Question about Kenmore 98702 Stacked Washer/Dryer
Kenmore 417.99980120 stack washer/dryer won't drain.
Have a Kenmore 417.99980120 stackable washer/dryer that would not drain or spin at times. Found that dipping out some of the water would allow it to work and drain remaining water and spin. Now even this method does not work. Any ideas or suggestions?
  • 15,935 Answers
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
Posted on Oct 01, 2010
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Check for a kinked drain hose. Also, if it is an older machine it could have something stuck in the drain pump. The usually culprit is an under wire bra
Mar 20, 2010 | Kenmore 98702 Stacked Washer/Dryer
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer spins, but not as fast as it should. The
Check the drain pump and /or filter not jamming / blocked
Nov 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore stackable washer/dryer 417.97802792 won't drain
its your brushes on your motor or the motor itself but my guess is the brushes replace and enjoy
Jun 23, 2009 | Kenmore 98702 Stacked Washer/Dryer
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
188 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
