Question about Motorola Mobility Bluetooth Hands Free Headset Wireless Headset
Increase microphone volume of H350
Have any idea if this is possible or if the microphone has a fix volume level ? People tell me it is as if I was speaking far from the microphone (it's on my ear). Headset is new and fully charged... my phone was about 1 feet way from the headset only. Thanks for the tip if U have 1.
Hi i have h350 i cant pair it to my phone can u help me?
i have the verizon lg vx9900
Posted on Apr 28, 2008
How to increase volume on corded speaker phone
Are we talking about an old style phone that you plug into a wall jack. In that case you can only increase the volume as high as the volume control will let you. Going higher may introduce significate feed back (high pitched whine).
If it's the microphone volume you want to increase (sound volume for the other party), that's not possible with out a major hack.
The phone needs to control the speaker volume and the microphone volume, and balance the two so you don't get feedback, yet allow each party to hear the other. This only works within a fixed range, which, if you exceed, will over load the circuit and you will get feedback. You may want to try a different phone, which may have a higher volume.
Sep 06, 2017 | Cell Phones
HOW TO INCREASE VOLUME IN XOLO A500S
here are some steps to increase incall volume
open your dial pad thwn input *#*#3646633#*#*
go to hardware option nd select audio then select sph.....select level 6 then select volume lwvel at 160 then press on set key
now reboot your dewice
The first step is to get in the "Engineer Mode" by pressing the following set of keys in the dialpad "*#*#3646633#*#*"
Xolo A500s low microphone volume fixby Sbplus 20/09/2013 ' 3:39 6 Posted in Tutorials
If you are a Xolo A500S owner, then you might have noticed the low microphone volume on this handset. So think no more, just follow these simple steps and this problem will be fixed.
You can watch the video or follow the steps below.
The next step is to go to the " Hardware Testing " and select " Audio "
Now select " Normal Mode "
From the dropdown, select " Mic "
Now we will increase the value to the highest possible number, which over here is "255" You can also select the level as " level 6 " , which will set the maximum value.
Now press "set" to apply, and then restart/reboot the handset.
Repeat the procedure if the settings are not saved the first time.
Sep 09, 2013 | Cell Phones
Volume setting on the 3088
You have to do it during a call.
Press the top navigation button (blue ring) to increase volume, press the bottom section to decrease. The setting is retained when you end the call.
The left button will mute the microphone.
Jul 14, 2013 | RTX DUALphone 3088
My Dell Latitude E5500 speaker is too low, how to increase volume?
If you have volume control in the system tray (bottom right corner), double-click it. In Windows XP you will see all the sound controls. Increase all to the maximum level (except microphone).
Use the buttons close to the screen to increase the volume.
There is a volume control in the player you are using. Increase it to the maximum.
If it doesn't help, please let us know.
Sep 10, 2011 | Dell Latitude E5500 Laptop
Downloaded skype. I can receive and hear the calling party, but they are unable to hear me.
This is the issue regarding the Internal Microphone in the Computer.
Your contacts cannot hear you, until you have enabled the Microphone in the Computer.
You will find the information to enable the Microphone below:
Windows XP:
1) Double-click on the Volume Control. 2) Select the "Properties" option from the "Options" menu. 3) Select the "Recording" option in the "Adjust volume for" section. Click the OK button. Check the box labeled "Select" under the microphone volume and you should now be able to adjust the volume for the microphone.
Windows Vista:
1) Right Click the Volume Icon at the bottom right corner of your screen [The Task bar]. 2) Click [Playback Devices]. 3) Right Click the [Speakers] Icon and click Properties. 4) Click the [Levels] Tab; and there you will see the Microphone Volume slider (The one at the very bottom of the "HD Audio output" and "PC Beep" sliders where you can un-mute the mic playback.
Windows 7:
1) Click on Start (the Windows icon) and type sound. 2) Click on Sound under Control Panel. 3) Click on Recording tab. Select Microphone and click on Properties. 4) Click on Levels tab. The default Microphone Boost is set to 0. Increase it. 5) Close all the dialog boxes, and the microphone will be ready for use.
Hope this helps.
Jul 07, 2010 | Toshiba Satellite P105-S9337 Notebook
HP pavilion dv9005us. When using built in mic receivers say volume is very low. When I move the lid I get a crackling sound in the speakers like the mic wires a lose ..
To fix the low volume problem in mic receiver follow the steps below:
  1. Click Start , Control Panel .
  2. In the left panel, select Classic View .
  3. Select Sound , and then select the Recording tab.
  4. Right-click on Microphone and select Properties .
  5. On the Custom tab, select Microphone Boost .
  6. On the Levels tab, increase the microphone recording volume to the maximum level.
Then please check if it works fine otherwise you need to install the latest sound driver.
Windows VISTA 64bit and 32 bitsound driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35684.exe
Windows XP sound driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
Install the sound driver as per your operating system.
Apr 04, 2010 | HP Computers & Internet
Microphone volume goes down automatically
Go to control panel and select the sound option
There you will find microphone settings that are enabled, one of them is set to on and adjusts volume automatically as the noise increases, jsut disable that option
Cheers
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Asus 19inch monitor with web cam mic not working
double click on the microphone volume thing at the bottom right of your start menu bar, that should bring up your volume levels, make sure the mic isn't muted. Also check to see if there are any microphone cables to plug into your soundcard. It's also possible it's just a webcam and doesn't have a microphone with it.
May 04, 2009 | ASUS Computers & Internet
GN Netcom wireless headset volume adjustment
Transmit volume adjustment
Adjust the volume of transmitted sound according to personal preference.
To adjust the volume:
1. Make a telephone call and ask the person you are calling to assist
you.
2. Press the +/– buttons on the headset simultaneously for 2 seconds.
A beep will indicate when 2 seconds has passed.
3. Adjust the volume level by pressing the + or – button.
4. When the person you are speaking with fi nds the volume of your
voice appropriate, press the +/– buttons simultaneously for 2
seconds. This setting is now stored in the headset.
A Copy of the manual is avaliable at:
http://www.onedirect.es/files/GN%20Netcom-ES/GN%20Netcom%209120%20manual.pdf
You must have Adobe Reader to view it and the instructions are on page PDF page 3 or manual page 6. Adobe Reader is avaliable for download at:
http://www.adobe.com/products/acrobat/readstep2.html
May 21, 2008 | GN Netcom (9120-48) Wireless Headset
Headphones
Try opening the volume control (you should find a VOLUME icon in the bottom right corner of the screen. Right click on this and open volume control.
Check if the "microphone" level is down or if the mute button is checked. If it is, click on it again to uncheck and increase the microphone level to full. If you do not see the Microphone level at all, click on "options" and then "properties" and make sure microphone is checked.
Hope this helps..
Mar 29, 2008 | Logitech 502B Consumer Headphones
Motorola Mobility Bluetooth Hands Free Headset Wireless Headset Logo
121 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
