Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Not starting properly have to turn off and on to start
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 15, 2010
Triumph trophy 900 carb 1997 starting problem. sometimes the ****** just will not start it turns over back fires turns over and starts, sometimes starts second turn. has had new coils fitted tappets a
Hmm sounds to me your Carburetor needs cleaning, check your intake might be just a bad air filter, also change you spark plugs and make sure they are on proper adjustment. that what i did when i have that problem... hope it help
Dec 23, 2012 | 1997 Triumph Trident 900
When i start my gateway netbook lt20 a black screen pops up asking to start windows normally or 3 other options.. why?does this happen?
Usually because you didn't shut windows down properly before turning your computer off or completely draining your battery. If that is the case then simply select start windows normally and as long as you follow the correct shut down procedure it shouldn't happen again. If it does there may be a problem with your windows instalation.
Aug 17, 2011 | Gateway LT2021u Netbook
Will not start. When key is turned to start
hi..
exactly the starter motor is not activated so
1. try checking the connection to the motor and terminal of the motor
2.check the battery terminals are properly secured if any loose conncetion are there they wont work properly
3.check the continuity of the wire which is going to the motor
Jul 09, 2010 | 2000 Nissan Maxima
Viper Remote Start wont work properly
if it cranks and wont start then its probably the bypass the module thats not working correctly
May 28, 2010 | Remote Start System
I have no rear turn signals and brake light.
i would start with the fuses, then move on to the wire connectors from there.
Jan 21, 2010 | Harley Davidson FLHTC Electra Glide...
1990 Ford Laser not starting properly
change the main power cable from the battery to the stater or the solenoid
Aug 19, 2009 | Ford Laser Cars & Trucks
Dryer starts but wont stay on
There is a switch on the motor that activates when the drum is turning at the proper speed. This switch should be checked if the drum is turning properly.
Eric
Jun 14, 2009 | Kenmore Dryers
Laptop won't startup properly
Friend that problem if cause of not shutting down properly.just select start safe mode as it recovers it will restore late back to the proper one
Jun 05, 2009 | Tablets & eReaders
Wont start....
Hi mdntcowboy
I'm Dave
When you turn the key to the start position do you hear the click of the starter solenoid?
If you do either your starter is faulty or you do not have enough voltage to power the starter. Your lights do not need much voltage nor the solenoid however the starter requires 12.5 volts to start properly. If you do not hear the click check to see if the car is in park properly. The vehicle will not start if the car is not properly in park or neutral...try it in neutral. Check the starter relay, ignition switch, park/neutral start switch.
Dec 02, 2008 | 1994 Chrysler New Yorker
When i turn on it starts too run ang then stops and starts agatn flashing on and off
when you turn on your pc desktop do you hear any beep sounds when it starts to reboot? if not then it could be probably cause by your graphic card not slot in properly or other hardware parts not properly inserted and install. Please turn off your PC and check all the hardware parts in your desktop are properly in place. cheers
Apr 20, 2008 | Computers & Internet
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
231 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
