Question about Dishwashers
The rubber seal around the door came loose...i need another one
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Posted on May 15, 2010
My 96 windstar sliding door rattles when I hit bumps.also I tab it through a carwash and it leaks water like a faucet. I checked the rollers and hinge bolts and nothing appeared to be loose or missing! Any...
I think the solution to your problem is to check the condition of the sealing rubbers as their use is to seal out water and load up the door slides to reduce the rattles.. The same as if the door rubbers around the drivers door are missing the door rattles against the lock plate.
Sep 29, 2013 | Cars & Trucks
I broke my rubber door seal loose on the passenger side in the icey weather today. what/how is the cheapest way to repair it? i am not using the remote, because that quit working a month ago after it ran...
Go to you local autoparts retailer you will need little tree clips that go into holes in the rubber seal and in turn push into holes in the door and you will need a tube of weather sealant glue.... Clean the rubber seal on the door and pull out the old tree clips ( tilt them on about a 45 degree angle to get them out don't tear the rubber) next put in the new tree clips you have bought following the same instructions on how you removed the old ones. Finally put sealant glue on the rubber where it contacts the door ( all the way around) and also on the door frame itself where the rubber will contact allow the glue to get tacky on door and rubber (Approx 10 mins) start at one end pushing the rubber back onto the door and inserting the tree clips as you go along when you get to the end viola your done! hope this helps
Jan 07, 2011 | 2003 Hyundai Tiburon
My washing machine won't open and the rubber piece around the opening is off
If the door is jammed and will not open, there is a manual release that you can use to open it. The following link explains:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
If you are referring to the door bellow (gray rubber seal around the perimeter of the door), the following link explains how to reinstall/or replace:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Sometimes, the bellow clamps can come loose and pop the seal off. If the seal is not damaged it may be reused. If you require replacement parts, you can purchase them from any of the following websites and save a little from retail:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare.
NOTE: Overloading the washer can contribute to premature wear of the door bellow. Overloading can also cause items to get lodged in the door bellow and pull it loose.
If you have any questions about this repair, please post back with your model number. I hope this helps you.
Jan 03, 2010 | Washing Machines
Rubber door seal came off along with metal ring. How do we fix it?
If you are referring to the wire hoop with a small spring, this is the front bellow clamp. The bellow is the rubber door seal. Around the perimeter of the seal where it attaches to the door frame, is a small groove in the rubber. Make sure the rubber bellow is properly seated around the door frame opening, then the wire hoop inserts into the groove in the rubber to hold the front of the bellow affixed to the door frame. Without it and the bellow will eventually come loose and the washer will leak. To reinstall, just follow these steps:
1. Make sure the bellow is firmly seated all the way around the perimeter of the door frame.
2. Begin inserting the wire hoop into the groove, starting at the twelve o' clock position.
3. Work your way around the four and eight o'clock positions. While maintaining some downward pressure to keep the hoop inserted in the groove, pull the spring apart and snap the wire hoop back in place.
A second set of hands may come in handy to hold the hoop in position to get it reseated. Make sure the wire hoop ends up at the 6 o'clock position when you are complete.
If you have any questions, please let me know. I hope this helps you.
NOTE: Overloading the washer with heavy items can contribute to premature wear on the bellow and can cause the clamps to come loose.
Dec 30, 2009 | Washing Machines
My washer front load rubber at the door has pulled away and the wire with spring has come out. the rubber is not torn and i put it back in but i dont know were the wire gos
Dec 29, 2009 | Kenmore Elite 45986 Front Load Washer
After my washer spends the rubber comes
Do you mean the door seal has come loose.
Disconnect the machine from the power. Open top hatch by removing two screws in the back and sliding top lid back and up to remove.
Check down from the top of the machine and feel around the door seal. Make sure there are no holes or tears in the seal. Try and refit seal. there is a metal ring around the drum and also around the front panel where the door seal joins. Make sure the are tight and fit in properly.
Let me know if I didnt understand the problem.
Good luck.
Ash
Oct 22, 2009 | Samsung WF448AAP Front Load Washer
Water leaking from door
This video will show you how to change a door seal on this Bosch front loader washing machine to stop leak
we have all bosch repairs in our channel
You can get seals on eBay
Aug 29, 2009 | Bosch Washing Machines
Kenmore elite washer metal band on gray seal
The retaining ring inserts into a groove in the rubber seam around the perimeter of the door where it attaches to the door frame. To reinstall, first make sure the door boot is fitting snugly around the door frame opening. Sometimes when the retaining spring comes loose, the rubber may pull away from the door frame. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure the wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place with your thumbs. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
If you have questions, please let me know. I hope this helps you.
Jun 30, 2009 | Washing Machines
Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
314 people viewed this question
Top Dishwashers Experts
Owen Barnes
