Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Bissell Velocity Vacuum brushes stopped
Hello. The brushes on my Bissell Velocity stopped turning. I checked the belt, and the part that turns it, and they are fine. The brush part itself appears that it should rotate on its own, but is frozen. Do I need to replace the brush part? Is it supposed to rotate on its own? Thanks, DAvid Rambaldi
  • 2 more comments
  • kimberly-E Oct 08, 2008
    I replaced the belt but the brush roller will no turn. it seems to be locked into place and the belt breaks again when I turn it on. What am U doing wrong?
  • Anonymous Dec 05, 2008
    My brush stopped turning on my Velocity and it broke all the belts I tried to put on.. We did get it to run but it is very noisy now. I have ordered a new brush online today. Hopefully this will fix the problem.
  • Anonymous Mar 25, 2014
    My brush won't turn in my Bissell lift off vacuum. The belt isn't broke
  • Anonymous Mar 28, 2014
    I noticed the brush stopped turning, even though the brush button was on. Then I noticed the left rear wheel was loose, like something was broken inside the wheel.
  • 432 Answers
The brush bearings wear out on these things. I know I replaced mine twice before buying new carpet. I've had it for 10 years,
You can order these parts on the Bissell website:
http://www.bissell.com/Products/p/CleanView+Brush/product.aspx
http://www.bissell.com/Products/ak/replacementparts/p/CVPT+II/product.aspx?%23=Detail#Detail
http://www.bissell.com/images/UserGuides/35934_804.pdf
Posted on Mar 30, 2008
Why doesnt bissell carpet cleaner brush turn properly
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Aug 06, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
I have the Bissell Healthy Home vacuum, it will turn on but the brush won't spin and I have tried the grey button and tightening the screws. Neither worked, any other suggestions?
You can purchase Bissell replacement parts directly from Govacuum with an exclusive 11% discount for Fixya.com readers, use code: FIXYA11 to checkout to avail the offer. We also offer free shipping over $35.
Bissell - https://www.govacuum.com/collections/bissell
Jeethu
Govacuum Team
Apr 26, 2014 | Bissell Healthy Home HEPA Bagless Upright...
Turbo brush on bissell cleanview helix stopped spinning
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
Ava B.
Feb 07, 2012 | Bissell Cleanview Helix Deluxe Bagless...
Bissell 5990 vacuum cleaner brush does not turn
Ava B.
Feb 06, 2012 | Vacuums
Bissell 3750 brush not moving has new belt suction works well on vacuum
Ava B.
Sep 17, 2011 | Kenmore 22812 Bagged Canister Vacuum
I have a lift-off bissell vaccuum and as I vacuum often the power brush will turn off and on. How can I fix this?
Ava B.
Jul 16, 2011 | Bissell 37604 Lift-Off Pet Bagless Upright...
My Bissell Model 3760-4 is not working properly. The belt has been replaced (and checked 3 times), but the brush bar does not move when the brush motor button is on. The little metal turning piece that...
Ava B.
May 12, 2017 | Bissell Lift-Off(R) Revolution(R) Turbo...
My 5770 bissell vacuum brushes won't turn on.
Ava B.
Jan 31, 2010 | Bissell 5770 Healthy Home Bagless Upright...
Main Brush Failure
first check if the brush motor is turning before you spend money on a new brush roller and belt. remove the belt by unscrewing the screws holding the brush cover ( the part touching the floor ) and slip the belt of the rotor. turn the vacuum on, and the brush on while the vacuum is in a reclined position. if the motor is not moving, you need a new motor.
Jul 31, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vacuum problem
Check the brush roll, do the ends turn freely, if not, replace it. Could have a clog in the hose or the dirt inlet by the brush roll, the other could be a bad motor.
Mar 19, 2008 | Vacuums
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
1,084 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
