Question about Apple MacBook Air
I have mac book with volume keys. I try to switch
I have mac book with volume keys. I try to switch the volume but the only thing that pops up is a round circle with a bar through it. I went to my system perferences and found sound but nothing it clicked to mute. How do I get the volume back?
  • 846 Answers
There is a problem with your audio jack. It thinks that the optical link is plugged in. Look into the jack and you'll see there is a red light for the optical link. Try to clean the jack, if you see and contacts that are recesssed, try to pull them back using a tooth pick. If that fails, the jack needs replacement. Here is an Macbook Repair Guide that shows how to open a Macbook. If you want somebody else to do it for you go to Macbook Repair.
Posted on Jun 28, 2010
2 Suggested Answers
iFixapples
  • 57 Answers
SOURCE: I have mac book with volume keys. I try to switch
I laughed when I saw this (NOT AT YOU, only because I had just finished answering this question for a MacBook Air). Just so you know, this is a VERY common problem among MacBooks. I own a MacBook repair shop and I see it quite a bit. it has even happened to my own MacBook Pro and Standard 2.4 GHZ MacBook. Usually this problem is accompanied by a little red light inside the earphone jack but not always.
Get a can of compressed air (for dusting of computers/electrical components) and attach the small straw that is supplied with the can.
Next, insert the other end of the straw into the EARPHONE jack. No need to jam it in there. Just insert it about 1/4 inch. Now spray a blast of air inside the jack a few times. Each time you do this, TRY THE VOLUME BUTTONS. They will work! This doesn't harm the computer and will not void the warranty. Plus it will only cost you about $3 to fix. It may take a few times but it WILL work. Here is my email if you have further questions and don't forget to vote if when this helps you: i_Patch.securepath@live.com
Posted on Apr 25, 2010
How to reset mac book key board
Did you do this? Under SYSTEM PREFERENCES click on LANGUAGE & TEXT, then INPUT SOURCES and uncheck the boxes for all but the language you want. (You can pick more than one). Then before you leave, click on the bottom where it says "Show Input Menu in Menu Bar." The Menu Bar will show you the flag from the country whose language you have selected. If you click on that, you will see the other languages you've checked and can change them. Hope this helps.
Oct 19, 2014 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
How do you fix stuck keys on an apple computer
It is not a hardware problem and easily solved by technicians. If you don't have enough knowledge than try with any Mac Book Expert. Mac Book technician will guide you step by step for reliable solution. Follow https://discussions.apple.com/message/24231664#24231664#24231664 and Mac Help .
Jun 01, 2014 | Apple MacBook Air
Where is volumn control located on Mac Book
F12 increases volume. You may need to raise the volume on the browser before you go full-screen.
Feb 15, 2014 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
I have mac book with volume keys. I try to switch the volume but the only thing that pops up is a round circle with a bar through it. I went to my system perferences and found sound but nothing it...
Mar 20, 2010 | Apple MacBook Air
My mac book will turn on but it wont load up
Clicking sounds are usually the hard disk drive going bad. Replacing the drive is not for the faint of heart on the Mac Books.
-=/ Daft Tech /=-
Sep 29, 2009 | Apple MacBook Mac Notebook
I have a mac book and two of the keys have popped off. Can they be put back on and How do I do that?
Placing back the keys is not possible manually except that you stick it, and thats the worst thing you would do. if you have an apple service center nearby, get it serviced by them as they need to open the lower case of the macbook to do that.
Btw is it Macbook or Macbook Pro? Because macbook pro has a unibody which can not easily get the keys back into position if they popped off.
Sep 18, 2009 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Pair plantronics voyager 510 with mac book os x
1. Turn Bluetooth On in Macbook 2. Turn the headset On 3. Press the Up volume and the conversation On/Off key at the same time until the blinking blue lights blinking Blue and Red alternatively 4. In a couple of seconds the Mac will ask for the Authorization Key 5. The Auth key is "0000" (4 zeros) 5. Pairing should now be successful and you should be able to use the PLT510 headset with your Mac. I can
Jul 13, 2009 | Radio Communications
Mac book will not turn on.
A flashing folder at startup means that the Mac doesn't recognize your system. This can be either a hardware or software problem. The hardware problem would be the hard drive, and the software the OS.
So these are the steps you should proceed: 1) Check your hard disk by using your install DVD (press the c key at startup), choose your language, go to the utilities menu and hit Disk utility. go to SOS tab and select your hard drive on the left. Click "repair volume" and check what happens.
2) reboot, if it does not recognize the system again, reinstall it using the "archive-install" option
May 29, 2009 | Apple 13.3 MacBook Intel Core 2 Duo 2.2GHz...
PROBLEMS WITH Microsoft Office:MAC
Have you tried to click on your desktop.
Jan 08, 2009 | Microsoft Office 2004 for Mac
Volume problem
try turning up both the system volume (on your top menu bar, by your clock), and the itunes volume (in the itunes window), maybe one of them is set too low..?
Brad
Apr 09, 2008 | Apple PowerBook G4 Mac Notebook
Apple MacBook Air Logo
342 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
