Thorens receiver at 403...schematics or service manual
informatica
  • 1114 Answers
SOURCE: I just received a Thorens
Hi - You can download the manual by registering on the link underlined in blue below:
TD320
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Jul 31, 2008
  • 189 Answers
SOURCE: I have a Thorens TD115. The left channel doesn't
HELLO
I am basing my findings on my THORENS TD166 MK2.
First thing you have to do here is check the wiring from the headshell to the RCA phono leads - for this you need a multi-meter set on continuity.
Disconnect the cartridge and put one meter probe on one of the headshell wires and the other to the centre pins and outer rim of the RCA plugs. One headshell wire should read fine on one part of the plug as it will correspond with ONE part only of the RCA plug. When you have checked all wiring and you get a continuity check (OK) then you must look to the cartridge.
However, if you get a reading of ONE headshell wire reading more than one part of an RCA plug then you may have an internal wiring problem in the deck.
Here is something that might help:
HEADSHELL:
RED - to centre pin of right output plug GREEN - to outer metal rim of right output plug WHITE - to centre pin of left output plug BLUE - to outer metal rim of left output plug In some cases this wire may be black
Just to recap, if these readings are OK - the cartridge may be at fault.
I wish you well with it!!! (:-)
Posted on Sep 26, 2009
Testimonial: "Thanks for the help. As a matter of fact I spoke to a Thorens distributor who told me that more than likely I need to replace the RCA plug and wires."
SOURCE: thorens tp-63 or tp-62 arm wand
about what
Posted on Jul 25, 2010
kapishtech
  • 2272 Answers
SOURCE: Dear Sirs, i`d like to
To get service manual you will have to get it from Thoren service center : Click this link directly and fill your details and get the required service manual:-- http://www.thorens.com/contact/contact.html ---------- For available service manual list please click on this link:--- http://tech.thorens.com/en/ ------------- Check out.Keep updated.Thanks.
Posted on Sep 02, 2010
SOURCE: Cannot remove clip around spindle to lift off
Hello mervyn_u,
The clip is a snap ring and it is best to use a pair of snap ring pliers to remove it without damaging or stretching it. Many people use a flathead screwdriver to pry off the ring but, again, you risk damaging the ring. You can purchase an inexpensive pair of these at your local Sears or other hardware store. They are simple to use.
Posted on Nov 08, 2010
Where can I find Staiger parts? GeBr Staiger (Germany) Thorens Movement
It's worth joining the vinylengine website. It's loaded with forums and manuals dedicated to higher end tts
Jan 10, 2016 | Thorens Audio Players & Recorders
Htr-6230 low volume
If I were to guess from the information you submitted, your Thorens, which needs a specific phono input, is now plugged into a high level input, such as an AUX, DVD, CD etc. These inputs are for a 300 Millivolt input device. Your magnetic cartridge is no where near 300 Millivolts; never measured it, but would have to say a 1/10 of that. If your receiver doesn't not have a label that says "phono", you will need a phono preamp to amplify the output of your Thorens, with the very low input, to an output of 300 Millivolts. These preamps are sold just about everywhere, Best Buy, Radio Shack, etc.
Mar 01, 2014 | Thorens Audio Players & Recorders
I have a turntable Thorens TD190 and i can't figure out what THE function is of the 17/30 switch? Can you help me?
It is a selector for record size. Ie. 30cm -12" records and 17cm-7" records. Cheers john. Styluscity.com
Nov 26, 2011 | Thorens TD-190 Turntable
I need power supply for a thorens td 280 turntable 16vac. where can i order one.
Here's a parts list, but it doesn't link to a supplier.
http://www.theanalogdept.com/thorens_part_nums.htm
Power supply for:
TD 520/521/TD 290 II/295 II:
AC-Adapter, Euro standard 230 V
Z4150084
AC-Adapter, UK standard 240V without plug
Z4150087
AC-Adapter, USA standard 110V
Z4150086
AC-Adapter, Japan standard 100V
Z4150085
High End Power Supply for all units with 16/18 Voltage
9999175
This is the Thorens Service Warranty link:
http://www.thorens.com/support/service-warranty.html
This is the Service partners (post warranty) U.S.
http://www.thorens.com/support/distributors.html
Distributor United States:
Address: WS Distributing, LLC
3427 Kraft SE
Grand Rapids, MI 49512
Phone: +1 616-885-9809
Fax: +1 616-885-9818
Email: tmyerswsdistributingcom
Website: www.wsdistributing.com
This is the Thorens Homepage Technical Database for the TD280
Downloads are NOT free.
http://tech.thorens.com/en/thorens.index.php?id=en_650_0_1_&name_search=td280&category_search=1&prodd_search=0&x=4&y=7
Someone there should be able to help you out.
Dec 31, 2010 | Teac Audio Players & Recorders
Low volume from my thorens td-145 record player
Have you checked the cartridge in the turntable arm?Also check to make sure receiver/tuner is switched to Phono or Aux..Also check to see if there is a speaker switch on receiver.
Mar 07, 2010 | Thorens TD-170 Turntable
Need new lid for Thorens TD 160 turntable. Any ideas where I can get one from
I can't guarantee anything, but look up and call Stereo Component Systems in Boston Ma. When I was there, they still had quite a bit of Thorens parts available.
Dan
Sep 08, 2009 | Thorens Audio Players & Recorders
124 people viewed this question
 Grubhead
Grubhead
