Question about Dryers
Dryer will not start but has power going to it timer works light comes on in drum just wont start when you hit the button
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryerdryer will not start but has power going to it - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turningdryer will not start but has power going to it - 2_bing.gif
Dryer2_bindryer will not start but has power going to it - 2_bing.gifss= Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 15, 2010
Bosch wtl 5400 elect. condensation dryer
Does it make any sound like it is trying to run. You could open it up and possibly check the belt
May 01, 2008 | Bosch Axxis WTL 5400 Dryer
Dryer Does Not Tumble When Pressing Start
Hi,First of all check your door switch, make sure it is operational.If the door switch checks good, the start switch could be faulty, in newer dryers the start switch is built into the timer in older dryers your start switch may be separate, if you have to push on the timer dial to start the dryer, its built into the timer.
Check any other safety's that may be stuck open.Double check anyway. If it wont do anything, I would say its the door switch or the start switch.
Thank you
May 10, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Has the door lock mechanism or the pin strike snapped these are located on the door and push into the appliance activating switches. Have a look around the door area .
Mar 20, 2010 | Whirlpool Dryers
Maytag dryer model PYE4558AYW. Stopped running, and no light in drum. Getting power. Timer switch continues to work. Fried Timer?
first off check to see if you don;t have a breaker tripped in your breaker box ! also make sure there is 220v going to the recept.
then with unit unplugged remove the back cover to see if there is a wire burnt on the motor start switch which is common will be a red or a orange wire. if all that checks out then sounds like a timer issue
Jan 12, 2010 | Maytag PYE4558A Electric Dryer
GE model DQSR483EE1WW. This is what I know so far: the switch on the door works so it shouldnt be that safety, it is getting power because the light work and the timer at least buzzes like its working,...
Try looking for a broken belt. (electrical interlock prevents starting with broken belt) Disconnect power, open door, remove two phillips screws which go from top of door opening into dryer top. Swing top up and back. If belt not present going around drum, that's your problem. Remove one screw from side panel to front panel on each side (near top) and lift front panel forward and off the bottom pegs. Set the front panel to the side (leaving door switch wires attached) so you can slip new belt around drum. Reach under drum to put belt WE12M29 around drive pulley and around tensioning pulley. (grooved side of belt touches drum) Put front back on dryer and manually rotate drum a couple revolutions to make sure belt does not come off before closing up top and reconnecting power.
Dec 24, 2009 | Dryers
Dryer will not start on the senor light comes on
Hi..
If your dryer does'nt work aat all you need to check this
if it is noise check this
  • Level the dryer
  • Check the drum belt
  • Check the drum support rollers
  • Check the idler pulley
  • Check the glides
  • Check drum bearings
  • Check the blower
  • Check the baffles
Godd luck !!!
Regards
PCmania
Jul 07, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer wont start
First I would check the door switch I could have broken off or quit working if that is ok then there is a white thermal fuse on the blower housing behind the back panel check with a ohms meter to see if it is good it has two wires going to it
Mar 30, 2009 | Maytag Dryers
Dryers Logo
90 people viewed this question
Top Dryers Experts
