controller ...
science.opposingviews.com > Computers
Dec 21, 2015 | Philips Televison & Video
Need code for magnavox tv urc-4021boo
Hi, the codes you have requested;
Magnavox - 0054, 0706, 0030, 1454, 1254
Instructions to program code:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., VCR/PVR, DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
Feb 12, 2011 | One For All URC-4021 Remote Control
I lost my remote codes for my philips US2-PM435S
Lost my remote codes for my philips remote. I need the combo codes for a tv, vcr,and dvd.
Apr 20, 2008 | Philips Magnavox Learning Universal Remote
Jumbo universal remote
I found that on the back of the 2205 it said that the unit was made by Funai. I looked in the Innovage book and found that the codes for Funai DVD are 231 and 233. 233 worked on mine. Good luck.
Jan 02, 2008 | Philips Magnavox DVD/VCR Dual Player
Magnavox MWR20V6 DVD
I purchased a Magnavox MWD7006 and need to have it play in Db5.1 KOSS Entertainment system; thus far only plays in stereo; anyone know what I'm missing? I'm using a S-Video cable.
Dec 15, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Remote control code for magnavox dvd/vcr combo
I need codes for my Universal Philips Magnavox remote for a Sanyodvd vcr combo ?
Sep 07, 2007 | Philips Magnavox Learning Universal Remote
Philips Magnavox Learning Universal Remote Logo
277 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
