Don't want to use handset
I want to know if i can answer all my calls directoly from the amp without touching the handset. I have worked with one before that allowed me to remove the handset completly and answer and make calls. Do i need a special phone, a different amp or is there an adaptor .
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi Kirsty
    What sort of amp is it you are using?
    regars
    Graeme
  • 1,512 Answers
Hi, let me know the models of equipment, and I will be able to do some research for you:)
Posted on Apr 10, 2008
SOURCE:
Plantronics CS55 Headset
Office was wired that way i have one tried several ways to use it without the lifter did't work had to buy a lifter the next problem is the phone not all will work Cisco uniden will work good
Jun 18, 2014 | Plantronics CS55 Wireless Headset
GE 27998GE6-C cordless phone with answering machine handset doesn't work
I can be of help please email me [email protected]
An upgrade can be offered, with lower call rates.
Jun 13, 2017 | Lands Phones
I have a panasonic kx tga 109ex cordless phone with 3 handsets. If I answer a call one one of them, how do I tranfer the call to another handset?
dial another number don't end current call just hold, then, if answer your latest call go option and select conference .
Sep 18, 2011 | Cell Phones
Phones were working perfectly. Without any warning the handsets have stopped ringing and calls bypass my base unit answering system and go directly to my provider's answering system. I have a dial tone...
check diversion - You may have set unconditional diversion to voice mail or have it set somehow ?
Maybe provider can check diversion settings
May 07, 2017 | Lands Phones
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
I cannot answer the phone without pressing the incoming call button that is flashing. I want to be able to answer the phone just by picking up the phone.
From the phone, don't pick up the handset and press PROGRAM 99 then dial 22 and press STORE. Here's a problem. By default, that's what it's supposed to be and if it beeps twice when you press STORE, you didin't change it. Pick up the handset and drop it back down to exit programming.
In order to have incoming line preference, your phone has to be RINGING :-) So, if the first program didn't work, you need to see your system manager to program your phone to ring. Or find an installation manual on the internet.
Carl
May 20, 2011 | Panasonic KX T7220 Corded Phone
Wharfedale Florence handsets restart on incoming call
We are having the same problem as you with our Wharfedale phone. Did you ever find a solution?
Thanks
Oct 29, 2009 | Lands Phones
Can i transfer call from 1 handset to second handset?
You can't transfer calls from one handset to another. With both handsets in your posession, you could simply give someone the other one to talk so you could engage in a 3-way conversation. It would also be good to call your local phone provider to get three way calling (a small expense). I use this all the time so I can talk to two other friends at once and we can all make plans together, without having to call, hang up, call the other one, hang up..you get the drill..
Aug 05, 2009 | Lands Phones
Lucent 6416 d+m
I dont think so. You might have to contact the administrator.
But here is the manual for your phone.
http://www.uts.csus.edu/uts/6408_16_24.pdf
Oct 29, 2008 | Lucent PARTNER18 Corded Phone
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
19 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
