Question about RCA RCU600M Remote Control
I have Direct TV: the RCA Realistic DVD VHS recorder will not work with Direct TV
Is it the remote?? Code??? Tv isRCA Color Track Plus.. Direct TV won't help my brother...he is slow so that may be why....he lives in another city..we will do this by phone....Thanks for your help [email protected]
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
White remotes RC16, RC23, and RC24 may not be programmable to some later TV models.
The codes for RCA televisions are as follows
11447, 10047, 10019, 10679, 11247, 11547, 10090, 11147, 11047, 11347, 10018.
here is a link to the DirectTV instruction page for remote set up and instructions if you are unable to find the correct code.
http://satex.com/directv/remote_codes.html
Hope this helps :)
Posted on Mar 30, 2008
SOURCE:
Best way to transfer vhs to dvd
hi if u r using rca cables connect 3 leads to output of vcr then connect them to input of dvd recorder......connect another cable to output of dvd recorder & connect it to tv input terminals set tv to av .on remote also set input on remote for dvd recorder good luck
Aug 29, 2015 | Televison & Video
I am trying to copy VHS to DVD [using quality DVD-RW] but keep getting screen message of NO SIGNAL - Please check connections.
Hi try this set up to check if you're scart set up isn't the problem connect 3 rca lead to the output of the vcr into the input of video recorder then plug 3 more leads from output of video recorder into the TV set you're TV to AV INPUT AND set YOURE VIDEO RECORDER TO THE CORRECT INPUT MODE ...good luck
Aug 03, 2015 | Televison & Video
I have a Magnavox TV I connected the VHS to, I get picture,but, no sound. How do I get the audio working?
First, you should see "Track" button on the VHS or VHS Remote, press the track severally still sound comes on. But if sound does not come on, you can follow th
There are two connection method you can use to connect our VHS to TV. 1. is RF wire and 2. is RCA (Yellow & White/Red).
Using the RF, Check the back of your VHS, you will see "RF Out", connect the RF wire to that part and the other to "RF IN" of the TV. Then search your TV and there should be a display and sound.
Using the RCA, Check the back of the VHS, you will see Video OUT and AUDIO OUT, connect the RCA wire there and the other part to IN of the, then press AV on the TV remote.
Good luck.
Oct 06, 2010 | Toshiba W403 VHS VCR
How to connect the toshiba to a rca tv with direct tv
do you have dvd in jacks on your rca...direct tv out to dvd in.....(this setup u need to scan for channels on the dvd)..note some premium channels will not record on dvd (will and still record on vhs)
May 29, 2010 | Toshiba DR410 DVD Recorder
Set t.v /remote to work with other components
Do you have a Sanyo Universal Remote ? If not, you program your dish 500 remote for these.
Sep 16, 2009 | Sanyo DS31590 31" TV
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Need code for Viore TV to program LG RC897T DVD/VHS Recorder
I believe Viore is the same as Samsung. I only noticed this by accident as I bought a Viore TV and my friend bought a Samsung and I noticed both remotes were identical. I tried the Samsung codes and the remote worked. Good luck! Kevin
Dec 29, 2008 | LG RC897T DVD Recorder/VCR Combo
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
Direct TV Remote - No Codes Operate TV
I couldn't find any info on that particular model, but if it has a built in DVD or VHS player you cannot program the Direct TV Remote to it. You will have to use both remotes. The Direct TV one to change the channels and the TV remote for the TV functions.
Jan 18, 2008 | iLO 3200 32 in. LCD Television
RCA RCU600M Remote Control Logo
103 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
