Question about Sewing Machines
The needle hits the base plate about 1mm on the far side of the hole.
    Problem Solver:
  • 13 Answers
Sounds like a bent needle. did you try changing it to a new one? I have gotten bent needles new in package before so try a couple out...hope it helps
Posted on May 14, 2010
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
THe needle hits the base plate about 1mm on the far side of the hole.
You may have the stitch setting on the left/right(depends which side it hits) setting, or the needle is un-noticeably bent. Depending on where the needle hits, if you are in zig-zag mode and it is hitting the base plate(wide slotted base plate req'd) the machine may need re-setting of the needle stops(if fitted). This is uncommon so its more likely to be a bent needle.
Mar 20, 2010 | Sewing Machines
How do I centre the needle in the base plate it
I think you may have put the timing out. You will have to take it to a machine shop
Feb 09, 2010 | Janome Sewing Machines
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
Keep breaking needles
Here are some solutions to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
your needle.
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric.
    If this doesn’t seem to be the problem
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Needle hits needle plate with heavy fabric
that is your problem, your needle bar is centered too far to the back. There are 2 little bolts (Below the presser foot lift on the back of the machine) that must be loosened while the needle bar is repositioned aligning the needle bar assembly.
Mar 23, 2009 | Bernina 1008
Sewing Machines Logo
137 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
