Question about Canon PIXMA MP160 All-In-One InkJet Printer
Hello from tita
Canon inkjet pinter scaner cdrom has a know compatibility issue with this version of windows and might notrun as expected
    Guru:
  • 377 Answers
Hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Posted on Apr 21, 2008
SOURCE:
Hello, i'm trying install the Canon Scan FB 630P Scaner on my labtop (windows 7) ... but, it doesn't work. I think there is a compatibility problem. (In Canon website doesn't appear drivers to...
There are no available drivers for win 7. I suggest you to use the winXP drivers (compatible for win98, 2000, vista etc) here is a link to download the latest version at any language you wish. After the download finish extract the downloaded zip file, right click at the s14a_enx fil, choose properties and go at the compatibility tab. Check the box for compatibility with win XP sp 3 and hit apply - ok. Run the s14a_enx fileand follow the on screen wizard. In case installing the drivers this way won't solve the problem, sorry to said, but you need a new win 7 compatible scanner.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 23, 2011 | Canon CanoScan FB630P Flatbed Scanner
Hi I am running Windows Vista SP2 on an HP Compaq laptop and trying to install drivers and then software for Canon Printer IP4600. Have tried from CD Rom, Windows update with printer attached and Canon's...
Try updating drivers on device manager.
Plug in your printer - right click computer (on start menu) - click properties - on the next screen click device manager - on the next screen there should be a usb device with a yellow question mark - right click on the question mark - select update driver software - ensure the cdrom supplied by canon is in the cdrom drive.
The computer should scan the cdrom for the applicable drivers and automatically install them.
Jan 02, 2011 | Canon PIXMA iP4600 Color InkJet Photo...
Hello, I try to find a driver windows 7 for a printer canon i850. The solution driver windows XP and add-on windows 7 is not good. I don't find the solution. Thanks Bruno
This is the direct download link for Canon i850 Inkjet Photo Printer compatible with Windows 7 (Click Here), open the link, scroll down to the bottom and click "I Agree - Begin Download", save it and install it. Your printer should run without any problem. Unfortunately, there's no additional software to be installed on Windows 7 for this Model.
If you have problem, let me know.
Good Luck.
Thanks for using FixYa.
Dec 17, 2010 | Canon i850 InkJet Photo Printer
I have recently bought a new lap top with Windows 7 OS system and am having problems getting my cannon inkjet pixus 2000 to connect to it. If i use the cd install it says it isn't compatible, i've tried...
First, uninstall the printer software that was installed from the CD. Next, download the latest driver from http://software.canon-europe.com/products/0010093.asp. If your laptop is new is is probably 64 bit. Make sure that you download and install the 64 bit version. The default versions on the CD and from most download sites is the older 32 bit version.
Aug 11, 2010 | Canon PIXMA iP2000 InkJet Printer
Canon Mp210 scaner problem
Uninstall the driver and reinstall the driver.It will work.
Feb 25, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
71 people viewed this question
Clive
Clive
old marine
old marine
Ekse
